Página 6 de 9 PrimeiroPrimeiro ... 23456789 ÚltimoÚltimo
    Citação Postado originalmente por djjean2006 Ver Post
    balanciamento
    / ip firewall mangle
    add chain=prerouting in-interface=ether1 connection-state=new nth=3,1,0 action=mark-connection new-connection-mark=odd passthrough=yes comment="LB Odd" disabled=no
    add chain=prerouting in-interface=ether1 connection-mark=odd action=mark-routing new-routing-mark=odd passthrough=no comment="Odd LB" disabled=no
    add chain=prerouting in-interface=ether1 connection-state=new nth=3,1,1 action=mark-connection new-connection-mark=even passthrough=yes comment="LB Even" disabled=no
    add chain=prerouting in-interface=ether1 connection-mark=even action=mark-routing new-routing-mark=even passthrough=no comment="Even LB" disabled=no
    add chain=prerouting in-interface=ether1 connection-state=new nth=3,1,2 action=mark-connection new-connection-mark=odd1 passthrough=yes comment="LB Odd1" disabled=no
    add chain=prerouting in-interface=ether1 connection-mark=odd1 action=mark-routing new-routing-mark=odd1 passthrough=no comment="Odd LB1" disabled=no
    add chain=prerouting in-interface=ether1 connection-state=new nth=3,1,3 action=mark-connection new-connection-mark=even1 passthrough=yes comment="LB Even1" disabled=no
    add chain=prerouting in-interface=ether1 connection-mark=even1 action=mark-routing new-routing-mark=even1 passthrough=no comment="Even LB1" disabled=no
    os modems
    / ip firewall nat
    add chain=srcnat connection-mark=even action=src-nat to-addresses=192.168.1.1 to-ports=0-65535 comment="LB Redirect Even" disabled=no
    add chain=srcnat connection-mark=odd action=src-nat to-addresses=192.168.2.1 to-ports=0-65535 comment="LB Redirect Odd" disabled=no
    add chain=srcnat connection-mark=even1 action=src-nat to-addresses=192.168.3.1 to-ports=0-65535 comment="LB Redirect Even1" disabled=no
    add chain=srcnat connection-mark=odd1 action=src-nat to-addresses=192.168.4.1 to-ports=0-65535 comment="LB Redirect Odd1" disabled=no
    e a net lembrando que o modem padão é o 192.168.1.1 que vai ser o principal
    / ip route
    add dst-address=0.0.0.0/0 gateway=192.168.1.1 scope=255 target-scope=10 routing-mark=even comment="LB Route Odd" disabled=no
    add dst-address=0.0.0.0/0 gateway=192.168.2.1 scope=255 target-scope=10 routing-mark=odd comment="LB Route Odd" disabled=no
    add dst-address=0.0.0.0/0 gateway=192.168.3.1 scope=255 target-scope=10 routing-mark=even1 comment="LB Route Odd" disabled=no
    add dst-address=0.0.0.0/0 gateway=192.168.4.1 scope=255 target-scope=10 routing-mark=odd2 comment="LB Route Odd" disabled=no
    add dst-address=0.0.0.0/0 gateway=192.168.1.1 scope=255 target-scope=10 comment="LB Route No Mark" disabled=no
    não esqueça de agradecer
    obrigado
    Otimo topico irmão, voce poderia me ajudar com o meu loadbalace eu quero usar dois Adsl no meu serve.
    Ele esta com autentição para os usuarios e o IP e 10.0.0.2 modem 01 e 10.0.0.3 modem 02, ele tem que esta roteados ou nao?
    Muito grato Deus te faça feliz.
  2. #32
    Citação Postado originalmente por lucart Ver Post
    Obrigado amigo!
    Os IPS dos 4 modens são o seguinte:
    Modem 1 Adsl 2.272mb 192.168.1.1
    Modem 2 Adsl 2.272mb 192.168.2.1
    Modem 3 Adsl 2.272mb 192.168.3.1
    Modem 4 Adsl 1024mb 192.168.4.1
    Interface de Rede Local 192.168.0.1/24
    Obs. O link 1 fica vairando de 2 a 4mb e por isso coloquei ele a 2mb.
