  1. root@servidorx-marimba:/home/servidorx# ps -aux |grep squid
    Warning: bad ps syntax, perhaps a bogus '-'? See procps - Frequently Asked Questions (FAQ)
    root 8088 0.0 0.1 3024 684 ? S 13:26 0:00 tail -f /var/log/messages /var/log/squid/access.log
    root 9506 0.0 0.1 4972 648 ? Ss 13:53 0:00 /usr/sbin/squid -D -YC
    proxy 9509 0.0 0.9 7528 4836 ? S 13:53 0:00 (squid) -D -YC
    root 10036 0.0 0.1 3252 808 pts/0 S+ 13:59 0:00 grep squid
    root@servidorx-marimba:/home/servidorx# tail -f /var/log/squid/access.log
    1232777836.814 285 192.168.0.15 TCP_HIT/200 3785 GET http://static1.orkut.com/js/gen/scraps024.js - NONE/- application/x-javascript
    1232777837.039 1214 192.168.0.15 TCP_MISS/200 7523 GET http://www.orkut.com.br/Scrapbook.aspx?p=a - DIRECT/209.85.193.86 text/html
    1232777837.102 61 192.168.0.15 TCP_HIT/200 529 GET http://img1.orkut.com/img/castro/i_reply.gif - NONE/- image/gif
    1232777837.446 343 192.168.0.15 TCP_MISS/200 1510 GET http://img1.orkut.com/images/small/1...2804402/ln.jpg - DIRECT/209.85.193.85 image/jpeg
    1232777839.268 1866 192.168.0.15 TCP_MISS/200 11157 GET http://ll.atdmt.com/b/2NMBZBRAZBGH/B...0_new0202g.gif - DIRECT/65.54.93.163 image/gif
    1232777847.146 1303 192.168.0.15 TCP_MISS/200 12995 GET http://www.orkut.com.br/Home.aspx - DIRECT/209.85.193.86 text/html
    1232777847.844 180430 192.168.0.15 TCP_MISS/504 1487 GET http://www.aresgalaxy.org/ares/home4.php?ver=2.0.9.3030 - DIRECT/66.98.222.3 text/html
    1232777856.394 1255 192.168.0.4 TCP_MISS/200 406 GET http://tpb.tracker.thepiratebay.org/...v6=192.168.0.4 - DIRECT/77.247.176.145 text/plain
    1232777864.847 6319 192.168.0.15 TCP_MISS/301 729 GET Sexo | Vídeos de sexo grátis | Videos porno | Sexo anal - DIRECT/67.228.177.100 text/html
    1232777890.938 60577 192.168.0.15 TCP_MISS/504 1503 GET http://www.hotmail.msn.com/cgi-bin/m...26198652525921 - DIRECT/64.4.33.7 text/html
    onde está meu erro?
  2. ***********************************************************************************************************************
    boot@servidorx-marimba:/home/servidorx# ps -aux |grep squid
  3. Está usando Proxy transparente?
    faça os seguintes passos para começarmos a isolar os problemas.
    1 -
    2 -
    # tail -f /var/log/messages /var/log/squid/access.log
    Posta aqui a saída desses comandos.
    Sds.
    não consigo copiar e colar aki o resultado la do console
  4. Seu proxy não está transparente... vc setou o proxy nas configurações do browser dos clientes ?
    Caso queira deixá-lo transparente é só usar:
    http_port 3129 transparent
    OBS: Se setá-lo transparente tem que remover o proxy na config do browser dos clientes.
    Qualquer dúvida posta aí
  5. Amigo dê uma olhada no meu SQUID.CONF
    visible_hostname servidorx-marimba
    cache_mem 64 MB
    maximum_object_size_in_memory 64 KB
    maximum_object_size 700 MB
    minimum_object_size 0 KB
    cache_swap_low 90
    cache_swap_high 95
    cache_dir ufs /var/spool/squid 2048 16 256
    refresh_pattern . 15 20% 2280
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 21 80 443 563 70 210 280 488 59 777 901 1025-65535
    acl purge method PURGE
    acl CONNECT method CONNECT
    http_access deny manager
    http_access deny purge
    http_access deny !Safe_ports
    acl redelocal src 192.168.0.0/24
    http_access allow localhost
    http_access allow redelocal
    http_access deny all
    como vê ele esta setado pra transparente ...
    MSN e Torrent . estão funcionando .
    oq acontece é q não abre nenhuma pagina de internet nem no mozilla nem no IE.
    ondeu eu errei?
  1. Respostas: 2
    Último Post: 02-08-2006, 13:48
  2. Respostas: 3
    Último Post: 24-06-2005, 10:48
  3. .:Cliente VPN não conecta:.
    Por aprendiz_ce no fórum Servidores de Rede
    Respostas: 33
    Último Post: 17-05-2005, 02:14
  4. Cliente VPN não conecta - Parte II
    Respostas: 8
    Último Post: 11-05-2005, 09:22
  5. Maquina nao conecta na NET
    Por LeoJfa no fórum Servidores de Rede
    Último Post: 20-01-2005, 10:07
