    Thumbs down Sendmail
    Senhores.
    Estou tendo um erro no envio de e-mail pelo sendmail. Segue abaixo o log do meu erro.
    May 20 12:03:01 LvsCedro sendmail[3859]: n4KF31NW003859: to=root, delay=00:00:00, xdelay=00:00:00, mailer=local, pri=30000, dsn=2.0.0, stat=Sent
    May 20 12:03:02 LvsCedro sendmail[3855]: n4KF2DSO003853: to=<[email protected]>, ctladdr=<[email protected]> (48/48), delay=00:00:44, xdelay=00:00:33, mailer=esmtp, pri=229422, relay=gmail-smtp-in.l.google.com. [72.14.247.27], dsn=5.0.0, stat=Service unavailable
    May 20 12:03:02 LvsCedro sendmail[3855]: n4KF2DSO003853: n4KF32SO003855: DSN: Service unavailable
    May 20 12:03:02 LvsCedro sendmail[3855]: n4KF32SO003855: to=root, delay=00:00:00, xdelay=00:00:00, mailer=local, pri=30000, dsn=2.0.0, stat=Sent
    Oque eu tenho que fazer para resolver esse problema.
    Obrigado
    você? nada.. o serviço está indisponível no destino. O usuário ([email protected]) existe no destino?
    pode ser também algo momentâneo (serviço indisponivel), o google ultimamente anda meio atrapalhado.
    Citação Postado originalmente por irado Ver Post
    Segue abaixo o erro de log que estou tendo agora amigo
    May 20 15:41:06 LvsCedro sendmail[6450]: n4KIf60V006450: cedrofinances.com.br [127.0.0.1] did not issue MAIL/EXPN/VRFY/ETRN during connection to MTA
    May 20 15:41:06 LvsCedro sendmail[6451]: n4KIf6LU006451: from=apache, size=1332, class=-60, nrcpts=1, msgid=<[email protected]>, [email protected]
    May 20 15:41:06 LvsCedro sendmail[6452]: n4KIf6xZ006452: from=<[email protected]>, size=1477, class=-60, nrcpts=1, msgid=<[email protected]>, proto=ESMTP, daemon=MTA, relay=cedrofinances.com.br [127.0.0.1]
    May 20 15:41:06 LvsCedro sendmail[6451]: n4KIf6LU006451: [email protected], ctladdr=apache (48/48), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=139332, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (n4KIf6xZ006452 Message accepted for delivery)
    May 20 15:41:06 LvsCedro sendmail[6453]: n4KIf6xZ006452: to=<[email protected]>, ctladdr=<[email protected]> (48/48), delay=00:00:00, xdelay=00:00:00, mailer=local, pri=139697, dsn=2.0.0, stat=Sent
    May 20 15:41:06 LvsCedro sendmail[6455]: n4KIf6PZ006455: from=apache, size=989, class=-60, nrcpts=1, msgid=<[email protected]>, [email protected]
    May 20 15:41:06 LvsCedro sendmail[6456]: n4KIf6vx006456: <[email protected]>... User unknown
    May 20 15:41:06 LvsCedro sendmail[6455]: n4KIf6PZ006455: [email protected], ctladdr=apache (48/48), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=138989, relay=[127.0.0.1] [127.0.0.1], dsn=5.1.1, stat=User unknown
    May 20 15:41:06 LvsCedro sendmail[6456]: n4KIf6vx006456: from=<[email protected]>, size=989, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=cedrofinances.com.br [127.0.0.1]
    May 20 15:41:06 LvsCedro sendmail[6455]: n4KIf6PZ006455: n4KIf6Pa006455: DSN: User unknown
    May 20 15:41:06 LvsCedro sendmail[6456]: n4KIf6w1006456: from=<>, size=2634, class=0, nrcpts=1, msgid=<[email protected]>, proto=ESMTP, daemon=MTA, relay=cedrofinances.com.br [127.0.0.1]
    May 20 15:41:07 LvsCedro sendmail[6455]: n4KIf6Pa006455: to=apache, delay=00:00:01, xdelay=00:00:01, mailer=relay, pri=30000, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (n4KIf6w1006456 Message accepted for delivery)
    May 20 15:41:07 LvsCedro sendmail[6457]: n4KIf6w1006456: to=root, delay=00:00:01, xdelay=00:00:00, mailer=local, pri=32850, dsn=2.0.0, stat=Sent
    You have new mail in /var/spool/mail/root
    Não sei como resolver isso
    Obrigado pela ajuda
    bem.. eu já não uso o sendmail há uns 5 anos, mas enfim..
