  2. #26
    Isso mesmo.
  3. #27
    blz já deixei tudo pronto mas só vou rodar segunda que é quando volto de férias...testo e posto aqui a taxa de download.
  4. #28
    vamos lá..hoje estou na empresa e vou te mostrar o que fiz:
    1)no squid não tinha aquelas linhas para retirar..só essas:
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 4243 563
    acl Safe_ports port 80 21 443 563 70 210 1025-65535
    acl CONNECT method CONNECT
    http_access deny manager
    http_access deny !Safe_ports
    http_access allow localhost
    então adicionei as linhas abaixo no squid.conf
    #CACHE FULL
    refresh_pattern (/cgi-bin/|\?) 0 0% 0
    refresh_pattern . 0 20% 4
    2)na eth1 fiz o que vc pediu e ficou assim:
    #!/bin/bash
    tc qdisc del dev eth1 root
    tc qdisc add dev eth1 root handle 1:0 htb default 50
    #squid
    tc class add dev eth1 parent 1:0 classid 1:1 htb rate 100mbit
    #squid
    tc class add dev eth1 parent 1:1 classid 1:60 htb rate 100mbit prio 1
    tc class add dev eth1 parent 1:1 classid 1:10 htb rate 512kbit ceil 512kbit prio 1 # voip
    tc class add dev eth1 parent 1:1 classid 1:20 htb rate 100kbit ceil 200kbit prio 2 # DNS / ACK / SYN / FIN
    tc class add dev eth1 parent 1:1 classid 1:30 htb rate 250kbit ceil 512kbit prio 3 # Terminal service
    tc class add dev eth1 parent 1:1 classid 1:40 htb rate 128kbit ceil 300kbit prio 4 # HTTP
    tc class add dev eth1 parent 1:1 classid 1:50 htb rate 128kbit ceil 400kbit prio 5 # Geral
    #squid
    tc qdisc add dev eth1 parent 1:60 handle 60: sfq perturb 10
    tc qdisc add dev eth1 parent 1:10 handle 10: sfq perturb 10
    tc qdisc add dev eth1 parent 1:20 handle 20: sfq perturb 10
    tc qdisc add dev eth1 parent 1:30 handle 30: sfq perturb 10
    tc qdisc add dev eth1 parent 1:40 handle 40: sfq perturb 10
    tc qdisc add dev eth1 parent 1:50 handle 50: sfq perturb 10
    #squid
    tc filter add dev eth1 parent 1:0 protocol ip prio 1 u32 match ip dst-address 10.0.1.254 flowid 1:60
    tc filter add dev eth1 parent 1:0 protocol ip prio 1 u32 match ip sport 5060 0xffff flowid 1:10
    tc filter add dev eth1 parent 1:0 protocol ip prio 1 u32 match ip sport 5061 0xffff flowid 1:10
    tc filter add dev eth1 parent 1:0 protocol ip prio 1 u32 match ip sport 10000 0xffff flowid 1:10
    tc filter add dev eth1 parent 1:0 protocol ip prio 1 u32 match ip sport 20000 0xffff flowid 1:10
    tc filter add dev eth1 parent 1:0 protocol ip prio 2 u32 match ip sport 53 0xffff flowid 1:20
    tc filter add dev eth1 parent 1:0 protocol ip prio 3 u32 match ip sport 3389 0xffff flowid 1:30
    tc filter add dev eth1 parent 1:0 protocol ip prio 4 u32 match ip sport 80 0xffff flowid 1:40
    só que está dando erro na hora do start no serviço:
    debian:~# /etc/init.d/redeinterna start
    Illegal "match"
    na eth0 como não alterei nada o serviço levanta normal....
    o que deve ser feito?
    Última edição por lfernandosg; 12-01-2009 às 09:43.
  5. #29
  6. #30
    Faz o seguinte, coloca aqui o script completo, para eu poder testar no meu computador.
