Olá estou com problemas com o FreeRadius que ele não se conecta com o Mysql, veja o erro:
Código :Mon Jun 6 00:06:07 2011 : Info: rlm_sql (sql): Driver rlm_sql_mysql (module rlm_sql_mysql) loaded and linked Mon Jun 6 00:06:07 2011 : Info: rlm_sql (sql): Attempting to connect to root@localhost:/radius Mon Jun 6 00:06:07 2011 : Info: rlm_sql (sql): Attempting to connect rlm_sql_mysql #0 Mon Jun 6 00:06:07 2011 : Info: rlm_sql_mysql: Starting connect to MySQL server for #0 Mon Jun 6 00:06:07 2011 : Info: rlm_sql (sql): Connected new DB handle, #0 Mon Jun 6 00:06:07 2011 : Info: rlm_sql (sql): Attempting to connect rlm_sql_mysql #1 Mon Jun 6 00:06:07 2011 : Info: rlm_sql_mysql: Starting connect to MySQL server for #1 Mon Jun 6 00:06:07 2011 : Info: rlm_sql (sql): Connected new DB handle, #1 Mon Jun 6 00:06:07 2011 : Info: rlm_sql (sql): Attempting to connect rlm_sql_mysql #2 Mon Jun 6 00:06:07 2011 : Info: rlm_sql_mysql: Starting connect to MySQL server for #2 Mon Jun 6 00:06:07 2011 : Info: rlm_sql (sql): Connected new DB handle, #2 Mon Jun 6 00:06:07 2011 : Info: rlm_sql (sql): Attempting to connect rlm_sql_mysql #3 Mon Jun 6 00:06:07 2011 : Info: rlm_sql_mysql: Starting connect to MySQL server for #3 Mon Jun 6 00:06:07 2011 : Info: rlm_sql (sql): Connected new DB handle, #3 Mon Jun 6 00:06:07 2011 : Info: rlm_sql (sql): Attempting to connect rlm_sql_mysql #4 Mon Jun 6 00:06:07 2011 : Info: rlm_sql_mysql: Starting connect to MySQL server for #4 Mon Jun 6 00:06:07 2011 : Info: rlm_sql (sql): Connected new DB handle, #4
Estou usando a versão 2.1.9 do freeradius. Já criei o banco de dados já configurei, já tirei o comentario do SQL no radiusd.conf.. já li um monte de dúvida já fiz de tudo e ainda não consegui fazer.
Se alguém puder me ajudar eu agradeço.
Obrigado,
André.
Citação
