    Mano me adiciona no skype: tel92218120 para podemos resolver o tal sonhado cache full
    Padrão full
    nas regras do proxy full no mangle tem uma delas que pede a iterface do link e quando e um balaceamento como fica isso pois no balavceamento roda proxy full...
    amigo estow com uma duvida que está marcado de vermelho e e fiquei com uma broquinha para o up do server qd desabilito o cache full fica blz.
    Alguem poderia olha estas regras?
    / ip firewall mangle
    add chain=output protocol=tcp src-port=3128 content="X-Cache: HIT" action=mark-connection new-connection-mark=squid-connection-HIT passthrough=yes comment="Cache-squid" disabled=no
    add chain=output connection-mark=squid-connection-HIT action=mark-packet new-packet-mark=squid-packet-HIT passthrough=no comment="" disabled=no
    add chain=prerouting in-interface=ether2 src-address=10.10.0.0/24 action=mark-packet new-packet-mark=test-up passthrough=no comment="UP TRAFFIC" disabled=no
    add chain=forward src-address=10.10.0.0/24 action=mark-connection new-connection-mark=test-conn passthrough=yes comment="CONN-MARK" disabled=no
    add chain=forward in-interface=ether1 connection-mark=test-conn action=mark-packet new-packet-mark=test-down passthrough=no comment="DOWN-DIRECT CONNECTION" disabled=no
    add chain=output out-interface=ether2 dst-address=10.10.0.0/24 action=mark-packet new-packet-mark=test-down passthrough=no comment="DOWN-VIA PROXY
    disabled=no
    / queue tree
    add name="downstream" parent=aq uso oq packet-mark=test-down limit-at=1024000 queue=default priority=1 max-limit=1024000 burst-limit=0 burst-threshold=0 burst-time=0s disabled=no
    add name="upstream" parent=global-in packet-mark=test-up limit-at=512000 queue=default priority=1 max-limit=512000 burst-limit=0 burst-threshold=0 burst-time=0s disabled=no
    add name="Cache-full" parent=global-out packet-mark=squid-packet-HIT limit-at=2000000 queue=default priority=8 max-limit=2000000 burst-limit=0 burst-threshold=0 burst-time=0s disabled=no
    agradeço a todos do under sempre nos ajudando
    Citação Postado originalmente por jbssi Ver Post
    amigo obrigado pela sua gentileza mais ja consegui habilitar o web-proxy o pessoal do curso online me ajudou a fazer o cache.
    Padrão ^n Consegui colocar pra rodar...
    amigos tentei de todas as formas mais ñ onsegui colocar pra rodar algum poderia me dá uma ajuda.
    uso a versão 2.9.27. ether1 ( Link ) e ether2 ( clientes.)
    disabled=no
    / queue tree
    add name="downstream" parent=global-in packet-mark=test-down limit-at=1024000 queue=default priority=1 max-limit=1024000 burst-limit=0 burst-threshold=0 burst-time=0s disabled=no
    Sempre lendo e aprendendo e quando possivel ajudando....
    galeta depois de muita luta consegui cache full tow em teste....
    brigadão quem pode ajudar
    sempre lendo e aprendendo.......
    Citação Postado originalmente por talesarconet Ver Post
    disabled=no
    / queue tree
    ai vc coloca o nome da sua interface de saida por exemplo (cliente)
    na regra do amigo josafa estava faltando um (acentos) rsrsrs ne meu deu certo!
    add chain=output protocol=tcp src-port=3128 content="X-Cache: HIT" action=mark-connection new-connection-mark=squid-connection-HIT passthrough=yes \
    add chain=prerouting in-interface=Cliente src-address=192.168.1.0/24 action=mark-packet new-packet-mark=test-up passthrough=no comment="UP TRAFFIC" \
    disabled=no
    add chain=forward src-address=192.168.1.0/24 action=mark-connection new-connection-mark=test-conn passthrough=yes comment="CONN-MARK" disabled=no
    add chain=forward in-interface=Link connection-mark=test-conn action=mark-packet new-packet-mark=test-down passthrough=no comment="DOWN-DIRECT \
    add chain=output out-interface=Cliente dst-address=192.168.1.0/24 action=mark-packet new-packet-mark=test-down passthrough=no comment="DOWN-VIA PROXY" \
    disabled=no
    / queue tree
    add name="downstream" parent=Cliente packet-mark=test-down limit-at=1024000 queue=default priority=1 max-limit=1024000 burst-limit=0 burst-threshold=0 \
    add name="upstream" parent=global-in packet-mark=test-up limit-at=512000 queue=default priority=1 max-limit=512000 burst-limit=0 burst-threshold=0 \
    add name="Cache-full" parent=global-out packet-mark=squid-packet-HIT limit-at=2000000 queue=default priority=8 max-limit=2000000 burst-limit=0 \
    em vermelho e a interface de saida que no meu caso e (Cliente)
    em azul e a faixa de ip que vc usa
    em verde e a interface de entrada que no meu caso e (Link)
    Olá amigos do Fórum!
