ola a todos
peguei o cd 1 e 2 do slackware 10 e resolvi instalar so pra ver como é o slack, ele vem com o x.org, nao sei muita coisa sobre o x.org, so tinha usado o xfree, o pau que da é que ele nao entra em modo grafico. a tela fica distorcida e o arquivo Xorg.0.log esta desta forma:
_XSERVTransSocketOpenCOTSServer: Unable to open socket for inet6
_XSERVTransOpen: transport open failed for inet6/darkstar:0
_XSERVTransMakeAllCOTSServerListeners: failed to open listener for inet6
Release Date: 18 December 2003
X Protocol Version 11, Revision 0, Release 6.7
Build Operating System: Linux 2.4.26 i686 [ELF]
Current Operating System: Linux darkstar 2.4.26 #6 Mon Jun 14 19:07:27 PDT 2004 i586
Build Date: 05 June 2004
Before reporting problems, check http://wiki.X.Org
to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Aug 6 21:35:36 2004
(==) Using config file: "/etc/X11/xorg.conf"
Parse error on line 1 of section (null) in file /etc/X11/xorg.conf
"PNG" is not a valid keyword in this section.
(EE) Problem parsing the config file
(EE) Error parsing the config file
Fatal server error:
no screens found
Please consult the The X.Org Foundation support
at http://wiki.X.Org
for help.
Please also check the log file at "/var/log/Xorg.0.log" for additional information.
tenho uma placa trdent tgui 9440, no xfree bastava editar o arquivo XF86Config-4 e trocar o driver para vesa que funcionava, como fazer com o xorg?
valeu
Citação
