  1. Citação Postado originalmente por info24hs Ver Post
    Isso ta parecendo configuração.. certifique-se que esteja configurado de acordo como tem que ser as suas interfaces, rotas, dhcp, etc... se possível coloca ai teus arquivos..
    Vou postar meu squid.conf e smb.conf, se faltar algum a mais por favor avisar.
    SQUID.CONF
    http_port 192.168.10.1:3128
    visible_hostname smb
    cache_mem 64 MB
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    #maximum_object_size_in_memory 64 KB
    #maximum_object_size 12288 KB
    #minimum_object_size 0 KB
    cache_swap_low 90
    cache_swap_high 95
    cache_dir ufs /proxy/cache 5000 16 256
    cache_access_log /proxy/log/access.log
    cache_log /proxy/log/cache.log
    cache_store_log /proxy/log/store.log
    cache_effective_user proxy
    cache_effective_group proxy
    refresh_pattern ^ftp: 60 20% 2280
    refresh_pattern ^gopher: 60 0% 2280
    refresh_pattern . 60 20% 2280
    refresh_pattern au.download.windowsupdate.com/.*\.(cab|exe|msi) 10080 100% 43200 reload-into-ims
    refresh_pattern download.microsoft.com/.*\.(cab|exe|msi) 10080 100% 43200 reload-into-ims
    refresh_pattern msgruser.dlservice.microsoft.com/.*\.(cab|exe|msi) 10080 100% 43200 reload-into-ims
    refresh_pattern windowsupdate.com/.*\.(cab|exe|msi) 10080 100% 43200 reload-into-ims
    refresh_pattern www.microsoft.com/.*\.(cab|exe|msi) 10080 100% 43200 reload-into-ims
    emulate_httpd_log off
    cache_mgr informatica@multmoldes.com.br
    dns_nameservers 192.168.10.1
    #dns_nameservers 201.10.120.3
    unlinkd_program /usr/lib/squid/unlinkd
    #-------------AUTENTICACAO-----------------
    auth_param basic program /usr/lib/squid/ncsa_auth /etc/squid/squid.passwd
    auth_param basic children 5
    auth_param basic realm Digite seu usuario e senha
    auth_param basic casesensitive on
    #------------ACL's-------------------------
    acl ncsa_users proxy_auth REQUIRED
    acl bloqueados url_regex '/samba/administrativo/Servidor/Bloqueados/Bloqueados.txt'
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80
    acl Safe_ports port 21
    acl Safe_ports port 443 563
    acl Safe_ports port 70
    acl Safe_ports port 210
    acl Safe_ports port 1025-65535
    acl Safe_ports port 280
    acl Safe_ports port 488
    acl Safe_ports port 591
    acl Safe_ports port 777
    acl redelocal src 192.168.10.0/24
    acl CONNECT method CONNECT
    acl outros proxy_auth -i "/etc/squid/outros"
    acl outrossites dstdomain "/etc/squid/outrossites"
    acl nod32 proxy_auth -i "/etc/squid/nod32"
    acl nod32_sites dstdomain "/etc/squid/nod32_sites"
    #------------HTTP_ACCESS-------------------
    http_access deny bloqueados
    http_access deny outros !outrossites
    http_access deny nod32 !nod32_sites
    http_access allow ncsa_users
    http_access deny manager
    http_access deny !Safe_ports
    http_access allow redelocal
    http_access deny all
    icp_access allow redelocal
    icp_access deny all
    SMB.CONF:
    #----------GLOBAL SETTINGS----------------
    [global]
    workgroup = multmoldes
    domain logons = yes
    logon script = %U.bat
    announce as = NT Server
    netbios name = smb
    server string =
    interfaces = eth1
    guest account = nobody
    log file = /var/log/samba/log.%m
    log level = 2
    max log size = 1000
    syslog = 0
    security = user
    encrypt passwords = true
    socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
    os level = 99
    domain master = yes
    preferred master = yes
    wins support = yes
    dns proxy = no
    name resolve order = lmhosts host wins bcast
    preserve case = yes
    short preserve case = yes
    unix password sync = yes
    admin users = administrator,sebastian,root,eliseu
    passwd program = /usr/bin/passwd %u
    obey pam restrictions = yes
    printcap name = /dev/null
    load printers = no
    printing = bsd
    #client plaintext auth = no
    #level2 oplocks = True
    #map acl inherit = Yes
    #nt acl support = yes
    #----------------SHARE DEFINITIONS---------------
    [netlogon]
    comment = Network Logon Service
    path = /samba/netlogon
    browsable = no
    writable = no
    share modes = no
    [Administrativo]
    comment = Administrativo
    path = /samba/administrativo
    writable = yes
    guest ok = no
    browseable = no
    #force directory mode = 0775
    #force create mode = 0775
    inherit permissions = yes