    vamos à miuda:
    <[email protected]> ... User unknown
    diz que o tal ulisses neto não existe aí na cedrofinances.com.br; nada demais, se o cara realmente não existe
    [email protected] está tentando envia essa msg --> talvez vc tenha algum aplicativo no seu apache enviando algo para o tal de ulisses, que (tudo indica) não existe.
    /intervalinho
    se quiser, eventualmente vc cria um aliases pra essa criatura, apontando pra seu próprio zémail (o mais simples, mas ERRADO).
    /end intervalinho
    após isso o MTA desiste de entregar a msg e manda msg de êrro pro root:
    agora ficou mais simples: vc usa o mutt, simplesmente:
    # mutt
    ou vc pode (se quiser) usar o less:
    # less /var/spool/mail/root
    mas é chato pra kct.
    como (acho) vc nunca o usou, devem haver uns trilhões de mensagens lá dentro.
    Ainda continuo tendo erro
    Eu não sei oque fazer mais para isso dar certo
    May 20 18:46:58 LvsCedro sendmail[7302]: n4KLkwjs007302: from=apache, size=1332, class=-60, nrcpts=1, msgid=<[email protected]>, [email protected]
    May 20 18:46:58 LvsCedro sendmail[7303]: n4KLkwZt007303: SYSERR(root): rewrite: excessive recursion (max 50), ruleset canonify
    May 20 18:46:58 LvsCedro sendmail[7302]: n4KLkwjs007302: [email protected], ctladdr=apache (48/48), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=139332, relay=[127.0.0.1] [127.0.0.1], dsn=5.0.0, stat=Service unavailable
    May 20 18:46:58 LvsCedro sendmail[7302]: n4KLkwjs007302: n4KLkwjt007302: DSN: Service unavailable
    May 20 18:46:58 LvsCedro sendmail[7303]: n4KLkwZu007303: SYSERR(root): rewrite: excessive recursion (max 50), ruleset canonify
    May 20 18:46:58 LvsCedro sendmail[7302]: n4KLkwjt007302: to=apache, delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30000, relay=[127.0.0.1], dsn=5.0.0, stat=Service unavailable
    May 20 18:46:58 LvsCedro sendmail[7303]: n4KLkwZu007303: from=<>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=cedrofinances.com.br [127.0.0.1]
    May 20 18:46:58 LvsCedro sendmail[7302]: n4KLkwjt007302: n4KLkwju007302: return to sender: Service unavailable
    May 20 18:46:58 LvsCedro sendmail[7303]: n4KLkwZw007303: from=<>, size=2313, class=0, nrcpts=1, msgid=<[email protected]>, proto=ESMTP, daemon=MTA, relay=cedrofinances.com.br [127.0.0.1]
    May 20 18:46:59 LvsCedro sendmail[7302]: n4KLkwju007302: to=postmaster, delay=00:00:01, xdelay=00:00:01, mailer=relay, pri=30000, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (n4KLkwZw007303 Message accepted for delivery)
    May 20 18:46:59 LvsCedro sendmail[7304]: n4KLkwZw007303: to=root, delay=00:00:01, xdelay=00:00:00, mailer=local, pri=32533, dsn=2.0.0, stat=Sent
    May 20 18:46:59 LvsCedro sendmail[7305]: n4KLkxb4007305: from=apache, size=990, class=-60, nrcpts=1, msgid=<[email protected]>, [email protected]
    May 20 18:46:59 LvsCedro sendmail[7307]: n4KLkxC2007307: SYSERR(root): rewrite: excessive recursion (max 50), ruleset canonify
    May 20 18:46:59 LvsCedro sendmail[7305]: n4KLkxb4007305: [email protected], ctladdr=apache (48/48), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=138990, relay=[127.0.0.1] [127.0.0.1], dsn=5.0.0, stat=Service unavailable
    May 20 18:46:59 LvsCedro sendmail[7305]: n4KLkxb4007305: n4KLkxb5007305: DSN: Service unavailable
