  1. segue como está meu /boot/grub/menu.lst
    # menu.lst - See: grub(8), info grub, update-grub(8)
    # grub-install(8), grub-floppy(8),
    # grub-md5-crypt, /usr/share/doc/grub
    # and /usr/share/doc/grub-doc/.
    ## default num
    # Set the default entry to the entry number NUM. Numbering starts from 0, and
    # the entry number 0 is the default if the command is not used.
    # You can specify 'saved' instead of a number. In this case, the default entry
    # is the entry saved with the command 'savedefault'.
    # WARNING: If you are using dmraid do not use 'savedefault' or your
    # array will desync and will not let you boot your system.
    default 0
    ## timeout sec
    # Set a timeout, in SEC seconds, before automatically booting the default entry
    # (normally the first entry defined).
    timeout 3
    ## hiddenmenu
    # Hides the menu by default (press ESC to see the menu)
    hiddenmenu
    # Pretty colours
    #color cyan/blue white/blue
    ## password ['--md5'] passwd
    # If used in the first section of a menu file, disable all interactive editing
    # control (menu entry editor and command-line) and entries protected by the
    # command 'lock'
    # e.g. password topsecret
    # password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/
    # password topsecret
    # examples
    # title Windows 95/98/NT/2000
    # root (hd0,0)
    # makeactive
    # chainloader +1
    # title Linux
    # root (hd0,1)
    # kernel /vmlinuz root=/dev/hda2 ro
    # Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST
    ### BEGIN AUTOMAGIC KERNELS LIST
    ## lines between the AUTOMAGIC KERNELS LIST markers will be modified
    ## by the debian update-grub script except for the default options below
    ## DO NOT UNCOMMENT THEM, Just edit them to your needs
    ## ## Start Default Options ##
    ## default kernel options
    ## default kernel options for automagic boot options
    ## If you want special options for specific kernels use kopt_x_y_z
    ## where x.y.z is kernel version. Minor versions can be omitted.
    ## e.g. kopt=root=/dev/hda1 ro
    ## kopt_2_6_8=root=/dev/hdc1 ro
    ## kopt_2_6_8_2_686=root=/dev/hdc2 ro
    # kopt=root=UUID=736505e3-2540-49f4-a69b-48018c63f8b8 ro apm=off acpi=off noapic nolapic nopcmcia noapci nosmp pnpbios=off nomce pci=nomsi locale=pt_BR
    ## default grub root device
    ## e.g. groot=(hd0,0)
    # groot=736505e3-2540-49f4-a69b-48018c63f8b8
    ## should update-grub create alternative automagic boot options
    ## e.g. alternative=true
    ## alternative=false
    # alternative=true
    ## should update-grub lock alternative automagic boot options
    ## e.g. lockalternative=true
    ## lockalternative=false
    ## additional options to use with the default boot option, but not with the
    ## alternatives
    ## e.g. defoptions=vga=791 resume=/dev/hda5
    # defoptions=quiet splash
    ## should update-grub lock old automagic boot options
    ## e.g. lockold=false
    ## lockold=true
    # lockold=false
    ## Xen hypervisor options to use with the default Xen boot option
    # xenhopt=
    ## Xen Linux kernel options to use with the default Xen boot option
    # xenkopt=console=tty0
    ## altoption boot targets option
    ## multiple altoptions lines are allowed
    ## e.g. altoptions=(extra menu suffix) extra boot options
