    Padrão Squid3 + Sarg + Mikrotik
    Ola galera, eu estou quebrando a cabeça para fazer isso. Vamos ver se vcs conseguem me ajudar.
    minha topologia é assim, como na imagem abaixo.
Nome:	         topologia.jpg
Visualizações:	322
Tamanho: 	42,1 KB
    Agora eu consegui colocar instalar o squid3 + sarg
    nessas configurações do squid.conf
    acl all src 0.0.0.0/0.0.0.0
    acl redelocal src 193.168.104.0/30
    acl localhost src 127.0.0.1/32
    acl clientes src 192.168.180.0/22
    acl SSL_ports port 443 # https
    acl SSL_ports port 563 # snews
    acl SSL_ports port 873 # rsync
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl Safe_ports port 443 # https
    acl Safe_ports port 631 # cups
    acl Safe_ports port 873 # rsync
    acl Safe_ports port 5000 # VPN
    acl CONNECT method CONNECT
    acl purge method PURGE
    http_access deny manager
    http_access deny purge
    http_access deny !Safe_ports
    http_access allow localhost
    http_access allow redelocal
    http_access allow clientes
    http_access deny all
    http_port 3128 intercept
    cache_mem 128 MB
    maximum_object_size_in_memory 512 KB
    memory_replacement_policy heap GDSF
    cache_replacement_policy heap LFUDA
    cache_dir aufs /var/spool/squid3 20048 16 256
    minimum_object_size 0 KB
    maximum_object_size 4 GB
    cache_swap_low 70
    cache_swap_high 80
    access_log /var/log/squid3/access.log squid
    cache_store_log none
    mime_table /usr/share/squid3/mime.conf
    cache_log /var/log/squid3/cache.log
    coredump_dir /var/spool/squid3
    refresh_pattern -i (/cgi-bin/|\?) 0 0% 0
    refresh_pattern (Release|Packages(.gz)*)$ 0 20% 2880
    refresh_pattern . 0 20% 4320
    cache_mgr [email protected]
    visible_hostname linux
    detect_broken_pconn on
    global_internal_static on
    error_directory /usr/share/squid3/errors/Portuguese
    memory_pools on
    memory_pools_limit 32 MB
    pipeline_prefetch on
    Agora as regras no mikrotik
    /ip firewall nat
    add action=accept chain=dstnat disabled=no dst-address-list=!fora_proxy \
    dst-port=80 protocol=tcp
    add action=dst-nat chain=dstnat disabled=no dst-address-list=!fora_proxy \
    dst-port=80 protocol=tcp src-address=192.168.180.0/22 to-addresses=\
    193.168.104.2 to-ports=3128
    add action=masquerade chain=srcnat comment="MASCARADE DO LINK" disabled=no
    /ip firewall address-list
    add address=23.64.0.0/14 comment=Akamai disabled=no list=fora_proxy
    add address=192.168.180.0/22 disabled=no list=clientes
    Na tela do /var/log/squid3/access.log
Nome:	         access_log.jpg
Visualizações:	245
Tamanho: 	165,9 KB
    porem não da os ips do clientes, como faço para dar os ips do clientes?
    Desde ja agradeço a ajuda.
    Moderador Avatar de minelli
    Aug 2006
    Padrão Re: Squid3 + Sarg + Mikrotik
    Bom dia, corrige sua regra de NAT.
    Para qual regra?
    Aug 2006
    Vc deve estar fazendo NAT para a classe de ip. Faça o NAT chaim: src-nat, out-intercafe: interface link, action: masquerade.
    Eu fiz quando eu habilito assim, os pessoas ficam sem internet
    apareceu os IP como na imagem abaixo, so que os clientes ficam sem internet
Nome:	         sarg.jpg
Visualizações:	254
Tamanho: 	182,0 KB
    Citação Postado originalmente por minelli Ver Post
    Se eu coloco essa regra ai, ate aparece os ip porem os clientes ficam sem internet e o proxy tbm fica sem, ele não pinga para fora.
    Obrigado @minelli ja consegui fazer funcionar.
