Pessoal executei todos os passos do tutorial em um box Fedora Core 2. Aparentemente tudo está funcionando, a conexão abre.
Em primeiro teste o seguinte log apareceu:
Aug 6 23:41:07 server pppoe-server[5297]: Session 3 created for client 08:00:46:bd:a5:36 (172.30.0.2) on eth2:0 using Service-Name ''
Aug 6 23:41:07 server pppd[5297]: Plugin radius.so loaded.
Aug 6 23:41:07 server pppd[5297]: RADIUS plugin initialized.
Aug 6 23:41:07 server pppd[5297]: Plugin radattr.so loaded.
Aug 6 23:41:07 server pppd[5297]: RADATTR plugin initialized.
Aug 6 23:41:07 server pppd[5297]: pppd 2.4.2b3 started by root, uid 0
Aug 6 23:41:07 server pppd[5297]: Using interface ppp0
Aug 6 23:41:07 server pppd[5297]: Connect: ppp0 <--> /dev/pts/65
Aug 6 23:41:09 server pppd[5297]: rc_find_server: couldn't find RADIUS server localhost in /etc/radiusclient/servers
Aug 6 23:41:09 server pppd[5297]: PAP peer authentication failed for wireless
Aug 6 23:41:09 server pppd[5297]: Connection terminated.
Aug 6 23:41:09 server pppoe-server[5169]: Sent PADT
Aug 6 23:41:10 server pppd[5297]: Terminating on signal 15.
Aug 6 23:41:10 server pppoe[5298]: read (asyncReadFromPPP): Session 3: Input/output error
Aug 6 23:41:10 server pppd[5297]: Exit.
Aug 6 23:41:10 server pppoe-server[5169]: Session 3 closed for client 08:00:46:bd:a5:36 (172.30.0.2) on eth2:0
Com isso descobri que no arquivo /etc/radiusclient/radiusclient.conf eu havia esquecido de aletar as linhas que diziam respeito ao servidor radius. Fiz a alteracao e quando tento loga o sistema fica dizendo que esta verificando usuário e senha e depois para dizendo que o servidor demorou muito a responder, sendo a resposta no log a seguinte:
Aug 6 23:44:58 server pppoe-server[5326]: Session 4 created for client 08:00:46:bd:a5:36 (172.30.0.3) on eth2:0 using Service-Name ''
Aug 6 23:44:58 server pppd[5326]: Plugin radius.so loaded.
Aug 6 23:44:58 server pppd[5326]: RADIUS plugin initialized.
Aug 6 23:44:58 server pppd[5326]: Plugin radattr.so loaded.
Aug 6 23:44:58 server pppd[5326]: RADATTR plugin initialized.
Aug 6 23:44:58 server pppd[5326]: pppd 2.4.2b3 started by root, uid 0
Aug 6 23:44:58 server pppd[5326]: Using interface ppp0
Aug 6 23:44:58 server pppd[5326]: Connect: ppp0 <--> /dev/pts/67
Aug 6 23:45:22 server pppoe-server[5169]: Sent PADT
Aug 6 23:45:22 server pppd[5326]: Terminating on signal 15.
Alguém pode me ajudar?
Att,
Nataniel Klug
