Boa noite senhores fui tentar instalar o prog. xarchon baixei o arquivo blz e fui tentar compilar começei executando o ./configure ai ele retornou a seguinte msn de erro:
checking for gtk-config... gtk12-config
checking for GTK - version >= 1.2.0... ./configure: line 1: gtk12-config: command not found
no
*** Could not run GTK test program, checking why...
*** The test program failed to compile or link. See the file config.log for the
*** exact error that occured. This usually means GTK was incorrectly installed
*** or that you have moved GTK since it was installed. In the latter case, you
*** may want to edit the gtk-config script: gtk12-config
checking for qVersion__Fv in -lqt... no
checking which toolkit is default... configure: error:
Neither GTK+ nor Qt toolkits were found
sei que é um problema com alguma biblioteca como descobrir qual exatamente é ?
