#Recommended minimum configuration:
# Acl para o Squid
acl rede_interna src 200.200.0.0/16
acl blockedsites url_regex -i "/etc/squid/bloqueados/block.txt"
acl teste url_regex uol.com.br
acl all src 0.0.0.0/0.0.0.0
acl SSL_ports port 443 563
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl CONNECT method CONNECT
# REGRAS PARA O SQUID
http_access allow rede_interna
httpd_accel_host virtual
httpd_accel_port 80
httpd_accel_with_proxy on
# INSERT YOUR OWN RULE(S) HERE TO ALLOW ACCESS FROM YOUR CLIENTS
# And finally deny all other access to this proxy
http_access allow localhost
# Regra para o Squid
http_access deny teste
http_access deny blockedsites
http_access deny all
