# Script MONITORAMENTO LUZ - Check v0.1 - ALERTA SMS SMSNET #
# Provedor SMSNET de envio #
https://www.smsnet.com.br/ #
# Basta apenas colocar qualquer equipamento na interface a ser monitorada #
# Autor: Andre Andrade <https://chat.whatsapp.com/47oHqutEhDs4R2ECrzNysZ> #
# 19/03/2018 - 19:20pm #
#### AJUSTAR VALORES ENTRE ASPA ABAIXO ####
#### NOME_DA_INTERFACE, USUARIO, SENHA, dddCELULAR ####
:local intname "NOME_DA_INTERFACE"
:local user "USUARIO_DO_SMSNET"
:local pass "SENHA_DO_SMSNET"
:local from "dddCELULAR"
#### NAO ALTERAR ABAIXO O SCRIPT ####
:local date [/system clock get date]; :local hour [/system clock get time]; :local host [/system identity get name]; :global uMonitTurn; /interface ethernet monitor $intname once do={:if ($status != "link-ok" && $uMonitTurn != 0) do={:set uMonitTurn 0; :log error "interface $intname is disconnected"; /tool fetch url="https://sistema.smsnet.com.br/sms/global\?username=$user&password=$pass&to=+55$from&msg=LIGHT TURN OFF em $host em $date ($hour)" keep-result=no; };:if ($status = "link-ok" && $uMonitTurn != 1) do={:set uMonitTurn 1; :log warning "interface $intname is connected"; /tool fetch url="https://sistema.smsnet.com.br/sms/global\?username=$user&password=$pass&to=+55$from&msg=LIGHT TURN ON in $host em $date ($hour)" keep-result=no;}}
