Postado originalmente por
LinuxKids
ae galera deêm uma olhada no meu squid.conf e me digam o que esta errado ae nele
visible_hostname servidor
http_port 192.168.0.0:8080
cache_mem 32 MB
cache_swap_low 90
cache_swap_high 95
cache_mgr
[email protected]
cache_effective_user proxy
maximum_object_size 16384 KB
minimum_object_size o KB
maximum_object_size_in_memory 20 kb
#cache_dir ufs /var/spool/squid 1000 16 256
hierarchy_stoplist cgi-bin ?
no_cache deny QUERY
auth_param basic program /usr/lib/squid/ncsa_auth /etc/squid/squid_passwd
auth_param basic children 5
auth_param basic realm Digite seu Login
acl autenticate proxy_auth REQUIRED
#auth_param basic credentialsttl 2 hours
refresh_pattern . 0 20% 4320
acl all src 192.168.0.0/24
acl redeinterna src 192.168.0.0/24
acl SSL_ports port 443 563
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl CONNECT method CONNECT
http_access allow redeinterna
http_access allow autenticate
#ttp_access allow manager localhost
http_access deny manager
http_access deny !Safe_ports
http_access deny all
http_reply_access allow all
icp_access allow all
coredump_dir /var/cache/squid
