Página 3 de 13 PrimeiroPrimeiro 12345678 ... ÚltimoÚltimo
    Citação Postado originalmente por bitim Ver Post
    Josafapalmas, testei aqui as regras e o ip que configurei em queue simple 64k/64k continua saindo com a banda toda...sem controle... vou postar aqui minhas regras para vc dar uma olhada... Estou testando na versão 2.9.27 Crack
    / ip firewall nat
    add chain=dstnat in-interface=Cliente protocol=tcp dst-port=80 action=redirect \
    to-ports=3128 comment="" disabled=no
    add chain=srcnat out-interface=Link action=masquerade comment="" disabled=no
    / ip firewall mangle
    add chain=output protocol=tcp src-port=3128 content="X-Cache: HIT" \
    action=mark-connection new-connection-mark=squid-connection-HIT \
    passthrough=yes comment="Cache-squid" disabled=no
    add chain=output connection-mark=squid-connection-HIT action=mark-packet \
    new-packet-mark=squid-packet-HIT passthrough=yes comment="" disabled=no
    / queue tree
    add name="Cache-full" parent=global-out packet-mark=squid-packet-HIT \
    limit-at=1024000 queue=default priority=8 max-limit=1024000 burst-limit=0 \
    burst-threshold=0 burst-time=0s disabled=no
    add name="upstream" parent=global-in packet-mark=test-up limit-at=1024000 \
    queue=default priority=8 max-limit=1024000 burst-limit=0 burst-threshold=0 \
    / queue simple
    add name="teste" target-addresses=182.168.31.6/32 dst-address=0.0.0.0/0 \
    interface=all parent=none direction=both priority=8 \
    queue=default-small/default-small limit-at=0/0 max-limit=64000/64000 \
    total-queue=default-small disabled=no
    / ip web-proxy
    set enabled=yes src-address=0.0.0.0 port=3128 hostname="proxy" \
    transparent-proxy=yes parent-proxy=0.0.0.0:0 \
    cache-administrator="webmaster" max-object-size=4096KiB cache-drive=system \
    max-cache-size=unlimited max-ram-cache-size=unlimited
    / ip web-proxy access
    add dst-port=23-25 action=deny comment="block telnet & spam e-mail relaying" \
    disabled=no
    / ip web-proxy cache
    add url=":cgi-bin \\?" action=deny comment="don't cache dynamic http pages" \
    disabled=no
    Amigo, vendo as sua regras só tem apenas as que o alexandre correia postou, se ta funcionado o cache nessa versão maravilha pq no meu server não funcionou até marca os pacotes mais não desce a full. Pesquisando no wink do mikrotik descobri umas regras e juntei com as do alexandre foi então que funcionou, que foi as que postei.
    Agora enm relação a teste de velocidade tipo rjnet acho que ele vai marcar a mais do que o deficido na queue do cliente devido o pagina já esta em cache.
    aqui testo da seguinte maneira, faço um download,a primeira vez ele desce em media de 30 a 60 kbps depois desce a entre 600 kbps a 1,98 mbps.
    Grato.
  2. #14
    Citação Postado originalmente por Josafapalmas Ver Post
    Grato.
    Agora faça um teste de velocidade em qualquer velocímetro e verá que o seu link também está a full...
  3. #15
    Citação Postado originalmente por Roberto21 Ver Post
    Roberto, faço o teste de velocidade realmente ele marca o link full, mas tenho 50 cliente definidos em 64k/128k geralmente fica uns 30 a 36 online e não tenho problema com lentidão.
    Agora tenho visto que vc participa bastante do forum, fiz uns teste aqui da seguinte maneira. Instalei o IPCOP em uma maquina configurei funciona beleza, ele já faz cache-full a diferença que ele não controla banda, aí coloquei uma router com mk em bridge e coloquei as regras do alexandre correia forward mas não passa. na rede cabeada desce a full tudo que esta em cache, mas na rede wireless não desce nada.
    Grato.
  4. #16
    Padrão Memoria baixando conforme o uso do mk
    Esse vai para os colegas que não conseguiram fazer funcionar na versão 2.9.27.
    add chain=output protocol=tcp src-port=3128 content="X-Cache: HIT" action=mark-connection new-connection-mark=squid-connection-HIT passthrough=yes \
    add chain=output connection-mark=squid-connection-HIT action=mark-packet new-packet-mark=squid-packet-HIT passthrough=no comment="" disabled=no
    add chain=prerouting in-interface=Cliente src-address=172.16.0.0/16 action=mark-packet new-packet-mark=test-up passthrough=no comment="UP TRAFFIC" \
    disabled=no
    add chain=forward src-address=172.16.0.0/16 action=mark-connection new-connection-mark=test-conn passthrough=yes comment="CONN-MARK" disabled=no
    add chain=forward in-interface=Link internet connection-mark=test-conn action=mark-packet new-packet-mark=test-down passthrough=no comment="DOWN-DIRECT \
    CONNECTION" disabled=no
    add chain=output out-interface=Cliente dst-address=172.16.0.0/16 action=mark-packet new-packet-mark=test-down passthrough=no comment="DOWN-VIA PROXY
    disabled=no
    / queue tree
    add name="downstream" parent=Cliente packet-mark=test-down limit-at=1024000 queue=default priority=1 max-limit=1024000 burst-limit=0 burst-threshold=0 \
    add name="upstream" parent=global-in packet-mark=test-up limit-at=512000 queue=default priority=1 max-limit=512000 burst-limit=0 burst-threshold=0 \
    add name="Cache-full" parent=global-out packet-mark=squid-packet-HIT limit-at=2000000 queue=default priority=8 max-limit=2000000 burst-limit=0 \
    Amigo, a regra aqui ta funcionando beleza, mais apos implementar essa regra do cache full no meu mk, percebi q a cada tempo, a memoria q tenho no mk vai baixando, isso ate q ela fique em torno de 20 mb, ate entao eu limpar o cache e reiniciar o mk p RAM ta voltando ao normal q é 460mb +/-, vc sabe o q pode ser isso?
    Abraços.
  5. #17
    Moderador Avatar de minelli
    Aug 2006
    Padrão Ram no Proxy
    Olá Vanderlei sim ele realmente vai comendo a ram conforme aumenta o cache, mas vc pode limitar o qt de ram ele pode consumir em web-proxy settings em Maximum Ram Cache Size.
  6. #18
    Padrão cache full na versão 2.9.27
    / ip firewall nat
    add chain=dstnat in-interface=Cliente protocol=tcp dst-port=80 action=redirect \to-ports=3128 comment="" disabled=no
    add chain=output protocol=tcp src-port=3128 content="X-Cache: HIT" \action=mark-connection new-connection-mark=squid-connection-HIT \
    add chain=output connection-mark=squid-connection-HIT action=mark-packet \ new-packet-mark=squid-packet-HIT passthrough=yes comment="" disabled=no
    / queue tree
    add name="Cache-full" parent=global-out packet-mark=squid-packet-HIT \ limit-at=100M queue=default priority=8 max-limit=100M burst-limit=0 \burst-threshold=0 burst-time=0s disabled=no
    / ip web-proxy
    cache-administrator=" webmaster" max-object-size=700000000KiB cache-drive=system \ max-cache-size=unlimited max-ram-cache-size=unlimited
    No web-proxy é só aumentar a capacidade do "max-object-size" para 700MB (significa que qualquer arquivo com até 700MB ficará no cache para baixar a full).
