- programa para lan house
e ai andre agora sim
como asim compila o qt
vc pode me ensinar paso a passo ?
tar -zxvf qtXXXXX
cd qtXXXX
./configure
make
make install
mas vc jah deve ter o qt instalado... ele jah vem com o conectiva
tenta ai rpm -qi qt
aaa aki tem o qt em RPM caso vc num tenha ele instalado:
http://rpmfind.net/linux/rpm2html/search.php?query=qt
olha eu abaixei ele em tgz
[root@serv qt-x11-free-3.1.1]# ./configure
WARNING: /usr/lib/libGL.so.1 is threaded!
The Qt OpenGL module requires Qt to be configured with -thread.
This is the Qt/X11 Free Edition.
You are licensed to use this software under the terms of either
the Q Public License (QPL) or the GNU General Public License (GPL).
Type ´Q´ to view the Q Public License.
Type ´G´ to view the GNU General Public License.
Type ´yes´ to accept this license offer.
Type ´no´ to decline this license offer.
Do you accept the terms of either license?
ué digita yes e da enter!!!
agora instala o programa q o andrew te passou...
ué..... eu nem sei q programa eh esse <IMG SRC="images/forum/icons/icon_razz.gif">
ele eh .tar.gz tb?? se for eh do mesmo jeito q o qt...
eu descompactei ele
da uma olhada no install.txt dele
Getting the Code
you can get the code from
http://zeiberbude.sourceforge.net
Requirements
zeiberbude
- QT 3.x
zbdesk-x11
- XFree-devel
- libxml2
zbdesk-win32
- libxml2
(there is an installer available)
Compiling
zeiberbude
$ qmake zeiberbude.pro
$ make
$ make install
$ cp config.xml db.xml /usr/local/share/zeiberbude
$ chmod 666 /usr/local/share/zeiberbude/db.xml
install paths are
/usr/local/bin - the binary
/usr/local/share/zeiberbude - the translations and configuration files
/usr/local/info - the documentation
zbdesk-x11
$ cd clients/x11
$ make
$ make install
install paths are
zbdesk-win32
there is an installer for the windows platforms
in the directory clients/win
qual q dificuldade??? ai ta passo a passo oq deve ser feito... O qt vc jah instalou agora vai pra proxima fase
o 1c3 eu vou usar aquele scipt seu mesmo este programa eu naum to conseguindo instalar mesmo
OK qq coisa me chama no icq...
AndrewAmorimdaSilva
Você decompactou o programa....agora entra na pasta e usa.
ai compila....
testa ai..
