    Padrão Balanceamento 2 Link's ADSL (Velox)
    Boa tarde a todos, Tenho 02 link's ADSL (Velox) estou tentando fazer Balanceamento PCC mas não estou conseguindo.
    Preferencialmente gostaria de ultilizar os dois links em modo bridge fazendo com que o Mikrotik faça a discagem, porem estou disposto a tentar qualquer coisa pra fazer funcionar.
    Código :
    /interface ethernet
    /ip pool
    add name=default-dhcp ranges=192.168.88.10-192.168.88.254
    add name=Range1 ranges=10.5.50.2-10.5.50.254
    add name=Lanhouse ranges=192.168.254.10-192.168.254.254
    /ip dhcp-server
    add address-pool=Range1 authoritative=after-2sec-delay bootp-support=static \
        disabled=no interface=saida lease-time=3d name=Mdnet
    /ip hotspot
    add address-pool=Range1 disabled=no idle-timeout=none interface=saida \
        keepalive-timeout=none name=Mdnet profile=hsprof2
    /ip hotspot user profile
    add address-pool=Range1 advertise=yes advertise-interval=1s \
        advertise-timeout=never advertise-url=bloqueio.html idle-timeout=none \
        incoming-filter=hs-unauth keepalive-timeout=2m name=bloqueio \
        open-status-page=always outgoing-filter=hs-unauth-to session-timeout=5m \
        shared-users=1 status-autorefresh=1m transparent-proxy=yes
    /ppp profile
    set default change-tcp-mss=yes comment="" name=default only-one=default \
        use-compression=default use-encryption=default use-vj-compression=default
    add change-tcp-mss=yes comment="" dns-server=10.5.50.1 local-address=Lanhouse \
        name=SERVER-PPPoE only-one=default remote-address=Range1 use-compression=\
        no use-encryption=no use-vj-compression=no
    set default-encryption change-tcp-mss=yes comment="" name=default-encryption \
        only-one=default use-compression=default use-encryption=yes \
    /interface pppoe-client
    add ac-name="" add-default-route=yes allow=pap,chap,mschap1,mschap2 comment=\
        "" dial-on-demand=no disabled=no interface=ether1 max-mru=1480 max-mtu=\
        1480 mrru=disabled name=Velox password=XXXXXXXXXX profile=default \
        service-name="" use-peer-dns=no [EMAIL="[email protected]"][email protected][/EMAIL]
    /queue type
    set default kind=pfifo name=default pfifo-limit=50
    set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
    set wireless-default kind=sfq name=wireless-default sfq-allot=1514 \
        sfq-perturb=5
    set synchronous-default kind=red name=synchronous-default red-avg-packet=1000 \
        red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
    set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=\
        5
    add kind=pcq name=cache pcq-classifier=dst-address pcq-limit=50 pcq-rate=\
        2000000 pcq-total-limit=2000
    set default-small kind=pfifo name=default-small pfifo-limit=10
    /queue simple
    add burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s comment="" \
        direction=both disabled=no dst-address=0.0.0.0/0 interface=saida-pppoe \
        limit-at=0/0 max-limit=256k/2M name=LANHOUSE parent=none priority=8 \
        queue=default-small/default-small total-queue=default-small
    /queue tree
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=1M \
        max-limit=2M name=ThunderCache3 packet-mark=thunder3-packs parent=\
        global-out priority=8 queue=default
        max-limit=2M name=CACHE-FULL packet-mark=Cache-Packet parent=global-out \
        priority=8 queue=cache
        max-limit=2M name=MKAUTHWEB packet-mark=mkauth-packs parent=global-out \
    /ip address
    add address=10.5.50.1/24 broadcast=10.5.50.255 comment="" disabled=no \
        interface=saida network=10.5.50.0
    add address=192.168.254.2/24 broadcast=192.168.254.255 comment="" disabled=no \
        interface=ether1 network=192.168.254.0
    add address=172.31.255.1/30 broadcast=172.31.255.3 comment="" disabled=no \
        interface=thunder network=172.31.255.0
    add address=192.168.254.3/24 broadcast=192.168.254.255 comment="" disabled=no \
        interface=modem2 network=192.168.254.0
    /ip dhcp-server config
    set store-leases-disk=5m
    /ip dhcp-server lease
    add address=Lanhouse comment="" disabled=no mac-address=00:21:97:DA:EE:A3
    /ip dhcp-server network
    add address=10.5.50.0/24 comment="DHCP Rede" dns-server=\
        10.5.50.1,200.165.132.155 gateway=10.5.50.1 netmask=24
    add address=192.168.254.0/24 comment="" dns-server=\
        192.168.254.1,200.165.132.155 gateway=192.168.254.1 netmask=24
    /ip dns
    set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB \
        max-udp-packet-size=512 servers=192.168.254.254,200.165.132.155
    /ip firewall address-list
    add address=172.31.255.0/24 comment=ip_do_thunder disabled=no list=NO_CACHE
    /ip firewall connection tracking
    set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
        tcp-close-wait-timeout=10s tcp-established-timeout=1d \
        tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
        tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
        tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
    /ip firewall filter
    add action=passthrough chain=unused-hs-chain comment=\
        "place hotspot rules here" disabled=yes
    add action=accept chain=forward comment="" disabled=no src-address=\
