-  DNS no FEDORA
 DNS no FEDORA
							Pessoal, olhem erro q ocorre quando tento subir DNS...
alguém me pode me dar uma luz...
obrigado..
Nov 25 09:46:46 radio02 named: desligar named failed
Nov 25 11:47:00 radio02 named[2455]: starting BIND 9.2.3 -u named -t /var/named/chroot
Nov 25 11:47:00 radio02 named[2455]: using 1 CPU
Nov 25 11:47:00 radio02 named[2455]: loading configuration from '/etc/named.conf'
Nov 25 11:47:00 radio02 named[2455]: listening on IPv4 interface lo, 127.0.0.1#53
Nov 25 11:47:00 radio02 named[2455]: listening on IPv4 interface eth0, 192.168.1.1#53
Nov 25 11:47:00 radio02 named[2455]: couldn't add command channel 127.0.0.1#953: not found
Nov 25 11:47:00 radio02 named[2455]: couldn't add command channel ::1#953: not found
Nov 25 11:47:00 radio02 named[2455]: running
Nov 25 09:47:00 radio02 named: inÃcio de named succeeded
 DNS no FEDORA
 DNS no FEDORA
							Coloca seu named ai para podermos analizar...
 DNS no FEDORA
							Agradeço....consegui resolver o problema, desistalando bind-chroor...não sei se foi a melhor opção....+ logo após desistalar....ta funcionando normal..
agradeço..
