OLA BOA NOITE
meu cenário: pc/mikrotik v5.18 2g/ram, HD/320g onde meus clientes vão se conectar via ppoe. meu link é via modem em bridg ppoe. ativei o webproxy rodando blz ( com todas as regras como manda o figurino). ja rodei aki no forum ja fiz todas as dicas de outros post mias nada( segue minha configurações):
/ip firewall mangle
add action=mark-connection chain=output comment="2-PROXY FULL" disabled=no \
dscp=4 new-connection-mark=proxyfull passthrough=yes protocol=tcp src-port=\
8080
add action=mark-packet chain=output comment="" connection-mark=proxyfull \
disabled=no new-packet-mark=proxyfull passthrough=yes
add action=return chain=output comment="" connection-mark=proxyfull disabled=n
/ip firewall nat
add action=redirect chain=dstnat comment="Redirecionamento do Proxy" disabled=\
no dst-port=80 protocol=tcp src-address=192.168.1.0/24 to-ports=8080add action=accept chain=dstnat comment=\
"\"\"\"\"\"\"SERVI\C7OS NOBRES FORA DO PROXY\"\"\"\"\"\"" disabled=no \
dst-address-list=nobalance dst-port=80 protocol=tcp
/ip firewall filter
add chain=input action=accept dst-port=8080 protocol=tcp comment="ACEITAR \
CONEXOES PROXY" disabled=no
/ip proxy
set always-from-cache=yes cache-administrator=webmaster cache-hit-dscp=4 \
cache-on-disk=yes enabled=yes max-cache-size=unlimited \
max-client-connections=600 max-fresh-time=3d max-server-connections=600 \
parent-proxy=0.0.0.0 parent-proxy-port=0 port=8080 serialize-connections=no \
src-address=0.0.0.0
/ip proxy access
add action=allow comment="Portas Para MSN" disabled=no dst-port=1025-65535
add action=deny comment="" disabled=no path=*ADSAdClient31.dll* redirect-to=\
www.flinformatica.com/0800/edu/msn.htm
add action=deny comment=\
"allow CONNECT only to SSL ports 443 [https] and 563 [snews]" disabled=no \
dst-port=!443,563 method=CONNECT
add action=deny comment="" disabled=no path=*ork.user* redirect-to=\
www.flinformatica.com/0800/edu/orkut.htm
add action=deny comment="block telnet & spam e-mail relaying" disabled=no \
dst-port=23-25
agradeço desde de ja pelo uma alma caridosa ^^ abração!