        128.0.0.0/2
    /ip firewall mangle
    add action=mark-connection chain=forward comment="MK-AUTH FULL" content=\
        "MKAUTH: FILES" disabled=no new-connection-mark=mkauth-connection \
        passthrough=yes protocol=tcp
    add action=mark-packet chain=forward comment="" connection-mark=\
        mkauth-connection disabled=no new-packet-mark=mkauth-packs passthrough=\
        yes protocol=tcp
    /ip firewall nat
    add action=masquerade chain=srcnat comment="NAT para clientes" disabled=no \
        src-address=10.5.50.0/24
    add action=dst-nat chain=dstnat comment="AVISO MANUNTENO" disabled=yes \
        protocol=tcp src-address-list=0.0.0.0/0 src-port=80 to-addresses=\
        172.31.255.2 to-ports=89
    add action=dst-nat chain=pre-hotspot comment=Web-proxy disabled=no dst-port=\
        80 hotspot=auth in-interface=ether1 protocol=tcp src-address=10.5.50.0/24 \
        to-addresses=172.31.255.2 to-ports=3128
    add action=redirect chain=pre-hotspot comment="Paginas de status do hotspot" \
        disabled=no dst-address=10.5.50.1 dst-port=80 hotspot=auth protocol=tcp \
        to-ports=64873
    /ip firewall service-port
    set ftp disabled=no ports=21
    set tftp disabled=no ports=69
    set irc disabled=no ports=6667
    set h323 disabled=no
    set sip disabled=no ports=5060,5061
    set pptp disabled=no
    /ip hotspot ip-binding
    add comment="" disabled=no mac-address=20:CF:30:E0:77:2E type=bypassed
    /ip hotspot service-port
    /ip hotspot user
    add comment="" disabled=no name=teste password=teste profile=300Kbps server=\
        Mdnet
    add comment="dia 05" disabled=no name=clei password=clei profile=300Kbps \
        server=Mdnet
    /ip hotspot walled-garden
    add action=allow comment="" disabled=yes server=Mdnet src-address=192.168.1.1
    add action=allow comment="" disabled=yes dst-host=172.31.255.2 dst-port=80
    add action=allow comment="" disabled=yes dst-host=172.31.255.2 dst-port=85
    /ip neighbor discovery
    set ether1 discover=no
    set saida discover=yes
    set modem2 discover=yes
    set thunder discover=yes
    set saida-pppoe discover=yes
    set Velox discover=no
    /ip proxy
    set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 \
        cache-on-disk=no enabled=no max-cache-size=none max-client-connections=\
        600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 \
        parent-proxy-port=0 port=8080 serialize-connections=no src-address=\
        0.0.0.0
    /ppp secret
    add caller-id="" comment="" disabled=no limit-bytes-in=0 limit-bytes-out=0 \
        name=lanhouse password=123 profile=SERVER-PPPoE routes="" service=pppoe
    /queue interface
    set ether1 queue=ethernet-default
    set saida queue=ethernet-default
    set modem2 queue=ethernet-default
    set thunder queue=ethernet-default
    set saida-pppoe queue=ethernet-default
    set Velox queue=default
    /store
    add comment="" disabled=no disk=system name=web-proxy1 type=web-proxy
    /system clock
    set time-zone-name=manual
    /system clock manual
    set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
        "jan/01/1970 00:00:00" time-zone=-03:00
    /system identity
    set name=MikroTik
    /system ntp client
    set enabled=yes mode=unicast primary-ntp=209.81.9.7 secondary-ntp=\
        143.107.255.15
    /tool mac-server
    add disabled=no interface=saida
    add disabled=no interface=modem2
    add disabled=no interface=thunder
    add disabled=no interface=saida-pppoe
    /tool mac-server ping
    set enabled=yes
    http://i77.photobucket.com/albums/j8.../Minharede.jpghttp://i77.photobucket.com/albums/j8...Interfaces.jpg
    Avatar de shuttner
    Aug 2008
    Boa Vista - Roraima
    Padrão Re: Balanceamento 2 Link's ADSL (Velox)
    Já tentou verificar esse tópico
    https://under-linux.org/f227/pcc-loa...tricos-145512/
    e e como pretende fazer balanceamento por pcc
    recomendo usar um mk só pra isso, ainda mais que vc esta usando cache
    e não da pra fazer cache na mesma máquina que vc for fazer o balanceamento
    espero ter ajudado
    amigão cria teu script para o pcc usando esse programinha
    https://under-linux.org/f227/program...to-pcc-134749/
    se vai usar o balanceamento não configure cache nesse mk.
    o programinha é bem intuitivo, não terá maiores problemas em configurar o pcc.
    ps.: configure o pcc depois levante o restante dos serviços, fica mais fácil, menas coisas pra ti te preocupar...
    Obrigado amigos pelas dicas, gostaria de saber como ficaria minhas regras do Cache no Mk-Auth se eu apagar todas minhas configurações utilizar a regra gerada pelo programa que vc me passou?
    Adicionei a regra, porem percebi que os modens fizeram a discagem, porem a net só funcionou para conexão PPPoE, todos meus clientes que utilizam HOTSPOT's não conseguiram chegar a pagina de Login.
    Gostaria de saber também como farei pra que o Cache do MK-Auth funcione depois da regra nova (Utilizo Mk-Auth apenas para Cache).
    Alguém poderia Ajudar?
    Estou pagando um Link e não estou sabendo como adicionar a rede
    Avatar de shuttner
    Aug 2008
    Boa Vista - Roraima
    qual problema esta tendo?
    se puder add no msn
    [email protected]
