Postado originalmente por
sonishi
galera, to com um problema, talvez pra voces seja facil, pois ainda estou gatinhando no mikrotik. Vamos ao problema !! Eu fiz o balanceamento de carga PCC (Mikrotik 3.3) e a tela de login do hotspot nao entra a nao ser que se coloque o ip do servidor, por outro lado se eu desativar a segunda regra em route (abaixo em vermelho) a tela de login aparece, o que pode ser galera ???
Desde Ja, agradeço a todos !!!
As regras >>>------->
/ip firewall mangle
add action=mark-connection chain=prerouting comment="" connection-state=new disabled=no dst-address-list=LINK0 in-interface=Lan new-connection-mark=Sites0 passthrough=yes
add action=mark-routing chain=prerouting comment="" connection-mark=Sites0 disabled=no in-interface=Lan new-routing-mark=Rota0 passthrough=no
add action=accept chain=prerouting comment="HTTPS FORA DO LOADBALACED" disabled=no dst-port=443 in-interface=Lan protocol=tcp
add action=change-ttl chain=forward comment="Filtro Tracert / Traceroute" \
disabled=no new-ttl=set:30 protocol=icmp
add action=mark-connection chain=prerouting comment="" connection-state=new disabled=no in-interface=Net new-connection-mark=Net_conn passthrough=yes
add action=mark-connection chain=prerouting comment="" connection-state=new disabled=no in-interface=adsl_Spd new-connection-mark=adsl_Spd_conn passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=Net_conn disabled=no new-routing-mark=to_Net passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=adsl_Spd_conn disabled=no new-routing-mark=to_adsl_Spd passthrough=yes
add action=accept chain=prerouting comment="" disabled=no dst-address=\
200.***.***.0/24 in-interface=Lan
add action=mark-connection chain=prerouting comment="" connection-state=new disabled=no dst-address-type=!local in-interface=Lan new-connection-mark=Net_conn passthrough=yes per-connection-classifier=both-addresses:3/0
add action=mark-connection chain=prerouting comment="" connection-state=new disabled=no dst-address-type=!local in-interface=Lan new-connection-mark=Net_conn passthrough=yes per-connection-classifier=both-addresses:3/1
add action=mark-connection chain=prerouting comment="" connection-state=new disabled=no dst-address-type=!local in-interface=Lan new-connection-mark=adsl_Spd_conn passthrough=yes per-connection-classifier=\
both-addresses:3/2
add action=mark-routing chain=prerouting comment="" connection-mark=Net_conn disabled=no in-interface=Lan new-routing-mark=to_Net passthrough=yes add action=mark-routing chain=prerouting comment="" connection-mark=adsl_Spd_conn disabled=no in-interface=Lan new-routing-mark=to_adsl_Spd passthrough=yes
/ ip route
add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
200.***.***.1 routing-mark=Rota0 scope=30 target-scope=10
add comment=Link1 disabled=yes distance=1 dst-address=0.0.0.0/0 gateway=\
adsl_Spd routing-mark=to_adsl_Spd
add check-gateway=ping comment=Link0 disabled=no distance=1 dst-address=\
0.0.0.0/0 gateway=200.189.206.1 scope=30 target-scope=10
0.0.0.0/0 gateway=200.***.***.1 routing-mark=to_Net scope=30 \
target-scope=10
add comment=Link1 disabled=no distance=2 dst-address=0.0.0.0/0 gateway=\
adsl_Spd
