- script nao inicia!
script nao inicia!
Olá galera
Peguei este script na net mas nao consigo inicia-lo!!!]
#!/bin/sh
# Variáveis
iptables=/sbin/iptables
IF_EXTERNA=eth0
IF_INTERNA=eth1
# Ativa módulos
/sbin/modprobe iptable_nat
/sbin/modprobe ip_conntrack
/sbin/modprobe ip_conntrack_ftp
/sbin/modprobe ip_nat_ftp
/sbin/modprobe ipt_LOG
/sbin/modprobe ipt_REJECT
/sbin/modprobe ipt_MASQUERADE
# Ativa roteamento no kernel
echo "1" > /proc/sys/net/ipv4/ip_forward
# Proteção contra IP spoofing
echo "1" > /proc/sys/net/ipv4/conf/all/rp_filter
# Zera regras
$iptables -F
$iptables -X
$iptables -F -t nat
$iptables -X -t nat
$iptables -F -t mangle
$iptables -X -t mangle
# Determina a política padrão
$iptables -P INPUT DROP
$iptables -P OUTPUT DROP
$iptables -P FORWARD DROP
# Tabela FILTER
# Dropa pacotes TCP indesejáveis
$iptables -A FORWARD -p tcp ! --syn -m state --state NEW -j LOG --log-level 6 --log-prefix "FIREWALL: NEW sem syn: "
$iptables -A FORWARD -p tcp ! --syn -m state --state NEW -j DROP
# Dropa pacotes mal formados
$iptables -A INPUT -i $IF_EXTERNA -m unclean -j LOG --log-level 6 --log-prefix "FIREWALL: pacote mal formado: "
$iptables -A INPUT -i $IF_EXTERNA -m unclean -j DROP
# Aceita os pacotes que realmente devem entrar
$iptables -A INPUT -i ! $IF_EXTERNA -j ACCEPT
$iptables -A INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
$iptables -A OUTPUT -m state --state ESTABLISHED,RELATED,NEW -j ACCEPT
$iptables -A FORWARD -m state --state ESTABLISHED,RELATED,NEW -j ACCEPT
# Proteção contra trinoo
$iptables -N TRINOO
$iptables -A TRINOO -m limit --limit 15/m -j LOG --log-level 6 --log-prefix "FIREWALL: trinoo: "
$iptables -A TRINOO -j DROP
$iptables -A INPUT -p TCP -i $IF_EXTERNA --dport 27444 -j TRINOO
$iptables -A INPUT -p TCP -i $IF_EXTERNA --dport 27665 -j TRINOO
$iptables -A INPUT -p TCP -i $IF_EXTERNA --dport 31335 -j TRINOO
$iptables -A INPUT -p TCP -i $IF_EXTERNA --dport 34555 -j TRINOO
$iptables -A INPUT -p TCP -i $IF_EXTERNA --dport 35555 -j TRINOO
# Proteção contra tronjans
$iptables -N TROJAN
$iptables -A TROJAN -m limit --limit 15/m -j LOG --log-level 6 --log-prefix "FIREWALL: trojan: "
$iptables -A TROJAN -j DROP
$iptables -A INPUT -p TCP -i $IF_EXTERNA --dport 666 -j TROJAN
$iptables -A INPUT -p TCP -i $IF_EXTERNA --dport 4000 -j TROJAN
$iptables -A INPUT -p TCP -i $IF_EXTERNA --dport 6000 -j TROJAN
$iptables -A INPUT -p TCP -i $IF_EXTERNA --dport 6006 -j TROJAN
$iptables -A INPUT -p TCP -i $IF_EXTERNA --dport 16660 -j TROJAN
# Proteção contra worms
$iptables -A FORWARD -p tcp --dport 135 -i $IF_INTERNA -j REJECT
# Proteção contra syn-flood
$iptables -A FORWARD -p tcp --syn -m limit --limit 2/s -j ACCEPT
# Proteção contra ping da morte
$iptables -A FORWARD -p icmp --icmp-type echo-request -m limit --limit 1/s -j ACCEPT
# Proteção contra port scanners
$iptables -N SCANNER
$iptables -A SCANNER -m limit --limit 15/m -j LOG --log-level 6 --log-prefix "FIREWALL: port scanner: "
$iptables -A SCANNER -j DROP
$iptables -A INPUT -p tcp --tcp-flags ALL FIN,URG,PSH -i $IF_EXTERNA -j SCANNER
$iptables -A INPUT -p tcp --tcp-flags ALL NONE -i $IF_EXTERNA -j SCANNER
$iptables -A INPUT -p tcp --tcp-flags ALL ALL -i $IF_EXTERNA -j SCANNER
$iptables -A INPUT -p tcp --tcp-flags ALL FIN,SYN -i $IF_EXTERNA -j SCANNER
$iptables -A INPUT -p tcp --tcp-flags ALL SYN,RST,ACK,FIN,URG -i $IF_EXTERNA -j SCANNER
$iptables -A INPUT -p tcp --tcp-flags SYN,RST SYN,RST -i $IF_EXTERNA -j SCANNER
$iptables -A INPUT -p tcp --tcp-flags SYN,FIN SYN,FIN -i $IF_EXTERNA -j SCANNER
# Loga tentativa de acesso a determinadas portas
$iptables -A INPUT -p tcp --dport 21 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: ftp: "
$iptables -A INPUT -p tcp --dport 23 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: telnet: "
$iptables -A INPUT -p tcp --dport 25 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: smtp: "
$iptables -A INPUT -p tcp --dport 80 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: http: "
$iptables -A INPUT -p tcp --dport 110 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: pop3: "
