Tenho dois links
ADSL = 15mb
VDSL = 50mb
estou usando essas regras
quando tento fazer um teste no http://www.testepower.com.br/ fica dando erro já no downloadCódigo PHP:
/ip firewall mangleadd action=mark-routing chain=prerouting comment=\ "========================= / Load Balance /=========================" \ disabled=no dst-address-type=!local in-interface=Lan new-routing-mark=\ VDSL passthrough=no per-connection-classifier=\ both-addresses-and-ports:2/0add action=mark-routing chain=prerouting disabled=no dst-address-type=!local \ in-interface=Lan new-routing-mark=ADSL passthrough=no \ per-connection-classifier=both-addresses-and-ports:2/1 /ip routeadd disabled=no distance=1 dst-address=0.0.0.0/0 gateway=VDSL routing-mark=\ VDSL scope=30 target-scope=10add disabled=no distance=2 dst-address=0.0.0.0/0 gateway=ADSL routing-mark=\ ADSL scope=30 target-scope=10
as vezes tambem fica dando travadas no mikrotik ( x86 ) onde nem via winbox funciona, tenho q forçar desligamento
erro = https://uploaddeimagens.com.br/images/000/841/397/full/Sem_t%C3%ADtulo.png?1487536775
