    Padrão Re: Configurar load balance
    tenho problemas com bradesco net empresa com balance src-address ,da erro de multiplos ips e fecha a conexao
  2. #42
    Rio de Janeiro - RJ
    me chame @jailtonnetlink pra ver seu ballance deve estar com erro
  3. #43
    Bom Pessoal intaum deixa eu colocar aqui o "NOVO" Load Ballance..como comentado ae pelo Acronimo a evolução do load também pode ser considerado como novo mediante a novos recusros que surgiram apartir do MUM 2010 (que também estive la )...
    Só gostaria que aqueles que fossem testar ( novatos ) não usassem apenas o copiar e colar que entendessem antes de colocar pra rodar .
    O exemplo a seguir é num cenário com 3 links ( podendo ser dedicado mais adsl oou adsl apenas):
    src-address=192.168.11.252 ( ip do concentrador depoois do Load )
    add action=mark-connection chain=prerouting comment=\
    "((((( LOAD BALLANCE PCC/HTTPS )))))" \
    connection-mark=no-mark in-interface=adsl_ether2 new-connection-mark=\
    ISP1_conn
    add action=mark-connection chain=prerouting connection-mark=no-mark \
    in-interface=Discador_2 new-connection-mark=ISP2_conn
    in-interface=Discador_3 new-connection-mark=ISP3_conn
    add action=mark-routing chain=output comment=\
    connection-mark=ISP1_conn new-routing-mark=ISP1_trafic passthrough=no
    add action=mark-routing chain=output connection-mark=ISP2_conn \
    new-routing-mark=ISP2_trafic passthrough=no
    add action=mark-routing chain=output connection-mark=ISP3_conn \
    new-routing-mark=ISP3_trafic passthrough=no
    add action=mark-routing chain=prerouting comment=\
    dst-address-type=!local in-interface=ether1-Link new-routing-mark=\
    ISP1_trafic passthrough=no per-connection-classifier=both-addresses:3/0
    add action=mark-routing chain=prerouting dst-address-type=!local \
    in-interface=ether1-Link new-routing-mark=ISP2_trafic passthrough=no \
    per-connection-classifier=both-addresses:3/1
    in-interface=ether1-Link new-routing-mark=ISP3_trafic passthrough=no \
    per-connection-classifier=both-addresses:3/2
    /ip firewall nat
    add action=masquerade chain=srcnat out-interface=Discador_1
    add action=masquerade chain=srcnat out-interface=Discador_2
    add action=masquerade chain=srcnat out-interface=Discador_3
    /ip route
    add distance=1 gateway=Discador_1 routing-mark=ISP1_trafic
    add distance=1 gateway=Discador_2 routing-mark=ISP2_trafic
    add distance=1 gateway=Discador_3 routing-mark=ISP3_trafic
    o segredo esta aqui :
    add distance=1 dst-address=172.16.0.0/24 gateway=192.168.11.252
    add distance=1 dst-address=192.168.1.0/24 gateway=192.168.11.252
    add distance=1 dst-address=192.168.200.0/24 gateway=192.168.11.252
    OBS: Os IPs 172.16.0.0/24 , 192.168.1.0/24 e 192.168.200.0/24 são usados na rede inclusive o thunder...dae so não usar o NAT no concentrador e dispensar a lista de endereços que sobrecarrega o link default .
    Isso ae espero ajudar
  4. #44
    Rio de Janeiro - RJ
    mas este balance tem muito mangle amigo
  5. #45
    Acronimo e Arthur
    Esse foi o melhor que cheguei ... e funciona redondinho
  6. #46
  7. #47
    também to precisando de ajuda pra fazer um balance quem puder ajuda agradeço Skype: [email protected]
  8. #48
    Paguei uma consultoria para um cara aqui do forum configurar esse modelo de balance com apenas tres linhas no mangle, ate agora so tive problemas, a rede esta amarrada, tenho problemas com series onlines, para resolver a amarração e series online tive que tirar o nat dos concentradores e usar src-address, o problema e que agora o cliente tem que reiniciar frequentemente a nano para a net voltar, estou esperando para ver se o cidadão que fez a configuração se manifesta para resolver meu problema ou devolver o dinheiro!
  9. #49
    Ceilandia, aproximadamente 150megas
  10. #50
    Citação Postado originalmente por wesleydialmeida Ver Post
    Essa questão de NAT no concentrador você resolve fácil, só fazer uma rota de retorno no seu balance apontando p/ o ip do concentrador, veja na resposta do nosso amigo rps67, ele dá a dica de como fazer.
    Já usando scr-address, aqui não deu certo, ficou uma lentidão tremenda. Depois de tanto pesquisar, testar e também contar c/ ajuda do nosso amigo @Arthur Bernardes, consegui fazer c/ pouquíssimas regras, apenas uma regra p/ cada link, e está perfeito, já testei tudo, desde videos online, jogos e acesso externo, DVR e tudo mais, tá perfeito aqui.
    Abraço.
  11. #51
    Rio de Janeiro - RJ
    Você deixar NAT somente no backbone é mais do que uma obrigação.
    Agora, "src-address" não resolve tudo, e firewall com somente 3 regras pra balanceamento é algo meio inusitado.
    Arthur este é o mesmo balance do qual lhe passei, e do qual sempre implantamos, inusitado?
  12. #52
    Rio de Janeiro - RJ
    Arthur me espere no face logo vou entrar
  13. #53
    Faz um tempo que tento acertar o balance sem nat na central...
    toda vez que tiro o nat fica saindo mais por um dos links.
    Ja desativei algumas regras no mangle do balance, ja acrescentei outras e nada.
    Alguma diga?