    como faço para aplicar essas regras, sou novo no mk, e não sei onde colocar esses scripst.
    ah, queria dizer que tenho o mk funcionando com DHCP, PPPoE. Só que só pega a net quando é discado o pppoe, queria saber se esse CACHE-FULL funciona para quem usa PPPoE?
    obrigado
    obrigado.
    funciona com pppoe sim, mas tem q efetuar a regra de firewall para as conexões pppoe passarem pela porta do proxy!
    Citação Postado originalmente por BraZuky Ver Post
    obrigado
    obrigado.
    depois de vc alterar as dados que estao coloridos vc vai em system scripts adiciona um novo script com esse codigo
    ai depois vai em rum script se aparecer a data e a hora e pq o script foi executado (isso nao que dizer que va funcionar)
    Citação Postado originalmente por flashnet Ver Post
    disabled=no
    disabled=no
    / queue tree
    TA OK QUER DIZER QUE PARA EU CONFIGURAR MEU MK QUE ESTA COMO ROUTER, BASTA FAZER AS REFERIDAS SUBSTITUIÇÕES E PRONTO? É ISTO MESMO, SO COPIAR A REGRA ACIMA E FAZER AS ALTERAÇÕES?
  13. #33
    Tem um erro nesta linha
    o passthrough=no ( nao faz cache full ) setado com yes ( faz cache full)
  14. #34
    coloquei a um tempo atrás uma regra relativa a essa do proxy e meu link ia a full nos clientes e tive que desativar...
    agora coloquei exatamente igual ao amigo flashnet postou, passa byte nelas e tudo mais mas baixo algo em um cliente, vo em outro e ele vem na velocidade do cliente.. parece que não ta querendo funcionar na minha versao 2.9.27 =(
    o web-proxy ta rodando, aqui eh mac amarrado ao ip sem hotspot, servidor embaixo e rb em cima..
    agradeço se alguem me der uma luz
  15. #35
    Padrão Queues Simple
    O Que Devo Mudar Na Regra Para Usar Queues Simples No Lugar Das Regras De Queue Tree? Poderia Usar As Duas, Pois Meu Controle E Feito Na Q Simple?
    Fiz Alguns Teste E A Banda Fica Liberada Em Vez De Somente O Cache.
  16. #36
    Moderador Avatar de minelli
    Aug 2006
    Padrão Regras
    Olá bom dia, procure o video do Alexandre Correa e teste pois funciona 100%.
  17. #37
    Padrão Cache full para Mikrotik 2.9.27
    mas aquele cache full do video funciona no mk 2.9.27
  18. #38
    Aug 2006
    Padrão Regras
    Sim, 100%.
  19. #39
    Padrão Nao Entendi As Regras
    ola galera, depois de algum tempo consegui fazer rodar o chache full na versao 2.9.27 e meu cache funcionou legal somente depois q desabilitei as ultimas 2 regras da queue tree q vc passou no seu post, e ai deixei somente a regra do cache full-global-out e ai sim funfou, mas blz...queria saber qual a importancia das outras 2 regras q retirei. valeu, e parebens pelas dicas...
  20. #40
    Padrão Cache Full Ñ Funfor
    Alguém disposto a me ajudar, nao conseguir fazer o cache ful funcionar , alguem tem algo que auxilie um iniciante,
    acontece algo estranho aqui; quando faço o teste de download de um arquivo no mesmo momento que acabou de ser baixado, o cache full funciona, agora quando se passa alguns minutos que esse arquivo foi baixado o cache full nao funciona. ??????????????????????????????
    ___aqui uso um pc rodando um web-proxy na porta 3180 cuja a rede é 192.168.30.0/24
    ___e uma RB em ap bridge, cujo proxy nao habilitado, e o controle dos clientes fica na QUEUE tambem na rb com o 192.168.20.0/24
    se alguem poder me dar uma luz fico muito grato, obrigado.
    Última edição por dnp; 06-06-2008 às 23:42.
