Página 4 de 11 PrimeiroPrimeiro 123456789 ... ÚltimoÚltimo
  1. Citação Postado originalmente por lfernandosg Ver Post
    agora acho que está do jeito que vc passou:
    #ZPH cache FULL
    zph_mode tos
    zph_option 136
    zph_parent 0
    zph_sibling 0
    zph_local 0x60
    e no HTB:
    #!/bin/bash
    tc qdisc del dev eth1 root
    tc qdisc add dev eth1 root handle 1:0 htb default 50
    #----------------------alterar essa linha-------------------
    tc class add dev eth1 parent 1:0 classid 1:1 htb rate 10mbit
    tc class add dev eth1 parent 1:1 classid 1:10 htb rate 512kbit ceil 512kbit prio 1 # voip
    tc class add dev eth1 parent 1:1 classid 1:20 htb rate 100kbit ceil 200kbit prio 2 # DNS / ACK / SYN / FIN
    tc class add dev eth1 parent 1:1 classid 1:30 htb rate 250kbit ceil 512kbit prio 3 # Terminal service
    tc class add dev eth1 parent 1:1 classid 1:40 htb rate 128kbit ceil 300kbit prio 4 # HTTP
    tc class add dev eth1 parent 1:1 classid 1:50 htb rate 128kbit ceil 400kbit prio 5 # Geral
    #--------------adiciona essa classe para receber o tr�fego do zph
    tc class add dev eth1 parent 1: classid 1:60 htb rate 5mbit prio 1 #ZPH
    tc qdisc add dev eth1 parent 1:10 handle 10: sfq perturb 10
    tc qdisc add dev eth1 parent 1:20 handle 20: sfq perturb 10
    tc qdisc add dev eth1 parent 1:30 handle 30: sfq perturb 10
    tc qdisc add dev eth1 parent 1:40 handle 40: sfq perturb 10
    tc qdisc add dev eth1 parent 1:50 handle 50: sfq perturb 10
    tc qdisc add dev eth1 parent 1:60 handle 60: sfq perturb 10
    tc filter add dev eth1 parent 1:0 protocol ip prio 1 u32 match ip sport 5060 0xffff flowid 1:10
    tc filter add dev eth1 parent 1:0 protocol ip prio 1 u32 match ip sport 5061 0xffff flowid 1:10
    tc filter add dev eth1 parent 1:0 protocol ip prio 1 u32 match ip sport 10000 0xffff flowid 1:10
    tc filter add dev eth1 parent 1:0 protocol ip prio 1 u32 match ip sport 20000 0xffff flowid 1:10
    tc filter add dev eth1 parent 1:0 protocol ip prio 2 u32 match ip sport 53 0xffff flowid 1:20
    tc filter add dev eth1 parent 1:0 protocol ip prio 3 u32 match ip sport 3389 0xffff flowid 1:30
    tc filter add dev eth1 parent 1:0 protocol ip prio 4 u32 match ip sport 80 0xffff flowid 1:40
    #-------------e finalmente o filtro que vai classificar o tr�fego e jogar na classe certa
    tc filter add dev eth1 parent 1:0 protocol ip prio 3 u32 match ip protocol 0x6 0xff match ip tos 60 0xff flowid 1:60
    mas os testes continuam com o sent zerado...e baixei um arquivo para testar..limpei o cache do navegador e ele foi baixado na mesma velocidade da internet 49KB/s
    o que pode estar faltando?meu squid é autendicado não sei se isso pode interferir mas acho que não!se puder me ajudar...preciso colocar algo no script da placa externa de rede?
