Oi pessoal preciso de ajuda sou leigo no assunto criei aqui um servidor para webmail com base em tuto da internet, porem nao consigo enviar ou receber email interno e externo, ja fiz registro de dominio no registro.br n'ao sei se fiz o MX da forma certa poderiam ent'ao me orientar sobre como resolvo os problemas e de que maneira registro no registro.br meu webmail eu pretendo usar o outlook.
erro quando envio para meu servidor o retorno do hotmail e
This is an automatically generated Delivery Status Notification.
THIS IS A WARNING MESSAGE ONLY.
YOU DO NOT NEED TO RESEND YOUR MESSAGE.
Delivery to the following recipients has been delayed.
[email protected]
e o erro quando tendo enviar do servidor
This is the mail system at host SERVIDOR.yeshua-trans.com.br.
I'm sorry to have to inform you that your message could not
be delivered to one or more recipients. It's attached below.
For further assistance, please send mail to postmaster.
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
The mail system
<[email protected]>: host 127.0.0.1[127.0.0.1] said: 554 5.4.0
id=05730-04-11 - Rejected by next-hop MTA on relaying, from
MTA(smtp:[127.0.0.1]:10025): 554 5.4.0 Error: too many hops (in reply to
end of DATA command)
meu main.cf
# See /usr/share/postfix/main.cf.dist for a commented, more complete version
# Debian specific: Specifying a file name will cause the first
# line of that file to be used as the name. The Debian default
# is /etc/mailname.
#myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
biff = no
# appending .domain is the MUA's job.
append_dot_mydomain = no
# Uncomment the next line to generate "delayed mail" warnings
#delay_warning_time = 4h
readme_directory = no
# TLS parameters
smtpd_tls_cert_file=/etc/ssl/certs/ssl-cert-snakeoil.pem
smtpd_tls_key_file=/etc/ssl/private/ssl-cert-snakeoil.key
smtpd_use_tls=yes
smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
# See /usr/share/doc/postfix/TLS_README.gz in the postfix-doc package for
# information on enabling SSL in the smtp client.
myhostname = SERVIDOR.yeshua-trans.com.br
mydomain = yeshua-trans.com.br
alias_maps = hash:/etc/aliases
alias_database = hash:/etc/aliases
mydestination = SERVIDOR.yeshua-trans.com.br, yeshua-trans.com.br, localhos$
relayhost =
mynetworks = 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128
home_mailbox = Maildir/
ailbox_command =
recipient_delimiter = +
inet_interfaces = all
inet_protocols = all
message_size_limit = 20000000
mailbox_size_limit = 0
#Configuraçõs sasl
smtpd_sasl_local_domain =
smtpd_sasl_auth_enable = yes
smtpd_sasl_security_options = noanonymous
broken_sasl_auth_clients = yes
smtpd_recipient_restrictions = permit_sasl_authenticated, permit_mynetworks$
smtpd_tls_auth_only = no
smtp_use_tls = yes
smtp_tls_note_starttls_offer = yes
smtpd_tls_CAfile = /etc/postfix/ssl/cacert.pem
smtpd_tls_loglevel = 1
smtpd_tls_received_header = yes
smtpd_tls_session_cache_timeout = 3600s
smtpd_tls_cert_file = /etc/postfix/ssl/smtpd.crt
smtpd_tls_key_file = /etc/postfix/ssl/smtpd.key
smtpd_tls_session_cache_database = btree:${queue_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${queue_directory}/smtp_scache
tls_random_source = dev:/dev/urandom
content_filter = smtp-amavis:[127.0.0.1]:10024
obrigado pela forca gente.
