Salve, salve ...
Pessoal estou tentando rodar o unbound no freebsd e ao dar o start ele me retorna o seguinte erro:
unbound-control[993:0] error: connect: Connection refused for /var/run/local_unbound.ctl
abaixo esta meu unbound.conf
# Configuration basic DNS Reverse Unbound
server:
port: 53
username: unbound
directory: /var/unbound
chroot: /var/unbound
use-syslog: yes
logfile: /var/unbound/unbound.log
pidfile: /var/run/local_unbound.pid
module-config: "validator iterator"
root-hints: /var/unbound/named.cache
auto-trust-anchor-file: /var/unbound/root.key
hide-identity: yes
hide-version: yes
interface: 127.0.0.1
interface: 10.99.99.10
access-control: 0.0.0.0/0 refuse
access-control: 127.0.0.0/8 allow
access-control: 10.0.0.0/8 allow
access-control: 172.16.0.0/12 allow
access-control: 192.168.0.0/16 allow
do-ip6: yes
do-ip4: yes
do-tcp: yes
do-udp: yes
do-daemonize: yes
verbosity: 1
msg-cache-slabs: 2
rrset-cache-slabs: 2
infra-cache-slabs: 2
key-cache-slabs: 2
# Cache de Memoria
rrset-cache-size: 100m
msg-cache-size: 50m
# Eventuais problemas de fragmentation de pacotes
edns-buffer-size: 1480
local-data:"localhost A 127.0.0.1"
local-data-ptr:"127.0.0.1 localhost"
local-data:"www.facebook.com.br. A 31.13.85.8"
local-data-ptr:"31.13.85.8 www.facebook.com.br."
local-data:"facebook.com.br. A 31.13.85.8"
local-data-ptr:"31.13.85.8 facebook.com.br."
local-data:"facebook.com. A 31.13.85.8"
local-data-ptr:"31.13.85.8 facebook.com."
local-data:"www.facebook.com. A 31.13.85.8"
local-data-ptr:"31.13.85.8 www.facebook.com."
#Exemplo de como Definir uma zona
#local-zone:"hdrive.com.br." static
#local-data:"mail.hdrive.com.br. 10800 IN A 201.150.144.12"
#local-data:"mail.hdrive.com.br. 10800 IN A 201.150.144.13"
#include: /var/unbound/forward.conf
include: /var/unbound/control.conf
# Exemplo de como ativar o unbound-control
remote-control:
control-enable: yes