    Obrigado!
    Amigao, quantos clientes vc consegue atender com esses 4 links???
  3. #33
    Citação Postado originalmente por froyer Ver Post
    Exatamente....
    No mangle vc marca cada nova conexão e rota com os contadores 3,1,0 / 3,1,1 / 3,1,2 / 3,1,3....
    No Nat vc faz o seguinte:
    chain=srcnat connection-mark=con310 action=src-nat to-addresses=172.16.1.1 to-ports=0-65535
    chain=srcnat connection-mark=con311 action=src-nat to-addresses=172.16.2.1 to-ports=0-65535
    chain=srcnat connection-mark=con312 action=src-nat to-addresses=172.16.3.1 to-ports=0-65535
    chain=srcnat connection-mark=con313 action=src-nat to-addresses=172.16.3.1 to-ports=0-65535
    Esses endereços ips são os endereços que vc atribuiu para cada interface em que está ligado cada link (no meu caso tenho 3 placas de rede, uma para cada link, mas vc pode tbm ligar os 3 links num hub e ligar em uma interface apenas no mkt loadbalance.. a vantagem de vc ter uma placa para cada link é que vc pode monitorar o consumo de cada link independentemente)
    Observe que os contadores nth 312 e 313 estao apontando para a mesma interface 172.16.3.1 (é aqui e depois no /ip route que ele faz o peso 2)...
    Entendeu?
    Abs
    Maravilha Froyer, só faltava isso pra clarear as coisas aki, fiquei matutando muito tempo pra pra achar isso em posts de outros colegas, que a pesar de terem link de velocidades diferentes observei q estão dividindo a carga de forma igual em todos kkk, daí acabei ficando confuso nessa questão.
    Quanto a utilizar uma interface pra cada link, realmente fica fácil de "ver" o consumo de cada um, massss, por outro lado, se eu tiver apenas uma interface com os links ligados pelo switch, posso acreditar tb que o que aparece lá tá pesando igual em todos eles...
    Enfim meu muito obrigado pela contribuição, a cada dia aprendo um pouquinho por aki.
    Grande abraço,
  4. #34
    dougdoidão coloque mais estas regras ai para ficar com os dois modens trabalhando.... deve ser isso que vc quer ver hehe
    / ip route
    add dst-address=16.0.0.0/4 gateway=192.168.1.254 scope=255 target-scope=10 \
    comment="link1" disabled=no
    add dst-address=32.0.0.0/3 gateway=192.168.1.254 scope=255 target-scope=10 \
    add dst-address=64.0.0.0/8 gateway=192.168.1.254 scope=255 target-scope=10 \
    add dst-address=65.0.0.0/8 gateway=192.168.1.254 scope=255 target-scope=10 \
    add dst-address=66.232.99.0/24 gateway=192.168.1.254 scope=255 target-scope=10 \
    add dst-address=64.0.0.0/3 gateway=192.168.1.254 scope=255 target-scope=10 \
    add dst-address=96.0.0.0/8 gateway=192.168.254.254 scope=255 target-scope=10 \
    comment="SITES INTERNACIONAIS" disabled=no
    add dst-address=96.0.0.0/3 gateway=192.168.1.254 scope=255 target-scope=10 \
    add dst-address=128.0.0.0/8 gateway=192.168.254.254 scope=255 target-scope=10 \
    add dst-address=128.0.0.0/3 gateway=192.168.1.254 scope=255 target-scope=10 \
    add dst-address=170.66.0.0/16 gateway=192.168.254.254 scope=255 target-scope=10 \
    comment="link2" disabled=no
    add dst-address=189.38.18.122/32 gateway=192.168.1.254 scope=255 \
    target-scope=10 comment="ABUSAR" disabled=no
    add dst-address=160.0.0.0/3 gateway=192.168.254.254 scope=255 target-scope=10 \
