- DNS p/ rede interna
DNS p/ rede interna
Gente,
estou usando o Bind 9.2 no Red Hat 9, através dele consigo navegar na net normalmente. Ele esta resolvendo os nomes legais. Mas esta dando um problemas p/ resolver os nomes de dentro da minha rede.
Qdo estarto ele, levanta blz, mas dei uma olhada no /var/log/messages e lá me mostrou pq ele não resolve os nomes da rede interna.
/var/log/messages
named[5961]: listening on IPv4 interface lo, 127.0.0.1#53
named[5961]: listening on IPv4 interface eth0, 192.168.0.8#53
named[5961]: command channel listening on 127.0.0.1#953
named[5961]: zone 0.0.127.in-addr.arpa/IN: loaded serial 1997022700
named[5961]: zone 0.168.192.in-addr.arpa/IN: loaded serial 1997022700
named[5961]: intranet.zone:14: file does not end with newline
named[5961]: zone intranet/IN: loaded serial 2003090200
named[5961]: zone localhost/IN: loaded serial 42
named[5961]: running
named[5961]: zone intranet/IN: sending notifies (serial 2003090200)
file does not end with newline o q ele esta querendo dizer c/ isso?
Bem, vou passar tb meus arquivos de configuração do bind derrepente lá pode ter alguma coisa errada.
/etc/named.conf
// generated by named-bootconf.pl
options {
directory "/var/named";
* If there is a firewall between you and nameservers you want
* to talk to, you might need to uncomment the query-source
* directive below. Previous versions of BIND always asked
* questions using port 53, but BIND 8.1 uses an unprivileged
* port by default.
// query-source address * port 53;
// a caching only nameserver config
controls {
inet 127.0.0.1 allow { localhost; } keys { rndckey; };
zone "." IN {
type hint;
file "named.ca";
zone "localhost" IN {
type master;
file "localhost.zone";
allow-update { none; };
zone "0.0.127.in-addr.arpa" IN {
type master;
file "named.local";
zone "dominio" IN {
type master;
file "intranet.zone";
zone "0.168.192.in-addr.arpa" IN {
type master;
file "192.168.0.rev";
include "/etc/rndc.key";
/var/named/intranet
$TTL 86400
@ IN SOA dominio. root.dominio. (
2003090200 ; serial
28800 ; refresh
14400 ; retry
3600000 ; expire
86400 ) ; minimum
@ IN NS web.dominio.
web.dominio IN A 192.168.0.8
www.dominio IN A 192.168.0.8
/var/named/192.168.0.rev
$TTL 86400
1997022700 ; Serial
28800 ; Refresh
14400 ; Retry
3600000 ; Expire
86400 ) ; Minimum
@ IN NS dominio.
#8.0.168.192.in-addr.arpa IN PTR dominio.
1 IN PTR web.dominio.
2 IN PTR www.dominio.
Desculpe pelo tamanho do texto.
Valeu...
DNS p/ rede interna
Valeu pessoal consegui resolver.
Briagdão..
DNS p/ rede interna
Cara como faço para resolver nomes com a rede interna no bind
DNS p/ rede interna
Cara;
Não sei se estou falando muita merda mas acho que vc tem que editar o arquivo hosts que fica em /etc.
127.0.0.1 servidor localhost.localdomain localhost
192.168.0.3 micro-1
192.168.0.4 micro-2
E por ae vai..
DNS p/ rede interna
para resolver nomes vc pode cadastrar um dominio interno no seu DNS ..... isso só fica na sua rede interna .
DNS p/ rede interna
Olha na linha 14 do seu arquivo /var/named/intranet.zone se tem algo anormal...
Abraços!
DNS p/ rede interna
*sigh* eh soh dar uma enter no final do arquivo.... vergonha nao saber o que eh newline... tentem jogar o erro de voces na google, ou na proprio tradutor... newline.. linha nova.. etc etc
DNS p/ rede interna
no /etc/hosts
lá que tem que tá o IP , nome completo e apelido
10.3.1.100 maquina1.dominio.com.br maquina1
dê um
man 5 hosts
que lá mostra os exemplos.
