    Edita o arquivo /etc/pam.d/common-password
    muda de: password required pam_unix.so nullok obscure min=4 max=8 md5
    para: password required pam_unix.so nullok min=4 max=8 md5
    e depois redefina a senha novamente
    Citação Postado originalmente por fmeschini Ver Post
    o meu ao invez de "required" estava "requisite". mantive o sequisite e fiz conforme vc falou, quando tentei mudar a senha por asd123 veio a msn:
    passwd: user not know to the underlying authentication module
    passwd: password unchanged
    coloca o conteúdo do seu arquivo aqui por favor...
    Olha ai o danado!!!!
    # /etc/pam.d/common-password - password-related modules common to all services
    # This file is included from other service-specific PAM config files,
    # and should contain a list of modules that define the services to be
    # used to change user passwords. The default is pam_unix.
    # Explanation of pam_unix options:
    # The "nullok" option allows users to change an empty password, else
    # empty passwords are treated as locked accounts.
    # The "md5" option enables MD5 passwords. Without this option, the
    # default is Unix crypt.
    # The "obscure" option replaces the old `OBSCURE_CHECKS_ENAB' option in
    # login.defs.
    # You can also use the "min" option to enforce the length of the new
    # password.
    # See the pam_unix manpage for other options.
    # password requisite pam_unix.so nullok obscure md5
    password requisite pam_unix.so nullok min=4 max=8 md5
    # Alternate strength checking for password. Note that this
    # requires the libpam-cracklib package to be installed.
    # You will need to comment out the password line above and
    # uncomment the next two in order to use this.
    # (Replaces the `OBSCURE_CHECKS_ENAB', `CRACKLIB_DICTPATH')
    # password required pam_cracklib.so retry=3 minlen=6 difok=3
    # password required pam_unix.so use_authtok nullok md5
    # minimally-intrusive inclusion of smbpass in the stack for
    # synchronization. If the module is absent or the passwords don't
    # match, this module will be ignored without prompting; and if the
    # passwords do match, the NTLM hash for the user will be updated
    # automatically.
    password optional pam_smbpass.so nullok use_authtok use_first_pass
    Última edição por leonardo100ck; 20-01-2009 às 11:06.
    Esse problema que vc está tendo se não estou enganado é alguma zica com o modulo PAM, já tentou fazer uma busca na net ? vou tentar achar algo
    Vou ver tambem!!! vlw!!!!
    Re instalei o PAM mas não funcionou!!!
    Citação Postado originalmente por Lincoln Ver Post
    mano...
    so tem que achar o usuario que pode virar root
    faz assim oh
    cat /etc/passwd
    o seu usuario ta la pra uma das finais linhas,
    tenta com um desses usuarios, acho que vc num deve ter muitos!
    da pra alterar a senha sim, mas como vc num vai conseguir logar como root teria que achar o usuario que pode... heheh
    ó o link
    Como recuperar senha no Ubuntu : Led Nerd
    Galera usando este procedimento do link a cima eu entro como root mas não carrega o sistema totalmente!!! fica na tela...
    [email protected](none):/#
    e deveria ser!!!
    [email protected](nomedoservidor)~#
    será que tem como carregar todos os serviços????
    Então cara... esse site que foi passado é o lance do linux single que eu te perguntei lá atrás, server pra vc recuperar a senha do root, entre outras coisas mais.
    otimo!!!
    se vc conseguiu levanatar o seu linux aparecendo isso
    r[email protected](none):/
    siginifica que vc ja subiu como root, agora é só alterar a senha.
    passwd root
    agora brother... vc tem que dar esse comando com os usuarios que vc tem la no seu /etc/passwd
    sudo su
    eu to achando que é o usuario suporte o que pode virar root ve lá!
    primeiro agradecer a vcs fmeschini e lincoln que me tiraram do sufoco!!!!! vc não são macacos gordos mas me quebram um galho grande!!!! galera muito maneira!!!!
    entrei como o fmeschini falou alterei a senha do suporte como o lincoln falou e dei o comando sudo su pimba na gorduchinha sou root novamente...
    agora só tenho que recuperar o Usuario root pq a senha eu alterei mas o usuario não funciona. quando vc digita o nome do usuario root ele nem pede senha ja da erro!!!
    Depois recuperar minha telnet e ssh mais isso eu até já posso fazer pois já tenho meus super poderes de volta!!! heheheheh
    vlw!!! galera !!!!!!!!!!!!!!
    volta lá!!!
  13. #33
    intaum cara...
    ta certo...
    a ideia é não conseguir mesmo.
    No meu Ubuntu tambem não me da esta opção.
    sempre que precisar usar um comando como root tem que usar o sudo na frente mesmo...
    se for em ambiente grafico?
    tipo, se vc usa kde?
    kdesu comando
    se vc usa gnome acho que eh:
    gksu comando
    me corrijam ai se eu estiver errado pessoal!
    ah brother...
    a respeito do seu agradecimento, eu é que fico grato por saber que uma dica nossa ajudou vc ai!
    e que vc lembro de agradacer, heheh
    geralmente a maioria se inscreve no forum recebe uma puta de uma ajuda e some rssrsrsrrsrsr...
  14. #34
    intaum cara...
    ta certo...
    kdesu comando
    gksu comando
    ah brother...
    to me matando no modo texto pq não consegui instalar o kde!!! rsrsrsrsrsrsrs
    é verdade tem gente que é assim mas a esperança na rassa mundana... ops!! Humana continua!! rsrsrsrsr