    May 20 18:46:59 LvsCedro sendmail[7307]: n4KLkxC3007307: SYSERR(root): rewrite: excessive recursion (max 50), ruleset canonify
    May 20 18:46:59 LvsCedro sendmail[7305]: n4KLkxb5007305: to=apache, delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30000, relay=[127.0.0.1], dsn=5.0.0, stat=Service unavailable
    May 20 18:46:59 LvsCedro sendmail[7307]: n4KLkxC3007307: from=<>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=cedrofinances.com.br [127.0.0.1]
    May 20 18:46:59 LvsCedro sendmail[7305]: n4KLkxb5007305: n4KLkxb6007305: return to sender: Service unavailable
    May 20 18:46:59 LvsCedro sendmail[7307]: n4KLkxC5007307: from=<>, size=2313, class=0, nrcpts=1, msgid=<[email protected]>, proto=ESMTP, daemon=MTA, relay=cedrofinances.com.br [127.0.0.1]
    May 20 18:46:59 LvsCedro sendmail[7305]: n4KLkxb6007305: to=postmaster, delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30000, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (n4KLkxC5007307 Message accepted for delivery)
    May 20 18:46:59 LvsCedro sendmail[7308]: n4KLkxC5007307: to=root, delay=00:00:00, xdelay=00:00:00, mailer=local, pri=32533, dsn=2.0.0, stat=Sent
    Mais erros
    May 20 19:21:09 LvsCedro sendmail[7676]: n4KML8hQ007676: from=apache, size=1316, class=-60, nrcpts=1, msgid=<[email protected]>, [email protected]
    May 20 19:21:10 LvsCedro sendmail[7677]: n4KML96X007677: from=<[email protected]>, size=1455, class=-60, nrcpts=1, msgid=<[email protected]>, proto=ESMTP, daemon=MTA, relay=cedrofinances.com [127.0.0.1]
    May 20 19:21:10 LvsCedro sendmail[7676]: n4KML8hQ007676: [email protected], ctladdr=apache (48/48), delay=00:00:02, xdelay=00:00:01, mailer=relay, pri=139316, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (n4KML96X007677 Message accepted for delivery)
    May 20 19:21:11 LvsCedro sendmail[7679]: n4KMLB5b007679: from=apache, size=991, class=-60, nrcpts=1, msgid=<[email protected]>, [email protected]
    May 20 19:21:12 LvsCedro sendmail[7678]: n4KML96X007677: to=<[email protected]>, ctladdr=<[email protected]> (48/48), delay=00:00:02, xdelay=00:00:01, mailer=local, pri=139663, dsn=2.0.0, stat=Sent
    May 20 19:21:12 LvsCedro sendmail[7681]: n4KMLB5B007681: from=<[email protected]>, size=1088, class=-60, nrcpts=1, msgid=<[email protected]>, proto=ESMTP, daemon=MTA, relay=cedrofinances.com [127.0.0.1]
    May 20 19:21:12 LvsCedro sendmail[7679]: n4KMLB5b007679: [email protected], ctladdr=apache (48/48), delay=00:00:01, xdelay=00:00:01, mailer=relay, pri=138991, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (n4KMLB5B007681 Message accepted for delivery)
    May 20 19:21:13 LvsCedro sendmail[7683]: n4KMLB5B007681: to=<[email protected]>, ctladdr=<[email protected]> (48/48), delay=00:00:01, xdelay=00:00:01, mailer=esmtp, pri=229088, relay=mail.cedrofinances.com.br. [189.38.52.100], dsn=5.1.3, stat=User unknown
    May 20 19:21:13 LvsCedro sendmail[7683]: n4KMLB5B007681: n4KMLD5B007683: DSN: User unknown
    May 20 19:21:14 LvsCedro sendmail[7683]: n4KMLD5B007683: to=root, delay=00:00:01, xdelay=00:00:00, mailer=local, pri=30000, dsn=2.0.0, stat=Sent
    A conta [email protected] existe no dominio cedrofinances.com.br agora nao sei pq ele nao envia
