Alguem ae sabe fazer um servidor mikrotik pra servir Ovpn
pra maquinas windows como cliente?
de preferencia com usario e senha cadastrado nos secrets,
pra melhor gerencia, mas nao é obrifatorio..
O setup é bem simples, confira no link. Dúvidas só postar...
http://wiki.mikrotik.com/wiki/OpenVP...n_Step_by_Step
pois é... durante a semana eu tentei fazer baseado neste turorial e encontrei duas dificuldades...
gerar os certificados via cacert.org, uma vez q nao tenho nenhum dominio publicado na nic.br
e como nao tenho nem sei usar linux, mesmo q desse pra fazero certificado no cacert no formato
q a mikrotik aceita... entao gerei as chaves via easy-rsa, porem.. acho q nao estou sabendo talvez
configurar o openvpn no cliente windows;...
veja meus logs, no windows... cliente..
Código :Sun May 25 01:55:26 2014 OpenVPN 2.0.9 Win32-MinGW [SSL] [LZO] built on Oct 1 2006Sun May 25 01:55:26 2014 IMPORTANT: OpenVPN's default port number is now 1194, based on an official port number assignment by IANA. OpenVPN 2.0-beta16 and earlier used 5000 as the default port. Sun May 25 01:55:26 2014 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info. Sun May 25 01:55:26 2014 Control Channel MTU parms [ L:1543 D:140 EF:40 EB:0 ET:0 EL:0 ] Sun May 25 01:55:26 2014 Data Channel MTU parms [ L:1543 D:1450 EF:43 EB:4 ET:0 EL:0 ] Sun May 25 01:55:26 2014 Local Options hash (VER=V4): 'db02a8f8' Sun May 25 01:55:26 2014 Expected Remote Options hash (VER=V4): '7e068940' Sun May 25 01:55:26 2014 Attempting to establish TCP connection with 201.22.212.74:1194 Sun May 25 01:55:26 2014 TCP connection established with 201.22.212.74:1194 Sun May 25 01:55:26 2014 TCPv4_CLIENT link local: [undef] Sun May 25 01:55:26 2014 TCPv4_CLIENT link remote: 201.22.212.74:1194 Sun May 25 01:55:27 2014 TLS: Initial packet from 201.22.212.74:1194, sid=1609bdad b5ab8a69 Sun May 25 01:55:27 2014 VERIFY OK: depth=1, /C=BR/ST=RS/L=Brochier/O=Bar/[email protected] Sun May 25 01:55:27 2014 VERIFY OK: depth=0, /C=BR/ST=RS/O=Bar/CN=201.22.212.74/[email protected] Sun May 25 01:56:26 2014 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Sun May 25 01:56:26 2014 TLS Error: TLS handshake failed Sun May 25 01:56:26 2014 Fatal TLS error (check_tls_errors_co), restarting Sun May 25 01:56:26 2014 TCP/UDP: Closing socket Sun May 25 01:56:26 2014 SIGUSR1[soft,tls-error] received, process restarting Sun May 25 01:56:26 2014 Restart pause, 5 second(s)
agora veja meu log na mikrotik ovpnserver na outra cidade...
Código :01:57:36 ovpn,info TCP connection established from 186.251.59.50 01:57:38 ovpn,info : using encoding - BF-128-CBC/SHA1 01:58:41 ovpn,info TCP connection established from 186.251.59.50 01:58:43 ovpn,info : using encoding - BF-128-CBC/SHA1 01:59:46 ovpn,info TCP connection established from 186.251.59.50 01:59:48 ovpn,info : using encoding - BF-128-CBC/SHA1
abraço galeraaa!
Uma coisa muito importante quando se usa Openvpn, o servidor e os clientes precisam estar com o fuso-horário configurados. Caso não estejam configurados vai dar erro nos certificados pois não é possivel checar a validade do certificado ( no caso o certificado é considerado expirado ).
Para configurar o ntp ( atualizacao de hora/data via internet ) no mikrotik:
/system clock
set time-zone-name=America/Brasilia
/system ntp client
set enabled=yes mode=unicast primary-ntp=200.192.232.8 secondary-ntp=200.160.0.8
Olha, segundo este link:
http://wiki.mikrotik.com/wiki/OpenVPN#Windows
Para ter um cliente Windows, o openvpn no mikrotik tem que estar configurado no modo bridge.
Este tutorial:
Está no modo roteado, então acho que não vai conectar.
seguinte galera, achei o fiu da miada... vejam, o discador da open vpn vem ppré configurado com algumas coisas q o mikrotik nao aceita...
Currently unsupported OVPN feature:
- UDP mode
- LZO compression
- TLS authentication
- authentication without username/password
bom.,.. o primeiro e segundo problema eu matei, falta o terceiro e quarto...
desativar o tls... e fazer pedir usuario e senha,,,
caraca meu povo.. nao consigo fazer o open vpn pedir senha!!!
alguem sabe como fazer a maquina windows pedir usuario e senha do open vpn ?
Se existir no arquivo de configuracao da vpn a linha:
auth-user-pass auth.cfg
O usuario e a senha devem constar neste arquivo no formato:
usuario
senha
Se nao existir a linha, o cliente deve pedir o usuario e a senha.
só q nao tem nem a linha. ai eu criava a linha e o arquivo no endereço... e mesmo assim nao conseguia ler o arquivo
ai agora q vc me falou, me surgio a ideia de nao citar o arquivo, ai passo a pedir a senha certinho;; valeu! vo da uma reputaçao pra vc
