  1. portsnap fetch
    portsnap upgrade
    portupgrade -ai
  2. Não consigo fazer o Proxy rodar como transparente!!!
    oque eu posso ter feito de errado?
    ##Configurações Aplicadas:##
    #cd /usr/local/etc/squid/squid.conf #
    cache_effective_user squid
    cache_effective_group squid
    cache_dir diskd /squid/cache/01 4843 16 64 Q1=16 Q2=8
    cache_dir diskd /squid/cache/02 4843 16 64 Q1=16 Q2=8
    cache_dir diskd /squid/cache/03 4843 16 64 Q1=16 Q2=8
    cache_dir diskd /squid/cache/04 4843 16 64 Q1=16 Q2=8
    cache_dir diskd /squid/cache/05 4843 16 64 Q1=16 Q2=8
    cache_dir diskd /squid/cache/06 4843 16 64 Q1=16 Q2=8
    cache_dir diskd /squid/cache/07 4843 16 64 Q1=16 Q2=8
    cache_access_log /squid/logs/access.log
    cache_log /squid/logs/cache.log
    cache_store_log none
    pid_filename /usr/local/squid/var/logs/squid.pid
    http_port 192.168.x.x 3128 transparent
    emulate_httpd_log on
    icp_port 3130
    cache_peer exemplo-exemplo.exemplo.com.br sibling 3128 3130 round-robin
    dns_nameservers 201.10.128.3 201.10.1.2
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80
    acl Safe_ports port 21
    acl Safe_ports port 443 563
    acl Safe_ports port 70
    acl Safe_ports port 210
    acl Safe_ports port 1025-65535
    acl Safe_ports port 280
    acl Safe_ports port 488
    acl Safe_ports port 591
    acl Safe_ports port 777
    acl java browser Java
    acl java browser java
    acl CONNECT method CONNECT
    http_access allow all
    miss_access allow XXX
    miss_access deny all
    icp_access allow XXX
    icp_access deny all
    visible_hostname exemplo.exemplo.com.br
    logfile_rotate 4
    coredump_dir none
    shutdown_lifetime 20 seconds
    cache_mem 256 MB
    maximum_object_size 1024 MB
    cache_replacement_policy heap LFUDA
    refresh_pattern . 0 20% 10080
    refresh_pattern -i exe$ 0 50% 999999
    refresh_pattern -i zip$ 0 50% 999999
    refresh_pattern -i rar$ 0 50% 999999
    refresh_pattern -i tgz$ 0 50% 999999
    refresh_pattern -i iso$ 0 50% 999999
    refresh_pattern -i msi$ 0 50% 999999
    refresh_pattern -i gif$ 0 50% 999999
    refresh_pattern -i png$ 0 50% 999999
    refresh_pattern -i jpg$ 0 50% 999999
    refresh_pattern -i jpeg$ 0 50% 999999
    refresh_pattern -i asp$ 0 50% 999999
    refresh_pattern -i aspx$ 0 50% 999999
    refresh_pattern -i php$ 0 50% 999999
    refresh_pattern -i jsp$ 0 50% 999999
    refresh_pattern -i bmp$ 0 50% 999999
    refresh_pattern -i swf$ 0 50% 999999
    refresh_pattern -i flv$ 0 50% 999999
    refresh_pattern -i mp3$ 0 50% 999999
    refresh_pattern -i wav$ 0 50% 999999
    refresh_pattern -i wmv$ 0 50% 999999
    refresh_pattern -i wma$ 0 50% 999999
    refresh_pattern -i asf$ 0 50% 999999
    refresh_pattern -i avi$ 0 50% 999999
    refresh_pattern -i mov$ 0 50% 999999
    refresh_pattern -i htm$ 0 50% 999999
    refresh_pattern -i html$ 0 50% 999999
    refresh_pattern -i ico$ 0 50% 999999
    httpd_accel_host virtual
    httpd_accel_port 80
    httpd_accel_with_proxy on
    error_directory /usr/local/etc/squid/errors/Portuguese
    refresh_pattern windowsupdate.com/.*\.(cab|exe|dll|msi) 10080 100% 43200 reload-into-ims
    refresh_pattern download.microsoft.com/.*\.(cab|exe|dll|msi) 10080 100% 43200 reload-into-ims
    refresh_pattern www.microsoft.com/.*\.(cab|exe|dll|msi) 10080 100% 43200 reload-into-ims
    refresh_pattern au.download.windowsupdate.com/.*\.(cab|exe|dll|msi) 4320 100% 43200 reload-into-ims
  3. #cd /usr/src/sys/amd64/conf/GENERIC#
    options SYSVSHM
    options SHMSEG=16
    options SHMMNI=32
    options SHMMAX=2097152
    options SHMALL=4096
    options SYSVMSG
    options MSGMNB=16384
    options MSGMNI=41
    options MSGSEG=2049
    options MSGSSZ=64
    options MSGTQL=2049
    options IPFIREWALL