  14. #54
    Rio de Janeiro - RJ
    evite modinhas @Juniin use a mesma rb de balance
Nome:	         suelen.jpg
Visualizações:	313
Tamanho: 	327,7 KB
ID:      	58035 Clique na imagem para uma versão maior
Nome:	         ccr-marc.jpg
Visualizações:	275
Tamanho: 	172,9 KB
  15. #55
    Rio de Janeiro - RJ
    sim, mas se perguntar 10 profissionais em rede (que estudaram e entendem mesmo sobre rede) 9 irão falar sobre modinha, balance é algo tão simples que tem mais de 20 formas, todas são corretas, e todas são erradas se for olhar bem, existem um padrão comum simples e eficaz, usar modinhas é simplesmente mais um ponto de falha, use algo simples, hoje mesmo fizmeos em ecmp pois no cenario do cliente so daria desta forma
  16. #56
    /ip firewall mangle
    add action=mark-routing chain=prerouting comment="Cliente pelo mesmo link" \
    connection-mark=ISP1_conn in-interface=Local new-routing-mark=ISP1
    add action=mark-routing chain=prerouting connection-mark=ISP1_conn \
    in-interface=Local new-routing-mark=ISP2
    add chain=prerouting comment=\
    dst-address=192.168.88.0/30 src-address=192.168.88.0/30
    connection-mark=no-mark in-interface=pppoe-out1 new-connection-mark=\
    ISP1_conn
    in-interface=pppoe-out2 new-connection-mark=ISP2_conn
    add action=jump chain=prerouting comment=\
    connection-mark=no-mark in-interface=Local jump-target=Policy_Router
    add action=jump chain=prerouting dst-port=443 in-interface=Local jump-target=\
    Policy_Router protocol=tcp
    connection-mark=ISP1_conn new-routing-mark=ISP1_Trafic src-address=\
    192.168.88.0/30
    add action=mark-routing chain=prerouting connection-mark=ISP2_conn \
    new-routing-mark=ISP2_Trafic src-address=192.168.88.0/30
    add action=mark-connection chain=Policy_Router comment=\
    dst-address-type=!local new-connection-mark=ISP1_conn \
    per-connection-classifier=both-addresses:2/0
    add action=mark-connection chain=Policy_Router dst-address-type=!local \
    new-connection-mark=ISP2_conn per-connection-classifier=\
    both-addresses:2/1
    ja desativei algumas e ativei novamente e, nesse momento,
    as regras em negrito estao desativadas..
    valeu por responder
  17. #57
    Rio de Janeiro - RJ
    querido amigo @Arthur Bernardes me informe uma coisa simples pois vc esta pensando em pequena escala amigo
    se for pensar algo como vc ta citando primeiro não irá pensar em balance convenhamos, segundo, fazer um balance com ospf é sim modinha cara sei que vai defender esta "modinha" pois esta lucrando com isso
    mas vamos la,
    primeiro vc tem uma rb, concentrando seus clientes,
    cenario balance na mesma rb que concentra seus clientes, +ospf entre as rbs de torres pode se usar vlan (que recomendo) ou mpls/vpls) mas sem usar regrinhas de forum e sim entender realmente a camada osi, e isso é "foder" como o amigo disse? entçao esta precisndo estudar, pegar um cenario de grande escala,
    sou contra nat na rede sim, totalmente contra, então aprenda ler o cenario cada um é cada um,
    então colocar uma rb pra balance fazer ospf é o correto?
    desculpe amigo, mas ainda tem muito que aprender de rede, encerro por aki, não irei discutir estas "modinhas" de balance sem nat, balance sem mangle, balance sem link não
    vai tentar fazer o agregation no cisco, e vai entender de forma facil o que é realmente um balance
  18. #58
    Rio de Janeiro - RJ
    Obs citou que modinha é fazer nat? qunado começa a cursar rede de computadores, aprende que nat é o conceito padrão de rede para economia de ips, a decadas, então nao julgue modinha meu amigo, aprendeu ospf ano passado né?
  19. #59
    Rio de Janeiro - RJ
    Tirar AS é obrigatoriedade de todo provedor serio, e que tem condições de tirar (o que incentivo a todos) nao cuspo agora ficar falando que o correto é uma rb com balance +ospf para outra rb, e nat somente em uma é a forma grotesca de falar (não sei porra alguma de camada OSI muito menos de firewall) simples aprendeu algo e quer colocar pra vender
    pcc meu amigo é simples divisão de peso, e agregação de frames, vc pode colocar no seu concentrador onde autentica clientes, e nele sim criar um ospf evitando o duplo nat, algo simples muito simples nada complexo,
    colocar complexidade em rede para vender o produto pra mim tem um nome onde todos falam "FALTA DE ETICA" profissionais a anos no ramo, mestres, instrutores falam a mesma coisa, procure conversar com o Adilson Florentino onde tive o prazer de trabalhar junto quando ele ministrava roteaemnto avançado e CCNA CCNP Linux, algo simples faz a diferença, algo complexo causa dor de cabeça
  20. #60
    Acronimo, nao uso ospf porque tanto o pc que autentica os clientes quanto a rb que faz o balance estao no mesmo lugar, lugar fisico e, por tanto, nao vi necessidade de ospf... fiz apenas uma regra para apontar o ip dos clientes pra rb do balance. Seria roteamento estatico!?
    desse jeito a navegaçao funciona mesmo sem o nat na central, mas meu problema é que fica usando mais um dos links do balance sempre que desativo o nat na central, entao fica nat nos dois e, lendo o post, vi que nao é legal.
    Desativei as regras de output tambem, nao percebi mudança no desempenho, entao deixei sem elas...
    alguma diga?