    está assim meu script:
    #!/bin/bash
    tc qdisc del dev eth0 root
    tc qdisc add dev eth0 root handle 1:0 htb default 50
    tc class add dev eth0 parent 1:0 classid 1:1 htb rate 1024kbit
    tc class add dev eth0 parent 1:1 classid 1:10 htb rate 512kbit ceil 512kbit prio 1 # voip
    tc class add dev eth0 parent 1:1 classid 1:20 htb rate 100kbit ceil 200kbit prio 2 # DNS / ACK / SYN / FIN
    tc class add dev eth0 parent 1:1 classid 1:30 htb rate 250kbit ceil 512kbit prio 3 # Terminal service
    tc class add dev eth0 parent 1:1 classid 1:40 htb rate 128kbit ceil 300kbit prio 4 # HTTP
    tc class add dev eth0 parent 1:1 classid 1:50 htb rate 128kbit ceil 400kbit prio 5 # Geral
    tc qdisc add dev eth0 parent 1:10 handle 10: pfifo limit 10
    tc qdisc add dev eth0 parent 1:20 handle 20: sfq perturb 10
    tc qdisc add dev eth0 parent 1:30 handle 30: sfq perturb 10
    tc qdisc add dev eth0 parent 1:40 handle 40: sfq perturb 10
    tc qdisc add dev eth0 parent 1:50 handle 50: sfq perturb 10
    tc filter add dev eth0 parent 1:0 protocol ip prio 1 u32 match ip dport 5060 0xffff flowid 1:10
    tc filter add dev eth0 parent 1:0 protocol ip prio 1 u32 match ip dport 5061 0xffff flowid 1:10
    tc filter add dev eth0 parent 1:0 protocol ip prio 1 u32 match ip dport 10000 0xffff flowid 1:10
    tc filter add dev eth0 parent 1:0 protocol ip prio 1 u32 match ip dport 20000 0xffff flowid 1:10
    tc filter add dev eth0 parent 1:0 protocol ip prio 2 u32 match ip dport 53 0xffff flowid 1:20
    tc filter add dev eth0 parent 1:0 protocol ip prio 3 u32 match ip dport 3389 0xffff flowid 1:30
    tc filter add dev eth0 parent 1:0 protocol ip prio 4 u32 match ip dport 80 0xffff flowid 1:40
    não alterei nada!!
    Veja bem uma coisa:
    60 e 0x60 são coisas diferentes, usam bases diferentes. 60 está expresso em base(10) e 0x60 está expresso em base(16) hexadecimal.
    Então se você puser no squid :
    zph_local 0x60, você tem que colocar também no htb.
  2. Citação Postado originalmente por lfernandosg Ver Post
    #ZPH cache FULL
    zph_mode tos
    zph_option 136
    zph_parent 0
    zph_sibling 0
    zph_local 0x60
    e no HTB:
    #!/bin/bash
    #!/bin/bash
    não alterei nada!!
    Mas você precisa adicionar a regra que filtra o conteudo que vem do cache. se está assim não vai funcionar. Seu script htb está faltando esta linha no final
    perceba o trecho onde vai filtrar o material vindo com a marca (match ip tos 60) está em decimal e não 0x60. E você disse que botou zph_local 0x60. Então você precisa trocar, ou no squid pra ficar zph_local 60 ou no filtro:
    tc filter add dev eth1 parent 1:0 protocol ip prio 3 u32 match ip protocol 0x6 0xff match ip tos 60 0xff flowid 1:60.
    Feito isso , é so botar pra funcionar e vê o trafego na classe sair do zero.
  3. Lembre-se também de criar a classe do Cache full, no exemplo que o amigo te deu você tem que criar a classe 1:60, e setar a velocidade do cache para ela, se for cabo pode colocar 100mbits
    tc class add dev eth0 parent 1:0 classid 1:60 htb rate 100mbit
    recomendo uma classe a parte:
    tc class add dev eth0 parent 1:2 classid 1:2 htb rate 100mbit
    tc filter add dev eth1 parent 1:0 protocol ip prio 3 u32 match ip protocol 0x6 0xff match ip tos 60 0xff flowid 1:2 ......(se no squid estiver 60)
    Dessa maneira o cache full vai ficar a parte do seu controle ai. Essa dica é quente hein!
    Você poderá criar sub-classes da classe 1:2 controlando o conteúdo cache para cada host.
    Se tiver dúvidas recomendo um leitura para você dominar esse esquema de classes de HTB. Este controle na minha opnião é o melhor.