    options IPFW2
    options IPFIREWALL_VERBOSE
    options IPFIREWALL_VERBOSE_LIMIT=100
    options IPFIREWALL_FORWARD
    options IPDIVERT
    options IPFIREWALL_DEFAULT_TO_ACCEPT
    #cd /etc/rc.conf#
    firewall_enable=”YES”
    firewall_type=”OPEN”
    firewall_quiet=”YES”
    firewall_script=”/etc/ipfw.conf”
    firewall_logging=”NO”
    natd_enable=”YES”
    natd_flags=”-f /etc/natd.conf
    #cd /etc/rc.firewall #
    ipfw add 800 fwd 127.0.0.1,3128 dst-port { 80 or 21 } src-ip 192.168.0.0/24
    ipfw add 810 allow dst-port 3128 dst-port 192.168.0.X src-ip 192.168.0.0/24
    ipfw add 900 deny dst-port 3128
    ${fwcmd} add 60 fwd 127.0.0.1,3128 tcp from 192.168.X.X/24 to any 80 via x10
    case ${firewall_type} in
    [Oo] [Pp] [Ee] [Nn] )
    0100 allow ip from any to any via x10
    0200 deny ip from any to 192.168.0.0/24
    0300 deny ip from 192.168.0.0/24 to any
    65000 allow ip from any to any
    65535 deny ip from any to any
    iptables –t nat –A PREROUTING –I x10 –s 192.168.0.0/24 –p tcp –dport 80 –j REDIRECT –to-port 3128
    *Criei essesarquivosabaixo, não sei se esta certo, existem tantos tutoriais na Internet q pode ser q eu tenha lido o confundido algo.
    #cd /etc/ipfw.conf#
    ipfw –f flush
    ipfw add divert natd via x10
    ipfw add pass all from any to any
    #cd /etc/natd.conf#
    use_sockets yes
    interface x10
    #Quandouso essas linhas de commando o squid diz q é ‘unrecognized’:#
    httpd_accel_port 80
  4. Amigo, essas alteracoes de kernel que voce citou agora, semaforos, systemv, coisas do genero, voce nao precisa mais colocar estaticamente dentro do kernel, voce pode colocar dinamicamente carregando no loader ou sysctl (acho que é no loader).
    Realmente as novas versoes do squid mataram esses HTTP_ACCEL.
    Tire essas diretrizes http_accel e coloque do lado do seu http_port "transparent"
    Exemplo:
    Código :
    http_port 127.0.0.1:3128 transparent
    ou
    Código :
     http_port 3128 transparent
    Teste e veja...
    Saudações,
    Citação Postado originalmente por MassumiX Ver Post
    options SYSVSHM
    options SHMSEG=16
    options SHMMNI=32
    options SHMALL=4096
    options SYSVMSG
    options MSGMNI=41
    options MSGSEG=2049
    options MSGSSZ=64
    options MSGTQL=2049
    options IPFIREWALL
    options IPFW2
    options IPDIVERT
    #cd /etc/rc.conf#
    natd_enable=”YES”
    #cd /etc/ipfw.conf#
    ipfw –f flush
    #cd /etc/natd.conf#
    use_sockets yes
    interface x10
    httpd_accel_port 80
  5. Citação Postado originalmente por GrayFox Ver Post
    Exemplo:
    Código :
    ou
    Código :
    Teste e veja...
    Saudações,
    Fiz as modificações citadas acima mas não funciona como transparente!
    Ae fui ver os logs do cache e aparece essas mensagens:
    "/usr/local/squid/var/logs/squid.pid (1) Operation not permitted"
    "WARNING: could not write pid file"
    "DETECTED DEAD SIBLING: xxx.com.br"
    "WARNING: transparent proxying not supported"
    Aqueles arquivo q criei ipfw, natd estao certos?
    Ow eles tem um local especifico q q eles ja sejam criados na instalação?
    Última edição por MassumiX; 27-11-2008 às 10:42.
  1. Erro na inicialização do drive de video!
    Por renatospereta no fórum Sistemas Operacionais
    Último Post: 22-05-2006, 10:42
  2. Erro na inicialização do Fedora Core
    Por haas no fórum Servidores de Rede
    Último Post: 07-11-2005, 16:59
  3. Erro na inicialização do slack
    Por macinux no fórum Sistemas Operacionais
    Respostas: 6
    Último Post: 05-10-2005, 15:05
  4. erro na inicialização do root
    Por jhonatanw no fórum Servidores de Rede
    Último Post: 04-06-2005, 03:17
  5. Erro na inicializacao do servico
    Por epf no fórum Servidores de Rede
    Respostas: 8
    Último Post: 16-05-2004, 22:56
