pessoal, depois que atualizei meu slackware 9.1 com o kernel 2.4.26 comecou dar essa mensagem na inicializacao...alguem me ajude a resolver
nsmod: /lib/modules/2.4.26/kernel/drivers/net/irda/via-ircc.o.gz: Hint: insmod errors can be caused by incorrect module parameters, including invalid IO or IRQ parameters.
You may find more information in syslog or the output from dmesg
insmod: /lib/modules/2.4.26/kernel/drivers/net/irda/via-ircc.o.gz: insmod /lib/modules/2.4.26/kernel/drivers/net/irda/via-ircc.o.gz failed
insmod: /lib/modules/2.4.26/kernel/drivers/net/irda/via-ircc.o.gz: insmod via-ircc failed
insmod: /lib/modules/2.4.26/kernel/drivers/net/irda/via-ircc.o.gz: init_module: No such device
insmod: /lib/modules/2.4.26/kernel/drivers/net/irda/via-ircc.o.gz: Hint: insmod errors can be caused by incorrect module parameters, including invalid IO or IRQ parameters.
  Citação
