Citação Postado originalmente por SgtoMarlthon Ver Post
eu queria que maus pcs recebecem a net com alimitaçao de banda, mas a comunicaçao (jogos e transferencia de arquivos) entre os dois pcs ocorrece na velocidade da lan.
Vendo sua necessidade, vamos fazer uma marcação das portas de compartilhamento do windows e dos jogos no mikrotik, esta é a configuração para deixar as portas navengando a todo vapor:
Abra um terminal e insira estes regra:
Note: muda a faixa de ip para sua.
Regras de firewall
/ip firewall mangle add chain=forward src-address=192.168.100.0/24 protocol=tcp src-port=135-139 dst-port=135-139 action=mark-connection new-connection-mark=tcp-135-139 passthrough=yes
/ip firewall mangle add chain=forward src-address=192.168.100.0/24 protocol=udp src-port=135-139 dst-port=135-139 action=mark-connection new-connection-mark=udp-135-139 passthrough=yes
/ip firewall mangle add chain=forward connection-mark=tcp-135-139 action=mark-packet new-packet-mark=pack-tcp passthrough=yes
/ip firewall mangle add chain=forward connection-mark=udp-135-139 action=mark-packet new-packet-mark=pack-udp passthrough=yes
/ip firewall mangle add chain=forward src-address=192.168.100.0/24 protocol=tcp src-port=445 dst-port=445 action=mark-connection new-connection-mark=tcp-445 passthrough=yes
/ip firewall mangle add chain=forward src-address=192.168.100.0/24 protocol=tcp src-port=445 dst-port=445 action=mark-connection new-connection-mark=udp-445 passthrough=yes
/ip firewall mangle add chain=forward connection-mark=tcp-445 action=mark-packet new-packet-mark=pack-445-tcp passthrough=yes
/ip firewall mangle add chain=forward connection-mark=udp-445 action=mark-packet new-packet-mark=pack-445-udp passthrough=yes
Regras de Queues tree
/queue tree add name="tcp135-in" parent=global-in packet-mark=pack-tcp limit-at=0 queue=default priority=8 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
/queue tree addname="tcp135-out" parent=global-out packet-mark=pack-tcp limit-at=0 queue=default priority=8 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
/queue tree add name="udp135-in" parent=global-in packet-mark=pack-udp limit-at=0 queue=default priority=8 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
/queue tree add name="udp135-out" parent=global-out packet-mark=pack-udp limit-at=0 queue=default priority=8 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
/queue tree add name="tcp-445-in" parent=global-in packet-mark=pack-445-tcp limit-at=0 queue=default priority=8 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
/queue tree add name="tcp445-out" parent=global-out packet-mark=pack-445-tcp limit-at=0 queue=default priority=8 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
/queue tree add name="udp445-in" parent=global-in packet-mark=pack-445-udp limit-at=0 queue=default priority=8 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
/queue tree add name="udp445-out" parent=global-out packet-mark=pack-udp limit-at=0 queue=default priority=8 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
Aqui foram apenas as regra para o compartilhamento, para os jogos, deve-se saber as portas e fazer as mesmas regras.
Dica: Se continuar controlando, mude o forward para prerouting e coloque como endereço de destino o mesmo que no endereço fonte.
