olha aconsrho vc resetar seu modem e refazer o processo auqalquer coisa me add no msn [email protected]Fala ai galera to desde segunda-feira tentando fazer esse acesso remoto e nada já fiz inúmeras tentativas alias fiz todas e não deu certo ainda meu ultimo script foi este aki
# Set needed variables
:local username "claudinhohw"
:local password "********"
:local hostname "claudinhohw.ddns.info"
:global systemname [/system identity get name]
:if ($systemname = "Site1" ) do= {
:set hostname "yourdomain1.dyndns.org"
:if ($systemname = "Site2" ) do= {
:set hostname "yourdomain2.dyndns.org"
:if ($systemname = "Site3" ) do= {
:set hostname "yourdomain3.dyndns.org"
:global dyndnsForce
:global previousIP
# print some debug info
:log info ("UpdateDynDNS: username = $username")
:log info ("UpdateDynDNS: password = $password")
:log info ("UpdateDynDNS: hostname = $hostname")
:log info ("UpdateDynDNS: previousIP = $previousIP")
# get the current IP address from the internet (in case of double-nat)
/tool fetch mode=http address="checkip.dyndns.org" src-path="/" dst-path="/dyndns.checkip.html"
:local result [/file get dyndns.checkip.html contents]
# parse the current IP result
:local resultLen [:len $result]
:local startLoc [:find $result ": " -1]
:set startLoc ($startLoc + 2)
:local endLoc [:find $result "</body>" -1]
:local currentIP [ick $result $startLoc $endLoc]
:log info "UpdateDynDNS: currentIP = $currentIP"
# Remove the # on next line to force an update every single time - useful for debugging, but you could end up getting blacklisted by DynDNS!
#:set dyndnsForce true
# Determine if dyndns update is needed
# more dyndns updater request details available at DynDNS.com - Support -- Developers' Connection -- Update Specifications: Perform Update
:if (($currentIP != $previousIP) || ($dyndnsForce = true)) do={
:set dyndnsForce false
:set previousIP $currentIP
/tool fetch user=$username password=$password mode=http address="members.dyndns.org" src- path="/nic/update?hostname=$hostname&myip=$currentIP" dst-path="/dyndns.txt"
:local result [/file get dyndns.txt contents]
:log info ("UpdateDynDNS: Dyndns update needed")
:log info ("UpdateDynDNS: Dyndns Update Result: ".$result)
ut ("Dyndns Update Result: ".$result)
} else={
:log info ("UpdateDynDNS: No dyndns update needed")
Meu MK é V.3.25, já alterei até o modem mais não consegui nada ainda gostaria da ajuda de vcs meu modem e um Dlink 500b ADSL 2+, roteado tenho internet de 8mb nele....
obs: eu estou na mesma rede que estou testando o acesso remoto tem alguma coisa a ver?
Segue a imagem de como esta os erros...
http://thumbnails32.imagebam.com/926...a692604968.jpg http://thumbnails31.imagebam.com/926...c792604974.jpg http://thumbnails28.imagebam.com/926...6392604985.jpg http://thumbnails32.imagebam.com/926...c392604996.jpg
desde já agradeço ajuda de todos
Citação
