Olá pessoal Tem umas máquinas novas aqui (Pentium 4 2.4GHz, HD 60Gb, montadas pela Novadata) que algumas aceitam instalar Linux (RedHat 7.2, 8, FEDORA CORE 1) numa boa; mas algumas outras dão o mesmo erro abaixo:
"The partition table on /tmp/hda is inconsistent. There are many reasons why this might be the case. Often, the reason is that Linux detected the BIOS geometry incorrectly. However, this does not appear to be the case here. It is safe to ignore, but ignoring may cause (fixable) problems with some boot loaders, and may cause problems with FAT file systems. Using LBA is recommended. <IGNORE> <CANCEL>
AÍ EU DOU CANCEL e vem outra msg:
"The partition table on device 'hda' was unreadable. To create new partitions it must be initialized, causing the loss of all data on this drive. Would you like to initialize this drive? <YES> <NO>
AÍ EU DIGO NO e vem outra msg:
"An error has ocurred - no valid devices were found on which to create new filesystems. Please check your hardware for the cause of this problem. <OK>
E AO DAR OK A MAQUINA REBOOTA.
ALGUÉM SABE O QUE PODE ESTAR HAVENDO? JÁ OCORREU COM ALGUEM?