    add dst-address=200.0.0.0/24 gateway=192.168.1.254 scope=255 target-scope=10 \
    add dst-address=200.101.81.0/24 gateway=192.168.254.254 scope=255 target-scope=10 \
    add dst-address=200.128.0.0/16 gateway=192.168.254.254 scope=255 target-scope=10 \
    add dst-address=200.140.120.29/32 gateway=192.168.254.254 scope=255 \
    target-scope=10 comment="MEDIDOR GRATIS" disabled=no
    add dst-address=200.141.254.0/24 gateway=192.168.254.254 scope=255 target-scope=10 \
    add dst-address=200.159.128.189/32 gateway=192.168.254.254 scope=255 \
    target-scope=10 comment="RJ NET" disabled=no
    add dst-address=200.184.179.0/24 gateway=192.168.254.254 scope=255 target-scope=10 \
    add dst-address=200.199.252.68/32 gateway=192.168.254.254 scope=255 \
    target-scope=10 comment="link2" disabled=no
    add dst-address=200.199.252.72/32 gateway=192.168.254.254 scope=255 \
    add dst-address=200.203.191.8/32 gateway=192.168.254.254 scope=255 target-scope=10 \
    add dst-address=200.204.154.42/32 gateway=192.168.254.254 scope=255 \
    add dst-address=200.221.2.45/32 gateway=192.168.254.254 scope=255 target-scope=10 \
    add dst-address=200.221.2.0/24 gateway=192.168.254.254 scope=255 target-scope=10 \
    add dst-address=200.253.251.32/32 gateway=192.168.254.254 scope=255 \
    add dst-address=201.24.134.0/24 gateway=192.168.254.254 scope=255 target-scope=10 \
    add dst-address=201.34.35.0/24 gateway=192.168.254.254 scope=255 target-scope=10 \
    add dst-address=201.38.128.49/32 gateway=192.168.254.254 scope=255 target-scope=10 \
    comment="TESTE LINK2 N REMOVER - Catolica" disabled=no
    add dst-address=201.67.44.177/32 gateway=192.168.1.254 scope=255 \
    target-scope=10 comment="TESTE LINK1 N REMOVER - Catolica" disabled=no
    add dst-address=206.57.4.13/32 gateway=192.168.254.254 scope=255 target-scope=10 \
    comment="MERCADO LIVRE" disabled=no
    add dst-address=207.0.0.0/8 gateway=192.168.254.254 scope=255 target-scope=10 \
    add dst-address=208.65.0.0/24 gateway=192.168.254.254 scope=255 target-scope=10 \
    comment="YOU TUBE" disabled=no
    add dst-address=208.67.0.0/16 gateway=192.168.254.254 scope=255 target-scope=10 \
    comment="GOOGLE" disabled=no
    add dst-address=209.0.0.0/24 gateway=192.168.254.254 scope=255 target-scope=10 \
    comment="ORKUT" disabled=no
    add dst-address=0.0.0.0/0 gateway=192.168.1.254 scope=255 target-scope=10 \
    add dst-address=0.0.0.0/0 gateway=192.168.254.254 distance=2 scope=255 \
    não esquecer de agradecer isso fica bom para todos
    Djjean2006, só pra ver se eu entendi, nesse caso, eu dividir algum tráfego de alguns servidores e enviar cada um para um link específico, isso? E nesse caso eu não precisaria daquelas marcações de pacotes que fiz anteriormente.
    Seria isso? E no caso, o restante não marcado, cai no link principal normalmente.
    ps: Uso autenticação via hotspot para meus clientes.
    Grato.
  5. #35
    Citação Postado originalmente por dougdoidao Ver Post
    Grato.
    correto serão divididos. as marcação são obrigatorias. sim os demais sempre vai cair no principal
  6. #36
    Citação Postado originalmente por iron Ver Post
    Grande abraço,
    De nada amigo.. precisando é só falar...
