    Padrão Lançado a versão 3.24
    What's new in 3.24:
    *) added ability to run non RouterOS in MetaROUTER;
    *) improved address-list and layer7 firewall feature support for smp systems;
    *) special-login items can now be disabled;
    *) fixed special-login to update used-by property of port;
    *) fixed USB UPS monitoring on RB433UAH;
    *) console - 'print' command reuses assigned item numbers;
    *) fixed issue with Cisco BGP VPLS when used between 2 RouterOS devices;
    *) console - 'print' commands have new option 'follow-only' that continuously
    shows changes like the 'follow' option, but does not print all items
    at the beginning;
    *) api - 'follow' and 'follow-only' options of 'print' commands now work,
    '.dead' property is reported for deleted items;
    *) api - 'listen' command now is alias for 'print' with 'follow-only'
    opriont set;
    *) api - several commands running in parallel could produce intermixed
    output, fixed;
    *) console and api - fixed problem that caused property values sometimes to
    incorrectly have value '(unknown)', this could happen when running
    several console or api commands at once;
    *) fixed BGP VPLS crash when site-id > 15 used somewhere in network;
    *) changed BGP AS path number output format to ASPLAIN;
    *) console - new scheduler tasks use trimmed effective user permissions as the
    default value of policy, previously default value was "read,write,test";
    *) added ttl matcher to ipv4 firewall;
    *) improved dns cache not to allow other RRs in statically configured domains;
    *) fixed vlan on bonding;
    *) fixed bonding modes balance-alb and balance-tlb;
    *) added per-connection-classifier matcher to firewall;
    *) fixed wireless Hw. Fragmentation Threshold in WinBox;
    *) user manager - added option to specify custom Return URL
    for Authorize.Net payments;
    *) user manager - write logs to syslog topic manager,account;
    *) routing-test - support for per-VRF BGP instance redistribute settings;
    *) routing-test - speed up BGP route processing;
    *) routing-test - added routing-table configuration to RIP;
    Se, *) special-login items can now be disabled; for o que estou pensando, uma reinvindicação minha e de dezenas de pessoas foi atendida pela MK. Rumo aos testes!!!!
    O que seria essa opção "special-login items can now be disabled", o que ela faz?
    tambem fiquei curioso, o que seria isso?
    Bom testei agora mesmo a 3.24 e não encontrei essa opção (somente em modo terminal por linha de comando). Esse opção deveria ser teoricamente a possibilidade de criar um grupo de usuários a qual eu poderia dizer quais são os menus (ou itens) que serão mostrados. Isso seria fabuloso, pois poderia configurar meus equipamentos e liberar para os funcionários apenas os menus que eles iriam utilizar, tirando todos os outros de configuração... Tem uns 2 anos que peço isso (inclusive no wiki da Mikrotik, tem uma "lista de desejos"), mas parece que até agora nada.
    o problema dos Ping, ainda nao foi resolvido..... acho que esqueceram.
    Citação Postado originalmente por jhonnyp Ver Post
    Que bendito problema de ping é esse??? Não consigo de forma alguma reproduzir isso aqui.