    inherit acls = yes
    valid users = @users, administrator
    [Fabricacao]
    comment = Fabricacao
    path = /samba/fabricacao
    writable = yes
    guest ok = no
    browseable = no
    inherit acls = yes
    valid users = administrator, @users
    [CartaoPonto]
    comment = Cartao Ponto
    path = /samba/cartaoponto
    writable = yes
    guest ok = no
    browseable = no
    valid users = administrator,luciene,ligia,eliseu,sebastian,edmilson,claudio,waldir,Programador1,dieison,leandro
    [Maxsig]
    comment = MaxSIG
    path = /samba/maxsig
    writable = yes
    force directory mode = 770
    guest ok = no
    browseable = no
    force create mode = 0770
    valid users = administrator,eliseu,sebastian,eliane,bruno,almoxarife,edmilson,joelci,delmar,eloi,pedro,leandro,treinamento,luciene,ligia,claudio,waldir,dieison,recepcionista,metrologista,everton,antonio,note-temp
    [Publico]
    path = /samba/publico
    comment = Publico
    writable = yes
    public = yes
    guest ok = yes
    veto files = /*.mp3/*.wmv/*.wma/*.ogg/*.mpg/*.mpeg/*.avi/*.wav/
    force directory mode = 777
    force create mode = 0777
    valid users = @users,administrator
    [Backup]
    path = /backup
    writable = yes
    guest ok = no
    browseable = no
    valid users = administrator,eliseu,sebastian,leandro,evaldo,rodrigo
    [Backup2]
    path = /backup2
    writable = yes
    guest ok = no
    browseable = no
    [SARG]
    path = /proxy/sarg
    writable = no
    guest ok = no
    browseable = no
    valid users = administrator,sebastian,eliseu
    [Projetos]
    path = /samba/projetos
    writeable = yes
    guest ok = no
    browseable = no
    valid users = administrator,leandro,evaldo,rodrigo,claudio,eliseu,sebastian,dieison,waldir,edmilson,hilber,treinamento,everton,eletroafio,Programador1,Programador2,metrologista,joelci,antonio,fabrica,almoxarife
  2. manda o arquivo interfaces, e o config do dhcp
  3. dns_nameservers 192.168.10.1
    isso nao precisa deixa ele pegar automatico..
  4. Citação Postado originalmente por info24hs Ver Post
    O Servidor DHCP tá desativado, mas mando o .conf dele igual:
    INTERFACES:
    # This file describes the network interfaces available on your system
    # and how to activate them. For more information, see interfaces(5).
    # The loopback network interface
    auto lo
    iface lo inet loopback
    auto eth0
    iface eth0 inet static
    address 201.2.136.74
    netmask 255.255.255.248
    network 201.2.136.72
    broadcast 201.2.136.79
    gateway 201.2.136.73
    auto eth1
    iface eth1 inet static
    address 192.168.10.1
    netmask 255.255.255.0
    broadcast 192.168.10.255
    network 192.168.10.0
    DHCPD.CONF:
    ddns-updates on;
    ddns-domainname "multmoldes";
    ddns-update-style ad-hoc;
    allow unknown-clients;
    default-lease-time 86400;
    max-lease-time 172800;
    option domain-name "multmoldes";
    option domain-name-servers 192.168.10.1;
    option netbios-name-servers 192.168.10.1;
    option netbios-dd-server 192.168.10.1;
    option netbios-node-type 8;
    authoritative;
    subnet 192.168.10.0 netmask 255.255.255.0 {
    range 192.168.10.210 192.168.10.250;
    option subnet-mask 255.255.255.0;
    option broadcast-address 192.168.10.255;
    option routers 192.168.10.1;
    host ferramentaria {
    hardware ethernet 00:18:71:8C:3D:EB;
    fixed-address 192.168.10.124;
    host gerencia {
    hardware ethernet 00:16:36:47:B4:0B;
    fixed-address 192.168.10.117;
    host dircomercial {
    hardware ethernet 00:1B:38:21:EA:22;
    fixed-address 192.168.10.116;
    VALEU!
  5. A principio esta ok as conf, tenta ver o cabeamento, conectorização, hub, switch... e nas maquinas windows como esta configurado?
  1. Rede windows de 80 micros com problemas no compartilhamento
    Por j34nsch no fórum Sistemas Operacionais
    Último Post: 16-09-2011, 08:33
  2. problema compartilhamento velox msn em rede com dominio
    Por hudsonjr1 no fórum Servidores de Rede
    Último Post: 17-02-2011, 10:01
  3. Problemas de rede com Bullet 5
    Por Christopher no fórum Redes
    Respostas: 19
    Último Post: 25-10-2010, 21:24
  4. placa de rede broadcom problemas com kernel 2.6.16.11
    Por alexandrecorrea no fórum Sistemas Operacionais
    Último Post: 30-04-2006, 22:02
  5. Placa de rede com problema
    Por aspenbr no fórum Servidores de Rede
    Último Post: 28-09-2004, 14:36
