Senhores,
pelo amor de deusss..me ajudem no redirecionamento do Thunder? nao vai de jeito nenhum e ja refiz a configuracao toda do zero umas 500 vezes!!
# jan/31/2016 13:39:45 by RouterOS 5.26
# software id = AAHS-JG8K
/interface ethernet
set 0 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600 mac-address=D4:CA:6D:46:9C:41 mtu=1500 name="Interface Off" speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:46:9C:42 master-port=none mtu=1500 name="LAN 1 - porta 2" speed=1Gbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:46:9C:43 master-port=none mtu=1500 name="LAN 2 - porta 3" speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment="========================================= ===============UP========Down=========" disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:46:9C:44 master-port=none mtu=\
1500 name="Link 15 MB - porta 4" speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:46:9C:45 master-port=none mtu=1500 name="THUNDER - porta 5" speed=100Mbps
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap name=default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no use-radius=no
add dns-name="" hotspot-address=192.168.100.1 html-directory=hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap name=hsprof1 rate-limit="" smtp-server=0.0.0.0 split-user-domain=no use-radius=no
/ip pool
add name=dhcp_pool2 ranges=192.168.200.2-192.168.200.254
add name=hs-pool-2 ranges=192.168.100.2-192.168.100.254
/ip dhcp-server
add address-pool=dhcp_pool2 authoritative=after-2sec-delay bootp-support=static disabled=no interface="LAN 2 - porta 3" lease-time=3d name=dhcp1
/ip hotspot
add address-pool=hs-pool-2 addresses-per-mac=2 disabled=no idle-timeout=5m interface="LAN 1 - porta 2" keepalive-timeout=none name=hotspot1 profile=hsprof1
/queue tree
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=100M max-limit=100M name=THUNDER packet-mark=thunder_packs parent=global-out priority=8 queue=default
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no ignore-as-path-len=no name=default out-filter="" redistribute-connected=no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no redistribute-static=no router-id=0.0.0.0 \
routing-table=""
/ip address
add address=172.1.1.1/24 comment=THUNDER disabled=no interface="THUNDER - porta 5" network=172.1.1.0
add address=192.168.200.1/24 comment="DHCP wifi" disabled=no interface="LAN 2 - porta 3" network=192.168.200.0
add address=192.168.100.1/24 comment="hotspot network" disabled=no interface="LAN 1 - porta 2" network=192.168.100.0
/ip dhcp-client
add add-default-route=yes default-route-distance=0 disabled=no interface="Link 15 MB - porta 4" use-peer-dns=yes use-peer-ntp=yes
/ip dhcp-server network
add address=192.168.100.0/24 comment="hotspot network" dhcp-option="" dns-server="" gateway=192.168.100.1 ntp-server="" wins-server=""
add address=192.168.200.0/24 dhcp-option="" dns-server=8.8.8.8,8.8.4.4 gateway=192.168.200.1 ntp-server="" wins-server=""
/ip dns
set allow-remote-requests=yes cache-max-ttl=1w cache-size=4096KiB max-udp-packet-size=4096 servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.88.1 disabled=no name=router ttl=1d
/ip firewall address-list
add address=172.1.1.2 comment="Cliente Fora do Cache" disabled=no list=Cliente_fora_do_cache
add address=172.1.1.2 comment="Site Fora do Cache" disabled=no list=Site_fora_do_cache
/ip firewall filter
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
add action=accept chain=input comment="default configuration" disabled=no protocol=icmp
add action=accept chain=input comment="default configuration" connection-state=established disabled=no
add action=accept chain=input comment="default configuration" connection-state=related disabled=no
add action=drop chain=input comment="default configuration" disabled=no in-interface="Interface Off"
add action=accept chain=forward comment="default configuration" connection-state=established disabled=no
add action=accept chain=forward comment="default configuration" connection-state=related disabled=no
add action=drop chain=forward comment="default configuration" connection-state=invalid disabled=no
/ip firewall mangle
add action=mark-routing chain=prerouting comment=THUNDER disabled=yes dst-address-list=!Site_fora_do_cache dst-port=80 in-interface="!THUNDER - porta 5" new-routing-mark=to_cache passthrough=yes protocol=tcp src-address=192.168.0.0/16 \
src-address-list=!Cliente_fora_do_cache
add action=mark-packet chain=postrouting disabled=no dscp=18 new-packet-mark=thunder_packs passthrough=yes
add action=mark-routing chain=prerouting disabled=yes dst-address-list=!Site_fora_do_cache dst-port=80 in-interface="!THUNDER - porta 5" new-routing-mark=to_cache passthrough=yes protocol=tcp src-address=192.168.200.0/24 src-address-list=\
add action=mark-connection chain=prerouting disabled=yes dscp=17 dst-port=80 in-interface="THUNDER - porta 5" new-connection-mark=thunder_out passthrough=yes protocol=tcp src-address=192.168.200.0/24
add action=mark-routing chain=prerouting connection-mark=thunder_out disabled=yes in-interface="!THUNDER - porta 5" new-routing-mark=to_cache passthrough=yes protocol=tcp src-port=80
/ip firewall nat
add action=masquerade chain=srcnat comment="default configuration" disabled=yes out-interface="Interface Off" to-addresses=0.0.0.0
add action=dst-nat chain=dstnat comment=SSH_Thunder disabled=no dst-port=2200 protocol=tcp to-addresses=172.1.1.2 to-ports=22
add action=dst-nat chain=dstnat comment=WEBADMIN_Thunder disabled=no dst-port=82 protocol=tcp to-addresses=172.1.1.2 to-ports=82
add action=masquerade chain=srcnat comment="Nat Thunder" disabled=yes out-interface="Link 15 MB - porta 4" src-address=172.1.1.0/24
add action=masquerade chain=srcnat disabled=yes out-interface="Link 15 MB - porta 4" src-address=192.168.88.0/24
add action=masquerade chain=srcnat disabled=no out-interface="Link 15 MB - porta 4" src-address=192.168.200.0/24
add action=masquerade chain=srcnat comment="masquerade hotspot network" disabled=no out-interface="Link 15 MB - porta 4" src-address=192.168.100.0/24
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 cache-on-disk=no enabled=no max-cache-size=unlimited max-client-connections=600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 parent-proxy-port=0 port=8080 \
serialize-connections=no src-address=0.0.0.0
/ip route
add comment=ROTA-THUNDER disabled=no distance=1 dst-address=0.0.0.0/0 gateway=172.1.1.2 routing-mark=to_cache scope=30 target-scope=10
No Thunder cache:
Proxy Networks:
192.168.0.0/16
172.1.1.0/24
DNS Servers:
192.168.1.131ms1.049ms
192.168.100.16ms0.338ms
192.168.200.16ms0.404ms
Citação
