Configurei o ltsp, os terminais reconhecem o server dhcp, recebe o ip atribuido no dhcpd.conf, mas ao carregar o sistema ele trava na mensagem abaixo:
Error:
could not automatically detect the network card.
PCI cards should be detected automatically.
ISA cards cannot be detected, so they require the nic drive to be specified in a 'Nic=' parameter to be passed on the kernel command line, usually specefied in option-129, in the /etc/dhcpd.con file. See the LTSP docs for more ino.
Kernel panic - not syncing: Attempted to kill init!
Alguem sabe dizer o que pode ser feito?
E quando eu insiro as linhas abaixo eu não consigo reiniciar o serviço dhcp:
option option-128 code 128 = string;
option option-129 code 129 = text;
host ws001 {
hardware ethernet 00:E0:06:E8:00:84;
fixed-address 192.168.0.11;
option option-128 e4:45:74:68:00:00;
option option-129 "NIC=XXX";
Segue os arquivos da configuração do ltsp.
dhcpd.conf
arquivo exportsCódigo :shared-network WORKSTATIONS { subnet 192.168.0.0 netmask 255.255.255.0 { default-lease-time 21600; max-lease-time 21600; option subnet-mask 255.255.255.0; option broadcast-address 192.168.0.255; option routers 192.168.0.1; option domain-name-servers 192.168.0.1; deny unknown-clients; # range 192.168.0.100 192.168.0.201; option root-path "192.168.0.1:/opt/ltsp/i386"; next-server 192.168.0.1; } } group { use-host-decl-names on; # Adicione mais terminais caso necessário copiando e colando as linhas: # terminal 1: host ws001 { hardware ethernet 00:23:7D:43:63:60; fixed-address 192.168.0.11; filename "lts/2.6.17.3-ltsp-1/pxelinux.0"; } # terminal 2: host ws002 { hardware ethernet 00:18:71:8C:EC:D8; fixed-address 192.168.0.12; filename "lts/2.6.17.3-ltsp-1/pxelinux.0"; } # terminal 3: host ws003 { hardware ethernet 00:E0:7D:AB:E3:11; fixed-address 192.168.0.13; filename "lts/2.6.17.3-ltsp-1/pxelinux.0"; } # terminal 4: host ws004 { hardware ethernet 00:C0:DF:09:05:55; fixed-address 192.168.0.14; filename "lts/2.6.17.3-ltsp-1/pxelinux.0"; } # terminal 5: host ws005 { hardware ethernet 00:60:08:37:4F:15; fixed-address 192.168.0.15; filename "lts/2.6.17.3-ltsp-1/pxelinux.0"; } # terminal 6: host ws006 { hardware ethernet 00:0C:29:6F:F4:AB; fixed-address 192.168.0.16; filename "lts/2.6.17.3-ltsp-1/pxelinux.0"; } # terminal 7: host ws007 { hardware ethernet 00:08:0D:7B:E9:C8; fixed-address 192.168.0.17; filename "lts/2.6.17.3-ltsp-1/pxelinux.0"; } # terminal 8: host ws008 { hardware ethernet 00:0c:29:f4:34:19; fixed-address 192.168.0.18; filename "lts/2.6.17.3-ltsp-1/pxelinux.0"; } }
[/code]arquivo hosts.allowCódigo :# /etc/exports, para o LTSP 4.2 /opt/ltsp/i386/ 192.168.0.0/255.255.255.0(ro,sync,subtree_check,no_root_squash)
arquivo lts.confCódigo :ALL : 127.0.0.1 192.168.0.0/24
arquivo hosts.confCódigo :[Default] SERVER = 192.168.0.1 # Esta opção faz com que o LTSP detecte automaticamente a placa de vídeo # dos terminais, utilizando os drivers do X.org XSERVER = auto # Configure aqui o tipo de mouse que será usado nos terminais por default. # Você pode especificar tipos de mouse diferentes na configuração de cada # terminal. X_MOUSE_PROTOCOL = "PS/2" X_MOUSE_DEVICE = "/dev/psaux" X_MOUSE_RESOLUTION = 400 X_MOUSE_BUTTONS = 3 # Configuração default do teclado, ABNT2: XkbModel = ABNT2 XkbLayout = br # Faz com que as estações carreguem o ambiente gráfico por default: SCREEN_01 = startx RUNLEVEL = 5 # ------------ Configuração específica de cada estação: ------------- # Esta é a configuração individual dos terminais, que bipassam os valores # default determinados acima. Você pode adicionar mais estações conforme # necessário. Descomente a linha do swap via rede em todas as estações # com 32 MB de RAM ou menos. # Veja exemplos de configuração para diferentes situações logo a seguir. [ws001] XSERVER = auto # suporte a CD, disquete e pendrive LOCAL_STORAGE = Y MODULE_01 = ohci-hcd # swap via rede: # USE_NBD_SWAP = Y [ws002] XSERVER = auto # suporte a CD, disquete e pendrive LOCAL_STORAGE = Y MODULE_01 = ohci-hcd # swap via rede: # USE_NBD_SWAP = Y [ws003] XSERVER = auto # suporte a CD, disquete e pendrive LOCAL_STORAGE = Y MODULE_01 = ohci-hcd # swap via rede: # USE_NBD_SWAP = Y [ws004] XSERVER = auto # suporte a CD, disquete e pendrive LOCAL_STORAGE = Y MODULE_01 = ohci-hcd # swap via rede: # USE_NBD_SWAP = Y [ws005] XSERVER = auto # suporte a CD, disquete e pendrive LOCAL_STORAGE = Y MODULE_01 = ohci-hcd # swap via rede: # USE_NBD_SWAP = Y [ws006] XSERVER = auto # suporte a CD, disquete e pendrive LOCAL_STORAGE = Y MODULE_01 = ohci-hcd # swap via rede: # USE_NBD_SWAP = Y [ws007] XSERVER = auto # suporte a CD, disquete e pendrive LOCAL_STORAGE = Y MODULE_01 = ohci-hcd # swap via rede: # USE_NBD_SWAP = Y [ws008] XSERVER = auto # suporte a CD, disquete e pendrive LOCAL_STORAGE = Y MODULE_01 = ohci-hcd # swap via rede: # USE_NBD_SWAP = Y
Quem puder me ajudar agradeço muito.Código :127.0.0.1 ltsp localhost # The following lines are desirable for IPv6 capable hosts # (added automatically by netbase upgrade) ::1 ip6-localhost ip6-loopback fe00::0 ip6-localnet ff00::0 ip6-mcastprefix ff02::1 ip6-allnodes ff02::2 ip6-allrouters ff02::3 ip6-allhosts 192.168.0.1 ltsp 192.168.0.11 ws001 192.168.0.12 ws002 192.168.0.13 ws003 192.168.0.14 ws004 192.168.0.15 ws005 192.168.0.16 ws006 192.168.0.17 ws007 192.168.0.18 ws008
As placas de rede dos clientes são placas onboard e funcionam pxe, não entendo porque não entram no sistema.
obrigado.
