squid.conf
Código :http_port 3128 visible_hostname Next cache_mem 2 GB maximum_object_size_in_memory 1 MB maximum_object_size 700 MB minimum_object_size 0 KB cache_swap_low 90 cache_swap_high 95 cache_dir ufs /var/spool/squid3 700000 16 256 cache_access_log /var/log/squid3/access.log cache_store_log /var/log/squid3/store.log cache_log /var/log/squid3/cache.log refresh_pattern ^ftp: 15 20% 2280 refresh_pattern ^gopher: 15 0% 2280 refresh_pattern . 15 20% 2280 cache_mgr www.redenext.com cache_effective_user proxy cache_effective_group proxy acl LAN src 192.168.2.0/24 http_access allow LAN http_access deny all
não sei se este é o uso correto, minha maquina tem 4 cores 3.0, 8gb ddr3, hd 1tb sata3
a configuração do squid3 peguei em um vídeo do youtube, abaixo deixo o retorno.
Código :1488659688.333 460 192.168.2.2 TCP_MISS/200 3821 GET http://www.rarlab.com/download.htm - HIER_DIRECT/5.135.104.98 text/html 1488659695.357 5 192.168.2.2 TCP_MISS/200 1962765 GET http://www.rarlab.com/rar/wrar540.exe - HIER_NONE/- application/octet-stream 1488659742.646 487 192.168.2.2 TCP_MISS/200 4646 GET http://www.rarlab.com/ - HIER_DIRECT/5.135.104.98 text/html 1488659745.920 233 192.168.2.2 TCP_MISS/200 3821 GET http://www.rarlab.com/download.htm - HIER_DIRECT/5.135.104.98 text/html 1488659746.167 156 192.168.2.2 TCP_MISS/200 315 GET http://e0.extreme-dm.com/s9.g? - HIER_DIRECT/54.225.199.91 image/gif 1488659754.749 8 192.168.2.2 TCP_HIT/200 1962766 GET http://www.rarlab.com/rar/wrar540.exe - HIER_NONE/- application/octet-stream
ou seja a pagina n ta cacheando más o download sim, como resolver isso ?
cache pra gravar somente download n tem serventia pra mim.
