    Padrão ProFTP não acessa nem como root
    Olá amigos,
    Estou com um probleminha instalei o proftp e rodou sem nenhum problema inicia normalmente....ate ai ok
    o problema e quando vou me conectar quando pede login e senha eu digito root e usuario normal nenhum acessa mesmo o root estando habilitado....o que pode ser...ta rodando sob FreeBSD
    Os arquivos de log estão vazio.
    e ele aparentemente esta bom pelo menos inicia so nao loga.
    vou postar como esta a config dele...pode ser algo que esteja errado ne.
    Código :
    host1# vi proftpd.conf
    # For more informations about Proftpd configuration
    # look at : [URL="http://www.proftpd.org/"]The ProFTPD Project: Home[/URL]
    # This is a basic ProFTPD configuration file (rename it to
    # 'proftpd.conf' for actual use.  It establishes a single server
    # and a single anonymous login.  It assumes that you have a user/group
    # "nobody" and "ftp" for normal operation and anon.
    ServerName                      "ProFTPD Default Installation"
    ServerType                      standalone
    DefaultServer                   on
    ScoreboardFile          /var/run/proftpd.scoreboard
    # Port 21 is the standard FTP port.
    Port                            21
    # Umask 022 is a good standard umask to prevent new dirs and files
    # from being group and world writable.
    Umask                           022
    # To prevent DoS attacks, set the maximum number of child processes
    # to 30.  If you need to allow more than 30 concurrent connections
    # at once, simply increase this value.  Note that this ONLY works
    # in standalone mode, in inetd mode you should use an inetd server
    # that allows you to limit maximum number of processes per service
    # (such as xinetd).
    MaxInstances                    30
    CommandBufferSize       512
    # Set the user and group under which the server will run.
    User                            nobody
    Group                           nogroup
    # To cause every FTP user to be "jailed" (chrooted) into their home
    # directory, uncomment this line.
    DefaultRoot ~
    # Normally, we want files to be overwriteable.
    AllowOverwrite          on
    # Bar use of SITE CHMOD by default
    #<Limit SITE_CHMOD>
    #  DenyAll
    #</Limit>
    # A basic anonymous configuration, no upload directories.  If you do not
    # want anonymous users, simply delete this entire <Anonymous> section.
    # Uncomment lines with only one # to allow basic anonymous access       #
    #<Anonymous ~ftp>
    #   User                                ftp
    #   Group                               ftp
      ### We want clients to be able to login with "anonymous" as well as "ftp"
      UserAlias                     anonymous ftp
      ### Limit the maximum number of anonymous logins
      # MaxClients                  10
      ### We want 'welcome.msg' displayed at login, and '.message' displayed
      ### in each newly chdired directory.
      # DisplayLogin                        welcome.msg
      # DisplayFirstChdir           .message
      ### Limit WRITE everywhere in the anonymous chroot
      # <Limit WRITE>
      #   DenyAll
      # </Limit>
    #</Anonymous>
