-  CPAN - MODULES
 CPAN - MODULES
							Galera,
Já estou ficando irritado
Estou tentando instalar o Amavis, e quando eu adiciono o comando
./configure --enable-postfix # Ele me diz que necessita de alguns modulos perl.
Então eu entro no CPAN shell para instalar os modulos e ele me apresenta um erro.
Antes o CPAN shell até começava a instalar, mas não encontrava uma rota para o host, mas agora ele nem começa a instalar da uma erro loco...
Antes do erro
cpan shell -- CPAN exploration and modules installation (v1.59_54)
ReadLine support enabled
CPAN: Storable loaded ok
CPAN: LWP::UserAgent loaded ok
Fetching with LWP:
  ftp://ftp.perl.org/pub/CPAN/authors/01mailrc.txt.gz
LWP failed with code[500] message[LWP:<IMG SRC="images/forum/icons/icon_razz.gif">rotocol::MyFTP: Timeout]
Fetching with Net::FTP:
Trying with "/usr/bin/lynx -source" to get
System call "/usr/bin/lynx -source ´ftp://ftp.perl.org/pub/CPAN/authors/....txt.gz´  > /root/.cpan/sources/authors/01mailrc.txt"
returned status 1 (wstat 256)
Warning: expected file [/root/.cpan/sources/authors/01mailrc.txt.gz] doesn´t exist
Trying with "/usr/bin/ncftpget" to get
System call "cd /root/.cpan/sources/authors && /usr/bin/ncftpget ´ftp://ftp.perl.org/pub/CPAN/authors/....txt.gz´ "
Trying with "/usr/bin/wget -O -" to get
# Depoi ele apresenta a seguinte informação
--12:42:29-- ftp://ftp.perl.org/pub/CPAN/authors/01mailrc.txt.gz
    (tentative: <IMG SRC="images/forum/icons/icon_cool.gif"> => `-`
Connecting to ftp.perl.orb[163.10.4.8]:21... ftp: connect: No route to host
Depois o erro
There seems to be running another CPAN process (1684). Contacting...
Other job not responding. Shall I overwrite the lockfile? (Y/N) [y]
Going to read /root/.cpan/Metadata
  Database was generated on
Warning: Cannot install Unix::Syslog, don´t know what it is.
Try the command
    i /Unix::Syslog/
to find objects with matching identifiers.
Lockfile removed.
O que eu faço..... <IMG SRC="images/forum/icons/icon_mad.gif">  <IMG SRC="images/forum/icons/icon_mad.gif">  <IMG SRC="images/forum/icons/icon_mad.gif">  <IMG SRC="images/forum/icons/icon_mad.gif">  <IMG SRC="images/forum/icons/icon_mad.gif">  <IMG SRC="images/forum/icons/icon_mad.gif">  <IMG SRC="images/forum/icons/icon_mad.gif">  <IMG SRC="images/forum/icons/icon_mad.gif">  <IMG SRC="images/forum/icons/icon_mad.gif">  <IMG SRC="images/forum/icons/icon_mad.gif">  <IMG SRC="images/forum/icons/icon_mad.gif">  <IMG SRC="images/forum/icons/icon_mad.gif">  <IMG SRC="images/forum/icons/icon_mad.gif">  <IMG SRC="images/forum/icons/icon_mad.gif">  <IMG SRC="images/forum/icons/icon_mad.gif">
 CPAN - MODULES
							Pelo que entendi falta um arquivo o 01mailrc.txt.gz que deveria estar em algum lugar (/root/.cpan/sources/authors/), ache esse arquivo pois el;e tenta fazer download dele 3 vezes e não consegue....
 CPAN - MODULES
							O que eu faço FUTUREMAX,
Eu baixei o arquivo pelo browser através deste endereço
o que fazer algora......
Cara que tristeza pra instalar este Amavis
 CPAN - MODULES
							Equeceram de mim.....
Me ajuda ae pessoal......
 CPAN - MODULES
							Calma, estou aki....
crie uma pasta para que fique assim o nome: /root/.cpan/sources/authors/
Jogue o arquivo dentro dela, se não funcionar, aí vai ficar difícil, oq eu nunca fiz isso estou apenas indo pelo erro....
 CPAN - MODULES
							Aiaiaiaiaiaiiiiii
Pessoal,
Alguém aqui tem o AMAVIS sobre POSTFIX......
me ajudemmmmm
 CPAN - MODULES
							Eu tentei criar a pasta e não deu certo.
 CPAN - MODULES
							Qual antivirus eu posso instalar para interagir junto ao meu MTA (POSTFIX).
Eu instalei o Uvscan.
Vcs conhecem algum mailscanner que não seja o AMAVIS e que seja facil configurar????????
 <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif"> <IMG SRC="images/forum/icons/icon27.gif">