$iptables -A INPUT -p udp --dport 111 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: rpc: "
$iptables -A INPUT -p tcp --dport 113 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: identd: "
$iptables -A INPUT -p tcp --dport 137:139 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: samba: "
$iptables -A INPUT -p udp --dport 137:139 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: samba: "
$iptables -A INPUT -p tcp --dport 161:162 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: snmp: "
$iptables -A INPUT -p tcp --dport 6667:6668 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: irc: "
$iptables -A INPUT -p tcp --dport 3128 -i $IF_EXTERNA -j LOG --log-level 6 --log-prefix "FIREWALL: squid: "
# Libera acesso externo a determinadas portas
$iptables -A INPUT -p tcp --dport 22 -i $IF_EXTERNA -j ACCEPT
# Libera acesso de smtp para fora apenas para o IP XXX.XXX.XXX.XXX
#$iptables -A FORWARD -p tcp -d ! XXX.XXX.XXX.XXX --dport 25 -j LOG --log-level 6 --log-prefix "FIREWALL: SMTP proibido: "
#$iptables -A FORWARD -p tcp -d ! XXX.XXX.XXX.XXX --dport 25 -j REJECT
# Tabela NAT
# Ativa mascaramento de saída
$iptables -A POSTROUTING -t nat -o $IF_EXTERNA -j MASQUERADE
# Proxy transparente
#$iptables -t nat -A PREROUTING -i $IF_INTERNA -p tcp --dport 80 -j REDIRECT --to-port 3128
#$iptables -t nat -A PREROUTING -i $IF_INTERNA -p tcp --dport 8080 -j REDIRECT --to-port 3128
# Redireciona portas para outros servidores
#$iptables -t nat -A PREROUTING -d 192.168.200.1 -p tcp --dport 22 -j DNAT --to-destination 10.0.0.1
# Redireciona portas na própria máquina
#$iptables -A PREROUTING -t nat -d 192.168.200.1 -p tcp --dport 5922 -j REDIRECT --to-ports 22
já dei chmod +x firewall.h
e coloquei no rc.local /etc/rc.d/firewall.h
mas ele nao inicia, quando digito os comandos prompt funciona normalmente, o q estou fazendo errado???
Estou usando CL 8+
Agradeço desde já a colaboração de todos
script nao inicia!
isso ae galera,,,,,ola para todos...
estou com o mesmo prob.....
qualquer ajuda é bem vinda....
atea mais
script nao inicia!
amigo, dê iptables -L e veja se realmente ele nao iniciou... se ele nao jogou as regras... e veja se as rotas estao certas... flw!
script nao inicia!
Bom, algumas perguntas básicas:
Deu permissão de execução ao script?
Colocou o mesmo na inicialização da máquina?
Como o barata_branca disse, verifique se as regras estão ativas no sistema com o comando iptables -L.
Se estiver executando, verifique nos logs se não há algum erro.
script nao inicia!
Vc vai ter que colocar ele pra inicializar no arquivo /etc/rc.local .
Adiciona na ultima linha
bash /etc/rc.d/firewall.h
script nao inicia!
Ja tive o mesmo problema mas foi pq havia editado os arquivos em um editor de texto do open office ou gedit, kedit.. essas coisas.. usei o mcedit ou vi e retirei o espaço do fim da linhas. espaço = ^M
Depois disso, funcionou perfeito.
script
já dei permissao ao arquivo
e no iptables -L ele nao retorna nada
vou tentar amanha bash /etc/rc.d/firewall.h
muito obrigado
script nao inicia!
poe " " nas variaveis
iface="eth0"
troca a shell do seu script para bash
ve se gera algum erro quando voce roda o script
Erro!
Ola galera
coloquei o bash na frente e ele iniciou porem deu varios erros
cant' module locate
acho que ele nao achou o caminho da variavel $iptables, oq faco para resolver isso???
agradeco desde ja a colaboracao de todos
script nao inicia!
Kara ... tenta por só iptables na variavel, caso nao funcione, verifique se o iptables esta instalado.
script nao inicia!
viu, a shell tava errada, vamo la, seguinte:
eu="estou aprendendo a fazer variaveis"
estou dizendo que a variavel $eu e' igual a "estou aprendendo a fazer variaveis"
ou seja:
iptables="/sbin/iptables"
$iptables -A INPUT -p tcp --dport 69 -s 0/0 -d 0/0 -j ACCEPT
sete a variavel primeiro, confirme tambem se o PATH (caminho) esta certo, no meu sistema uso /sbin/iptables, dependendo da sua distribuicao (slackware) e' diferente, digite whereis iptables, ele vai te mostrar aonde o binario se encontra
falo ai irmao
abracao
