  1. Citação Postado originalmente por lelyrock Ver Post
    isso isso isso!rs
    sera q há alguma chance de criar um patch no thunder para isso?
    aproveitando....
    sera que alguem pode me ajudar nesse topico?
    Thunder Cache detalhado - Página 5
    Nao sei se é possivel nao, ai no caso só tentando fazer um plugin pra ver, no site do thunder tem ensinando como fazer um plugin, eu tentei fazer mais nao consegui :s,
    Sobre o topico que você pediu ajuda ja postei alguma coisa la
    Falow abraços
  2. Jul 6 09:10:20 justin kernel: [ 765.912829] ata1.00: status: { DRDY ERR }
    Jul 6 09:10:20 justin kernel: [ 765.912829] ata1.00: error: { UNC }
    Jul 6 09:10:20 justin kernel: [ 765.933961] ata1.00: configured for UDMA/133
    Jul 6 09:10:20 justin kernel: [ 765.933967] ata1: EH complete
    Jul 6 09:10:24 justin kernel: [ 769.654224] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
    Jul 6 09:10:24 justin kernel: [ 769.654224] ata1.00: BMDMA stat 0x24
    Jul 6 09:10:24 justin kernel: [ 769.654224] ata1.00: cmd 25/00:08:b7:0d:0f/00:00:28:00:00/e0 tag 0 dma 4096 in
    Jul 6 09:10:24 justin kernel: [ 769.654224] res 51/40:00:bd:0d:0f/40:00:28:00:00/e0 Emask 0x9 (media error)
    Jul 6 09:10:24 justin kernel: [ 769.654224] ata1.00: status: { DRDY ERR }
    Jul 6 09:10:24 justin kernel: [ 769.654224] ata1.00: error: { UNC }
    Jul 6 09:10:24 justin kernel: [ 770.002100] ata1.00: configured for UDMA/133
    Jul 6 09:10:24 justin kernel: [ 770.002100] ata1: EH complete
    Jul 6 09:10:27 justin kernel: [ 773.268897] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
    Jul 6 09:10:27 justin kernel: [ 773.268897] ata1.00: BMDMA stat 0x24
    Jul 6 09:10:27 justin kernel: [ 773.268897] ata1.00: cmd 25/00:08:b7:0d:0f/00:00:28:00:00/e0 tag 0 dma 4096 in
    Jul 6 09:10:27 justin kernel: [ 773.268897] res 51/40:00:bd:0d:0f/40:00:28:00:00/e0 Emask 0x9 (media error)
    Jul 6 09:10:27 justin kernel: [ 773.268897] ata1.00: status: { DRDY ERR }
    Jul 6 09:10:27 justin kernel: [ 773.268897] ata1.00: error: { UNC }
    Jul 6 09:10:27 justin kernel: [ 773.291928] ata1.00: configured for UDMA/133
    Jul 6 09:10:27 justin kernel: [ 773.291940] sd 0:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE,SUGGEST_OK
    Jul 6 09:10:27 justin kernel: [ 773.291945] sd 0:0:0:0: [sda] Sense Key : Medium Error [current] [descriptor]
    Jul 6 09:10:27 justin kernel: [ 773.291953] Descriptor sense data with sense descriptors (in hex):
    Jul 6 09:10:27 justin kernel: [ 773.291956] 72 03 11 04 00 00 00 0c 00 0a 80 00 00 00 00 00
    Jul 6 09:10:27 justin kernel: [ 773.291974] 28 0f 0d bd
    Jul 6 09:10:27 justin kernel: [ 773.291981] sd 0:0:0:0: [sda] Add. Sense: Unrecovered read error - auto reallocate failed
    Jul 6 09:10:27 justin kernel: [ 773.291988] end_request: I/O error, dev sda, sector 672075197
    Jul 6 09:10:27 justin kernel: [ 773.292034] ata1: EH complete
    Jul 6 09:10:27 justin kernel: [ 773.292120] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
    Jul 6 09:10:27 justin kernel: [ 773.294756] sd 0:0:0:0: [sda] 1465149168 512-byte hardware sectors (750156 MB)
    Jul 6 09:10:27 justin kernel: [ 773.751757] sd 0:0:0:0: [sda] Write Protect is off
    Jul 6 09:10:27 justin kernel: [ 773.751761] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
    Jul 6 09:10:27 justin kernel: [ 773.751795] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
    consegui colocar o Thunder aqui, funcionando perfeitamente, adequei o sistema a minha maquina, tal config como memoria, Espaço em HD e tudo mais, agora surgiu estes erros, alguem pode me dar uma dica? o servidor trava e para de responder qd segue estes erros...
  3. Citação Postado originalmente por raus Ver Post
    Raus, você desativou o orkut do thunder?
    Tenta desativar pode ser o orkut e ve se para
    Falow
  4. Citação Postado originalmente por edcomrocha Ver Post
    Falow
    Orkut desativado desde o principio...
    'fiz umas mudanças depois do post, parou um pouco e voltou com os erros, maquina zerada...
    vou ver q q agilizo por aqui, mais tarde volto a posta se resolver o problema, e quem ja sab o que e e quiser dar uma força, ficarei agradecido.
  5. aqui to usando o orkut ta ok... mas queria usalo somente para fotos de alta resolucao! alguem tem esse plugin alterado?
  1. Respostas: 10
    Último Post: 08-04-2013, 14:07
  2. Mikrotik + Thundercache 6: Limitar cache full por interface
    Por mikrotikuser no fórum Servidores de Rede
    Respostas: 8
    Último Post: 28-02-2011, 13:13
  3. MTCCP - Mikrotik ThunderCache Conlinux Proxy
    Por m4d3 no fórum Servidores de Rede
    Último Post: 20-02-2010, 12:49
  4. Mikrotik + Thundercache
    Por marcostmariano no fórum Redes
    Último Post: 09-10-2009, 06:02
  5. Mikrotik + Thundercache, segundo HD
    Por macewindu no fórum Servidores de Rede
    Último Post: 24-08-2009, 21:34