  4. blz..fiz a alteração no squid de 0x60 para 60 agora na placa eth1 eu já tinha colocado a última linha do filtro nos outros scripts que tinha te passado..só não coloquei na eth0:
    #!/bin/bash
    =>olha ela aqui#-------------e finalmente o filtro que vai classificar o tr�fego e jogar na classe certa
    agora na placa eth0:
    #!/bin/bash
    =>está certo?
    tc class add dev eth0 parent 1:2 classid 1:2 htb rate 100mbit prio 1 #ZPH
    =>está certo?
    tc qdisc add dev eth0 parent 1:2 handle 2: sfq perturb 10
    =>está certo?
    tc filter add dev eth0 parent 1:0 protocol ip prio 3 u32 match ip protocol 0x6 0xff match ip tos 60 0xff flowid 1:2
    onde coloquei "está certo?" ainda não sei se está certo...e colouqei o 60 no squid.conf
    como vc pediu mas ela não aparece no sent do eth0 e no sent do eth1 ainda continua zerada...
    class htb 1:60 root leaf 60: prio 1 quantum 62500 rate 5000Kbit ceil 5000Kbit burst 1600b/8 mpu 0b overhead 0b cburst 1600b/8 mpu 0b overhead 0b level 0
    Sent 0 bytes 0 pkt (dropped 0, overlimits 0 requeues 0)
    rate 0bit 0pps backlog 0b 0p requeues 0
    lended: 0 borrowed: 0 giants: 0
    tokens: 2500 ctokens: 2500
    class htb 1:2 root leaf 2: prio 0 quantum 200000 rate 100000Kbit ceil 100000Kbit burst 1600b/8 mpu 0b overhead 0b cburst 1600b/8 mpu 0b overhead 0b level 0
    tokens: 125 ctokens: 125
    desde já agradeço a ajuda!
  5. Citação Postado originalmente por lfernandosg Ver Post
    #!/bin/bash
    #!/bin/bash
    =>está certo?
    =>está certo?
    =>está certo?
    A interface eth0 é a que vai pra internet? se for não vai fazer diferença pois o htb na forma que está configurado só está controlando tráfego de saida. No caso da interface eth1 (download) e , se for o caso eth0 ( upload). Lembrando que se você tiver usando NAT (MASCARADE) não vai ser possível fazer controle de banda com htb a não ser marcando os pacotes -claro - , mesmo porque o seu squid não deverá funcionar pra receber solicitações vindas da internet. Eu acredito pelo menos. Para fazer controle de entrada com o htb você precisaria usar um lance chamado IMQ ou alguma coisa do estilo. Existem algumas opções. Mas isso não vem ao caso.
    altere essa linha de :
    para:
    tc class add dev eth1 parent 1:1 classid 1:60 htb rate 5mbit prio 1 #ZPH
    só mais uma coisa: você ja confirmou o funcionamento do squid? fez testes pra ver se o squid está recebendo mesmo o tráfego que vem da porta 80? Foi feito o redirecionamento da porta 80 pra porta do squid? se você negar o acesso pra todos no squid aparece a mensagem de erro do squid na máquina do cliente?
    Fora isso , parece tudo normal com sua configuraçao, tirando a última linha que mensionei acima era pra estar tudo normal.
    esperimente ai e dê retorno.
    faça um teste assim:
    #tc filter add dev eth1 parent 1:0 protocol ip prio 1 u32 match ip sport 5060 0xffff flowid 1:10
    #tc filter add dev eth1 parent 1:0 protocol ip prio 1 u32 match ip sport 5061 0xffff flowid 1:10
    #tc filter add dev eth1 parent 1:0 protocol ip prio 1 u32 match ip sport 10000 0xffff flowid 1:10
    #tc filter add dev eth1 parent 1:0 protocol ip prio 1 u32 match ip sport 20000 0xffff flowid 1:10
    tc filter add dev eth1 parent 1:0 protocol ip prio 3 u32 match ip protocol 0x6 0xff match ip tos 60 0xff flowid 1:10
    desviando o tráfego pra essa classe 1:10 pra confirmar se o defeito está na configuração e comentando as linhas que vão pra esta classe. As alteraçoes estao em negrito.
  1. Diferença com e sem ZPH
    Por Elliott no fórum Servidores de Rede
    Respostas: 7
    Último Post: 23-04-2008, 13:10
  2. hotspot qual o segredo?
    Por daniloacr no fórum Redes
    Respostas: 6
    Último Post: 11-03-2008, 00:48
  3. zph=tos_hit_tos + squid + htb
    Por megatek no fórum Servidores de Rede
    Respostas: 6
    Último Post: 09-06-2007, 01:15
  4. O segredo que ninguém fala... rssss
    Por adelsonbbg no fórum Servidores de Rede
    Respostas: 7
    Último Post: 06-03-2007, 10:36
  5. Link Dedicado Qual segredo ????
    Por adelsonbbg no fórum Redes
    Respostas: 6
    Último Post: 18-02-2007, 14:06
