    uma duvida que tenho ...
    tem algum lugar no winbox que permita copiar as configurações full?
    Citação Postado originalmente por paulojrandrade Ver Post
    Obrigado por responder Clecio, bom irei te mandar minha configuração full.... os comandos todos peguei aqui no forum.
    / ip firewall mangle
    add chain=output protocol=tcp src-port=3128 content="X-Cache: HIT" \
    action=mark-connection new-connection-mark=proxyfull passthrough=yes \
    comment="PROXY FULL" disabled=no
    add chain=output connection-mark=proxyfull action=mark-packet \
    new-packet-mark=proxyfull passthrough=yes comment="" disabled=no
    add chain=output connection-mark=proxyfull action=return comment="" \
    disabled=no
    add chain=prerouting p2p=all-p2p action=mark-connection \
    new-connection-mark=P2P-Conexao passthrough=yes comment="CONTROLE P2P" \
    disabled=no
    add chain=prerouting protocol=tcp p2p=all-p2p connection-limit=40,32 \
    action=mark-connection new-connection-mark=P2P-Conexao-Limite \
    add chain=prerouting connection-mark=P2P-Conexao action=mark-packet \
    new-packet-mark=P2P-Pacotes passthrough=no comment="" disabled=no
    add chain=prerouting connection-mark=P2P-Conexao-Limite action=mark-packet \
    add chain=prerouting protocol=udp dst-port=5060 action=mark-connection \
    new-connection-mark=voip_in passthrough=yes comment="VOIP-IN" disabled=no
    add chain=prerouting connection-mark=voip_in action=mark-packet \
    new-packet-mark=VOIP_IN passthrough=yes comment="" disabled=no
    add chain=prerouting protocol=udp src-port=5060 action=mark-connection \
    new-connection-mark=voip_out passthrough=yes comment="VOIP-OUT" \
    disabled=no
    add chain=prerouting connection-mark=voip_out action=mark-packet \
    new-packet-mark=VOIP_OUT passthrough=yes comment="" disabled=no
    / ip firewall nat
    add chain=srcnat src-address=192.168.1.0/24 action=masquerade comment="masquerade hotspot \
    network" disabled=no
    / ip firewall filter
    add chain=virus protocol=tcp dst-port=445 action=drop comment="bloqueio de \
    VIRUS conhecidos" disabled=no
    add chain=input in-interface=Net protocol=tcp dst-port=3128 action=drop \
    comment="bloqueia Xeretas" disabled=no
    / ip hotspot
    add name="hotspot1" interface=Lan address-pool=hs-pool-1 profile=hsprof1 idle-timeout=5m \
    keepalive-timeout=none addresses-per-mac=2 disabled=no
    / ip hotspot service-port
    set ftp ports=21 disabled=no
    / ip hotspot profile
    set default name="default" hotspot-address=0.0.0.0 dns-name="" html-directory=hotspot \
    rate-limit="" http-proxy=0.0.0.0:0 smtp-server=0.0.0.0 login-by=cookie,http-chap \
    http-cookie-lifetime=3d split-user-domain=no use-radius=no
    add name="hsprof1" hotspot-address=192.168.1.1 dns-name="hotspot.arnetms.com.br" \
    html-directory=hotspot rate-limit="" http-proxy=0.0.0.0:0 smtp-server=0.0.0.0 \
    login-by=cookie,http-chap,http-pap http-cookie-lifetime=3d split-user-domain=no \
    use-radius=no
    / ip hotspot user
    add name="admin" password="XXXXX" profile=default comment="" disabled=no
    add server=hotspot1 name="paulo" password="XXXXX" profile=640k comment="" disabled=no
    / ip hotspot user profile
    set default name="default" idle-timeout=none keepalive-timeout=2m status-autorefresh=1m \
    shared-users=1 transparent-proxy=yes open-status-page=always advertise=no
    add name="160k" address-pool=hs-pool-1 idle-timeout=none keepalive-timeout=2m \
    status-autorefresh=1m shared-users=1 rate-limit="60k/160k" transparent-proxy=no
    add name="320k" address-pool=hs-pool-1 idle-timeout=none keepalive-timeout=2m \
    status-autorefresh=1m shared-users=1 rate-limit="80k/320k" transparent-proxy=no
    add name="640k" address-pool=hs-pool-1 idle-timeout=none keepalive-timeout=2m \
    status-autorefresh=1m shared-users=1 rate-limit="120k/640k" transparent-proxy=no
    / ip web-proxy
    set enabled=yes src-address=0.0.0.0 port=3128 hostname="proxy" transparent-proxy=yes parent-proxy=0.0.0.0:0 \
    cache-administrator="webmaster" max-object-size=20000KiB cache-drive=secondary-master max-cache-size=unlimited \
    max-ram-cache-size=393216KiB
    / ip web-proxy access
    add dst-port=23-25 action=deny comment="block telnet & spam e-mail relaying" disabled=no
    / ip web-proxy cache
    add url=":cgi-bin \\?" action=deny comment="don't cache dynamic http pages" disabled=no
    add url="youtube.com*" action=allow comment="youtube" disabled=no
    add url="orkut.com*" action=allow comment="orkut" disabled=no
    add url="video.youtube.com*" action=allow comment="videos" disabled=no
    Essa é minha configuração, unica q encurtei é o bloquio de virus q peguei aqui no forum.
    Obrigado desde já pela força
  2. #8
    Amigo vc pode exportar td as configurações do seu mikrotik pelo New Terminal com o comando export file=nomedoarquivo
    Clecio
    Citação Postado originalmente por cynernet Ver Post
    Última edição por cleciorodrigo; 11-05-2008 às 17:42.
  3. #9
    obrigado amigão..
    mais qual seria o nome do arquivo ?
    Citação Postado originalmente por cleciorodrigo Ver Post
    Clecio
    Última edição por cynernet; 11-05-2008 às 18:11.
  4. #10
    Amigo usando o comando export vc exporta tds as configurações do seu mikrotik em um aquivo que vc define o NOME
    Menu New Terminal
    Clecio
    obrigado amigão..
  5. #11
    Exclamation
    Bom dia Clecio, bem fiz oq tu falou para fazer, fiz testes, muitos testes, e notei muita lentidão, e ao fazer download... tipo o emule e esta fazendo download na velocidade do link e nao da rede lan... estranho hein... ? Q podera de ser ??
  6. #12
    galera tenho as mesmas configurações.... e meu cache full so funciona quando eu configuro o navegador para navegar pelo proxy alguma sugestão?
