Postado originalmente por
bouncer
squid erro
versao squid-2.5.STABLE1
da esse erro
root@rox:/usr/local/squid/etc# /usr/local/squid/sbin/squid -z
FATAL: getpwnam failed to find userid for effective user 'squid'
Squid Cache (Version 2.5.STABLE1): Terminated abnormally.
CPU Usage: 0.020 seconds = 0.020 user + 0.000 sys
Maximum Resident Size: 0 KB
Page faults with physical i/o: 245
Aborted
http_port 3128
cache_mem 100 MB
cache_swap_low 95
cache_swap_high 98
maximum_object_size 61440 KB
maximum_object_size_in_memory 4096 KB
cache_dir ufs /usr/local/squid/var/cache 100 16 256
cache_access_log /usr/local/squid/var/logs/access.log
cache_log /var/log/squid/cache.log
emulate_httpd_log on
log_fqdn on
ftp_passive on
refresh_pattern . 0 20% 4320
acl all src 0.0.0.0/0.0.0.0
acl nossa src 192.168.0.0/255.255.255.0
acl SSL_ports port 443 563
acl Safe_ports port 80 21 443 563 70 210 1025-65535
acl CONNECT method CONNECT
#acl blacklist url_regex "/etc/squid/blacklist"
#acl whitelist url_regex "/etc/squid/whitelist"
acl download urlpath_regex .exe$ .zip$ .arj$ .tar.gz$ .tgz$ .rpm$ .mp3$
http_access allow manager localhost all
http_access deny manager
http_access deny !Safe_ports
#http_access deny !blacklist
#http_access allow whitelist
http_access allow nossa
http_access deny all
icp_access allow all
miss_access allow all
cache_effective_user squid
cache_effective_group squid
httpd_accel_host virtual
httpd_accel_port 80
httpd_accel_with_proxy on
cache_mgr
[email protected]
visible_hostname proxy.zoioroxo.com.br
