Página 3 de 10 PrimeiroPrimeiro 12345678 ... ÚltimoÚltimo
    Padrão Re: PPoE - QoS Dinâmico e Individual
    Citação Postado originalmente por PabloDelfino Ver Post
    O Codigo pronto ficou assim:
    Código :
    :foreach i in=[/queue simple find where name="<pppoe-$user>"] do={
        :local qName [/queue simple get $i name];
        :local rLimit [/queue simple get $i max-limit];
        :local indexExplod [:find $rLimit "/"];
        :local lenth [:len $rLimit];
        :local rl [:pick $rLimit ($indexExplod + 1) ($lenth - 1)];
        :local rlUnity [:pick $rLimit ($lenth - 1) $lenth];
        :local burstl [/queue simple get $i burst-limit];
        :local indexExplod [:find $burstl "/"];
        :local lenth [:len $burstl];
        :local bl [:pick $burstl ($indexExplod + 1) ($lenth - 1)];
        :local blUnity [:pick $burstl ($lenth - 1) $lenth];
        :local burstt [/queue simple get $i burst-time];
        :local indexExplod [:find $burstt "/"];
        :local lenth [:len $burstt];
        :local bt [:pick $burstt ($indexExplod + 1) ($lenth - 1)];
        :local indexExplod [:find $bt "m"];
        :local lenth [:len $bt];
        :local bt0 [:pick $bt 0];
        :local bt1 [:pick $bt ($indexExplod + 1) $lenth];
        :local burstth [/queue simple get $i burst-threshold];
        :local indexExplod [:find $burstth "/"];
        :local lenth [:len $burstth];
        :local bth [:pick $burstth ($indexExplod + 1) ($lenth - 1)];
        :local bthUnity [:pick $burstth ($lenth - 1) $lenth];
        :local c512k [($rl * 55 / 100)];
        :local c5M [($rl * 25 / 100)];
        :local c20M [($rl * 20 / 100)];
        :local c50M [($rl * 15 / 100)];
        :local cInf [($rl * 10 / 100)];
        :local cBt [(($bt0 * 60) + $bt1)];
            :log warning "=== Inicio Script ===";
        :if ([:len $bl] != 0) do={
            :log warning "QoS === $qName";
            :log warning "Com Burst";
            :log warning "Max Limit === $rl $rlUnity";
            :log warning "Burst Limit === $bl $blUnity";
            :log warning "Burst Thr === $bth $bthUnity";
            :log warning "Burst Time=== $cBt";
            :log warning "=== Fim Script ===";
       else={
            :log warning "Sem Burst";
            /queue tree add name="QoS_$qName" parent="$interface" queue="default" max-limit="$($rl)$rlUnity" bucket-size=0.20;
            /queue tree add name="2-512k_$qName" parent="QoS_$qName" packet-mark="QoS-Andriopj_512K" queue="default" priority="2" limit-at="$($c512k)$rlUnity" max-limit="$($rl)$rlUnity";
            /queue tree add name="4-5M_$qName" parent="QoS_$qName" packet-mark="QoS-Andriopj_5M" queue="default" priority="4" limit-at="$($c5M)$rlUnity" max-limit="$($rl)$rlUnity";
            /queue tree add name="6-20M_$qName" parent="QoS_$qName" packet-mark="QoS-Andriopj_20M" queue="default" priority="6" limit-at="$($c20M)$rlUnity" max-limit="$($rl)$rlUnity";
            /queue tree add name="7-50M_$qName" parent="QoS_$qName" packet-mark="QoS-Andriopj_50M" queue="default" priority="7" limit-at="$($c50M)$rlUnity" max-limit="$($rl)$rlUnity";
            /queue tree add name="8-Inf_$qName" parent="QoS_$qName" packet-mark="QoS-Andriopj_Infinity" queue="default" priority="8" limit-at="$($cInf)$rlUnity" max-limit="$($rl)$rlUnity";
    Nada aconteceu!
    Apenas autenticou e não emitiu nenhum Log. e nao adicionou nenhuma Queue Tree
    muito estranho não estar funcionando ai contigo.
    Qual a versão do seu Mikrotik? se for RB, qual a versão de firmware tbm?
    É possível fazer acesso remoto ai pelo team viewer ou algum programa semelhante??
  2. #42
    Citação Postado originalmente por AndrioPJ Ver Post
    Achei o Problema amigo,
    Estava aqui: "bucket-size=0.20" na hora de adicionar a Queue-tree
    Meu MK estava detectando erro
    Removi ele e funcionou, qual problema deixar sem?
    Notei também que não adicionou Burst Limit
    Última edição por PabloDelfino; 17-05-2017 às 10:35.
