Estou tentando configurar o bind no fedora 17, porém estou enfrentando problema na resolução de endereço reverso.
seguem meus arquivos.
Meu /etc/named.conf:
// named.conf
// Provided by Red Hat bind package to configure the ISC BIND named(8) DNS
// server as a caching only nameserver (as a localhost DNS resolver only).
// See /usr/share/doc/bind*/sample/ for example named configuration files.
options {
listen-on port 53 { 127.0.0.1; 189.50.0.106; };
listen-on-v6 port 53 { ::1; };
directory "/var/named";
dump-file "/var/named/data/cache_dump.db";
statistics-file "/var/named/data/named_stats.txt";
memstatistics-file "/var/named/data/named_mem_stats.txt";
allow-query { localhost; 189.50.0.106; };
recursion yes;
dnssec-enable yes;
dnssec-validation yes;
dnssec-lookaside auto;
/* Path to ISC DLV key */
bindkeys-file "/etc/named.iscdlv.key";
managed-keys-directory "/var/named/dynamic";
zone "tcc.teste" IN {
type master;
file "tcc.teste";
zone "0.50.189.in-addr.arpa" IN {
type master;
file "189.50.0.db";
allow-update { none; };
logging {
channel default_debug {
file "data/named.run";
severity dynamic;
zone "." IN {
type hint;
file "named.ca";
include "/etc/named.rfc1912.zones";
include "/etc/named.root.key";
meu arquivo /var/named/tcc.teste:
; Zone file for dominio.com.br
$TTL 86400
@ IN SOA localhost.tcc.teste. localhost.tcc.teste. (
2012010100 ; serial
7200 ; refresh
1800 ; retry
1209600 ; expire
300 ) ; minimum
NS localhost
TXT "v=spf1 mx -all"
HINFO PC-Intel-2.4GHz "Linux 2.6"
A 189.50.0.106
localhost A 189.50.0.106
ifes A 189.50.0.106
www CNAME @
_ldap._tcp.tcc.teste. SRV 0 0 389 ifes.tcc.teste.
_kerberos._tcp.tcc.teste. SRV 0 0 88 ifes.tcc.teste.
ftp CNAME www
meu arquivo /var/named/189.50.0.db :
; Reverse zone file for dominio.com.br
$ORIGIN 0.50.189.in-addr.arpa.
$TTL 86400
@ IN SOA tcc.teste. localhost.tcc.teste. (
2012010100 ; serial
7200 ; refresh
1800 ; retry
1209600 ; expire
300 ) ; minimum
@ IN NS tcc.teste.
1 PTR tcc.teste
vejam os resultados da utilização do comando nslookup
nslookup ifes.tcc.teste
Server: 189.50.0.106
Address: 189.50.0.106#53
nslookup 189.50.0.106
** server can't find 106.0.50.189.in-addr.arpa.: NXDOMAIN
Os testes nslookup foram realizados na mesma máquina que está configurada o bind.
Alguém tem alguma dica sobre esse problema? pois eu sigo a risca os tutorais.
Att
Citação