    ## altoptions=(recovery) single
    # altoptions=(recovery mode) single
    ## controls how many kernels should be put into the menu.lst
    ## only counts the first occurence of a kernel, not the
    ## alternative kernel options
    ## e.g. howmany=all
    ## howmany=7
    # howmany=all
    ## should update-grub create memtest86 boot option
    ## e.g. memtest86=true
    ## memtest86=false
    # memtest86=true
    ## should update-grub adjust the value of the default booted system
    ## can be true or false
    # updatedefaultentry=false
    ## should update-grub add savedefault to the default options
    # savedefault=false
    ## ## End Default Options ##
    title Ubuntu 8.10, kernel 2.6.27-11-generic
    uuid 736505e3-2540-49f4-a69b-48018c63f8b8
    kernel /boot/vmlinuz-2.6.27-11-generic root=UUID=736505e3-2540-49f4-a69b-48018c63f8b8 ro apm=off acpi=off noapic nolapic nopcmcia noapci nosmp pnpbios=off nomce pci=nomsi locale=pt_BR quiet splash
    initrd /boot/initrd.img-2.6.27-11-generic
    quiet
    title Ubuntu 8.10, kernel 2.6.27-11-generic (recovery mode)
    kernel /boot/vmlinuz-2.6.27-11-generic root=UUID=736505e3-2540-49f4-a69b-48018c63f8b8 ro apm=off acpi=off noapic nolapic nopcmcia noapci nosmp pnpbios=off nomce pci=nomsi locale=pt_BR single
    title Ubuntu 8.10, kernel 2.6.27-7-generic
    kernel /boot/vmlinuz-2.6.27-7-generic root=UUID=736505e3-2540-49f4-a69b-48018c63f8b8 ro apm=off acpi=off noapic nolapic nopcmcia noapci nosmp pnpbios=off nomce pci=nomsi locale=pt_BR quiet splash
    initrd /boot/initrd.img-2.6.27-7-generic
    quiet
    title Ubuntu 8.10, kernel 2.6.27-7-generic (recovery mode)
    kernel /boot/vmlinuz-2.6.27-7-generic root=UUID=736505e3-2540-49f4-a69b-48018c63f8b8 ro apm=off acpi=off noapic nolapic nopcmcia noapci nosmp pnpbios=off nomce pci=nomsi locale=pt_BR single
    # Suse<<<<
    title Suse (on /dev/sda3)<<<<
    root (hd0,2)<<<<
    kernel /boot/vmlinux-2.6.27.19-3.2-default i686 ro vga 792<<<<
    initrd /boot/initrd-2.6.27.19-3.2-default<<<<
    # Suse<<<<
    title Suse (on /dev/sda4)<<<<
    root (hd0,3)
    title Ubuntu 8.10, memtest86+
    kernel /boot/memtest86+.bin
    quiet
    ### END DEBIAN AUTOMAGIC KERNELS LIST
    Onde eu >>> setei <<< foi o que eu alterei no /boo/grub/menu.lst
    Só que só entra o Ubuntu o SUSE não entra de jeito maneira alguém sabe como resolver este problema?
    vejam o retorno da sintaxe sfdisk -l -x
    Disp Boot Início Fim Cils Blocos Id Sistema
    /dev/sda1 * 0+ 10442 10443- 83883366 83 Linux
    /dev/sda2 18702 19456 755 6064537+ 5 Estendida
    /dev/sda3 10443 13053 2611 20972857+ 83 Linux
    /dev/sda4 13054 18701 5648 45367560 83 Linux
    /dev/sda5 18702+ 19456 755- 6064506 82 Linux swap / Solaris
    - 18702 18701 0 0 0 Vazia
    Última edição por Jhonn; 24-03-2009 às 20:51.
  1. Dual boot Win7 e Ubuntu 11.10
    Por GuilhermeSilva no fórum Sistemas Operacionais
    Último Post: 19-03-2012, 09:38
  2. Respostas: 3
    Último Post: 09-03-2012, 10:43
  3. Como proceder para ter dual boot com linux e win98...
    Por MORIHIDEKI no fórum Servidores de Rede
    Último Post: 31-05-2005, 20:02
  4. Como mudar a ordem do Dual Boot.
    Por lacierdias no fórum Servidores de Rede
    Último Post: 19-02-2005, 11:27
  5. Respostas: 1
    Último Post: 14-11-2003, 08:26