  3. #43
    Andrio, parabens pela postagem, como já disseram, de alto nível.
    Fiz varios testes aqui em um cenario com cerca de 550 pppoe, e constatei o seguinte:
    Funciona muito bem e pode sim ser bem melhorado a partir desta ideia, a exemplo, fragmentacões de torrent e outros P2P em porta 443 não são vistas pelo filtro P2P nem pelo script (que não é o papel dele é lógico) pois ja vem fragmentado, teríamos que descobrir uma forma de usar um DIP (Deep Inspection Pack) em mikrotik pra fazer isso mas até agora não vi como pois esta funcionalidade esta como uma feature do iptables, mas se for nessa linha beira a perfeição.
    No mais, só elogios pela disposição do feito.
    Abraços!!
  4. #44
    AndrioPJ, fiquei com uma duvida aqui, a soma desses dados não teria que dar 100%?
  5. #45
    Citação Postado originalmente por eberty Ver Post
    a principio sim.
    Mas observei que nem sempre todas as regras estão sendo usadas simultaneamente.
    na grande maioria tem 2, no máximo 3 regras sendo usadas.
    Por isso, pensei em garantir um minimo maior.
  6. #46
    Sobre o bucket-size, não tem nenhum problema em exclui-lo.
    por padrão, quando não é mencionado, ele já usa o valor de 0.10.
    Como você já achou o problema, tenta copiar/usar o script que está na pagina inicial e remove apenas o bucket-size.
    ele deve adicionar as regras de burst-limite no geral, e na 1 regra de QoS (para pacotes pequenos).
  7. #47
    Citação Postado originalmente por leandromidia Ver Post
    Olá a todos, a principio, gostaria de agradecer e muito ao AndrioPJ, esse Qos dinâmico transformou a experiência dos meus usuários, o pessoal ligou perguntando o que aconteceu... e realmente ao entrar em um site que o pessoal usa muito eu me deparei com as aberturas muito mais rápidas das janelas de exibição, coisa impressionante!!! Como pode algumas regras mudarem tanto a rede... mais uma vez, OBRIGADO!!!
    Opa, valeu grande.
  8. #48
    Ja fis isso @AndrioPJ
    Mas o Burst Limit realmente não vai.
    Será a versão do Meu MK que esta causando isso? Ros 6.33.3 - Firm. 3.10
  9. #49
    o do burst possui o bucket-size tbm, vc retirou ele?
    de qualquer forma, realmente pode ser versão da RB.
    Aqui eu uso a versão 6.37.5 Bugfix only
  10. #50
    a principio sim.
    Obrigado pela resposta.
  11. #51
    Realmente, o erro estava relacionado a versão do mikrotik, atualizei para 6.37 e a regra com bucket-cize passou a funcionar
    Porem o Burst-limit não funciona!
  12. #52
    Outra falha @AndrioPJ
    O script Esta adicionando parent errado!
    Fez uma confusão aqui,Telefone começou a tocar reclamando de lentidão fui olhar e... olha no print.
Nome:	         erro qos.JPG
Visualizações:	694
Tamanho: 	273,9 KB
    Última edição por PabloDelfino; 20-05-2017 às 19:47.
  13. #53
    PPPoE ou PPoE ?
    Do resto ótima contribuição [emoji106]
  14. #54
Nome:	         erro qos.JPG
Visualizações:	694
Tamanho: 	273,9 KB
    estranho...
    Aconteceu o mesmo com mais alguém?
  15. #55
    Não adiciona a regra com Burst ou não libera o Burst?
  16. #56
    estranho...
    Será que ele esta tratando de certa forma como global?
    Se criar uma variável pro nome das variáveis exemplo adicionando os segundos aos nomes?
    segs = 23.312
    user$segs = "Joao"
    blabla usuario=$user23.312
    Algumas linguagens de programação permitem não sei se da certo no mikrotik
  17. #57
    Citação Postado originalmente por eduardomazolini Ver Post
    segs = 23.312
    user$segs = "Joao"
    pois é... n deveria.
    pois cada vez que ele roda, ele atualiza a variavel.
  18. #58
    Boa tarde @AndrioPJ
    Ele não Adiciona a Queue Tree com Burst!
    Adiciona Apenas LImit At e Max LImit , ta certo isso?
  19. #59
    Adiciona o Burst normal, 100% funcional, eu estou usando a 2 semanas, sem problemas.
    Que estranho isso, será que é só Comigo esse trem!
  20. #60
    Aqui quando cliente desconecta do pppoe e volta ele nao adicionar a regra correta de parent tbm, ao deletar da queue ai que ele adicona tudo pelas metade. Mais alguem com esse problema?
