# jan/06/1970 09:39:03 by RouterOS 6.15# software id = QM22-4ENJ
/interface ethernet
set [ find default-name=ether1 ] name=ISP1
set [ find default-name=ether2 ] name=ISP2
set [ find default-name=ether5 ] name="Rede Local"
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m \
    mac-cookie-timeout=3d
/ip pool
add name=dhcp_pool1 ranges=192.168.10.2
/ip dhcp-server
add address-pool=dhcp_pool1 disabled=no interface="Rede Local" name=dhcp1
/port
set 0 name=serial0
/ip address
add address=192.168.1.2/30 interface=ISP1 network=192.168.1.0
add address=192.168.2.2/30 interface=ISP2 network=192.168.2.0
add address=192.168.10.1/30 interface="Rede Local" network=192.168.10.0
/ip dhcp-server network
add address=192.168.10.0/30 gateway=192.168.10.1
/ip dns
set cache-size=20480KiB servers=8.8.8.8,8.8.4.4
/ip firewall mangle
add chain=prerouting comment=\
    dst-address=192.168.88.0/30 src-address=192.168.88.0/30
add chain=prerouting dst-address=192.168.1.0/30 src-address=192.168.88.0/30
add chain=prerouting dst-address=192.168.2.0/30 src-address=192.168.88.0/30
add action=mark-connection chain=prerouting comment=\
    connection-mark=no-mark in-interface=ISP1 new-connection-mark=ISP1_conn
add action=mark-connection chain=prerouting connection-mark=no-mark \
    in-interface=ISP2 new-connection-mark=ISP2_conn
add action=jump chain=prerouting comment=\
    connection-mark=no-mark in-interface="Rede Local" jump-target=\
    policy_router
add action=mark-routing chain=prerouting comment=\
    connection-mark=ISP1_conn new-routing-mark=ISP1_trafic src-address=\
    192.168.10.0/30
add action=mark-routing chain=prerouting connection-mark=ISP2_conn \
    new-routing-mark=ISP2_trafic src-address=192.168.10.0/30
add action=mark-routing chain=output comment=\
add action=mark-routing chain=output connection-mark=ISP2_conn \
add action=mark-connection chain=policy_router comment=\
    dst-address-type=!local new-connection-mark=ISP1_conn \
    per-connection-classifier=both-addresses-and-ports:2/0
add action=mark-connection chain=policy_router dst-address-type=!local \
    new-connection-mark=ISP2_conn per-connection-classifier=\
    both-addresses-and-ports:2/1
/ip firewall nat
add action=masquerade chain=srcnat out-interface=ISP1
add action=masquerade chain=srcnat out-interface=ISP2 to-addresses=0.0.0.0
/ip route
add distance=1 gateway=192.168.1.1 routing-mark=ISP1_trafic
add distance=1 gateway=192.168.2.1 routing-mark=ISP2_trafic
add distance=2 gateway=192.168.1.1
add distance=3 gateway=192.168.2.1
/ip upnp
set allow-disable-external-interface=no
/system identity
set name=""
/tool graphing interface
add
/tool graphing queue
add
/tool graphing resource
add
