Bom tarde galera,
Estou utilizando o Slackware com Mysql 4.20, Postfix 2.1.4,Courier.Maildrop !!!
Esta tudo startado e funcionando !!!
O recebimento parece estar funcionando ele conecta e checa se existe email !!!
Enviei pelo maildrop cat /etc/lilo.conf | maildrop -d [email protected] e funcionou
Só não consigo enviar email pelo postix !!! ?? Aparece o seguinte erro no maillog ???
Sep 25 02:44:24 EMAIL postfix/trivial-rewrite[17066]: warning: connect to mysql server localhost: Can't connect to local MySQL server through socket '/var/run/mysql/mysql.sock' (2)
Sep 25 02:44:24 EMAIL postfix/trivial-rewrite[17066]: fatal: mysql:/etc/postfix/mysql_transport_maps.cf(0,100): table lookup problem
Sep 25 02:44:24 EMAIL postfix/trivial-rewrite[17067]: warning: connect to mysql server localhost: Can't connect to local MySQL server through socket '/var/run/mysql/mysql.sock' (2)
Sep 25 02:44:24 EMAIL postfix/cleanup[16970]: 0C2D029EB03: message-id=<0_16874_1096087169_1@EMAIL>
Sep 25 02:44:24 EMAIL postfix/cleanup[16970]: warning: connect to mysql server localhost: Can't connect to local MySQL server through socket '/var/run/mysql/mysql.sock' (2)
Sep 25 02:44:24 EMAIL postfix/cleanup[16970]: warning: 0C2D029EB03: virtual_alias_maps map lookup problem for [email protected]
Sep 25 02:44:24 EMAIL postfix/pickup[16816]: warning: maildrop/669102AEA85: Error writing message file
Sep 25 02:44:24 EMAIL postfix/pickup[16816]: 1110D29EB03: uid=0 from=<root>
Sep 25 02:44:24 EMAIL postfix/trivial-rewrite[17067]: fatal: mysql:/etc/postfix/mysql_transport_maps.cf(0,100): table lookup problem
Sep 25 02:44:25 EMAIL postfix/smtpd[16931]: warning: premature end-of-input on private/rewrite socket while reading input attribute name
Sep 25 02:44:25 EMAIL postfix/smtpd[16931]: warning: problem talking to service rewrite: Success
Sep 25 02:44:25 EMAIL postfix/smtpd[16917]: warning: premature end-of-input on private/rewrite socket while reading input attribute name
Sep 25 02:44:25 EMAIL postfix/smtpd[16917]: warning: problem talking to service rewrite: Connection reset by peer
Sep 25 02:44:25 EMAIL postfix/master[16815]: warning: process /usr/libexec/postfix/trivial-rewrite pid 17066 exit status 1
Sep 25 02:44:25 EMAIL postfix/master[16815]: warning: /usr/libexec/postfix/trivial-rewrite: bad command startup -- throttling
Sep 25 02:44:25 EMAIL postfix/cleanup[16970]: warning: premature end-of-input on private/rewrite socket while reading input attribute name
Sep 25 02:44:25 EMAIL postfix/cleanup[16970]: warning: problem talking to service rewrite: Connection reset by peer
Alguem poderia me ajudar ???
Edu
Citação
