PCC
  1. Tenho estado tentando realizar a configuracion vendo os exemplos, mas fazem-no com ADSL da mesma capacidade, em m i caso tenho meus ADSL como segue:
    Interface do links:
    ADSL 4 MB = Ether3-ADSL1(2WIRE-1)-main
    ADSL 2 MB = Ether4-ADSL2(2WIRE-2)-second
    Interface Clientes= Ether1-MKT TOWER
    Modem ADSL em modo ruteador
    100.10.1.254 = Ip do modem A (ADSL 4MB)
    100.10.2.254 = Ip do modem B (ADSL 2 MB)
    Endereços das interfaces no Mikrotik ROS
    100.10.1.8 = Ip da interface Ether3-ADSL1(2WIRE-1)-main
    100.10.2.10 = Ip da interface ADSL2(2WIRE-2)-second
    Mangle:
    add action=accept chain=prerouting comment="SEM BALANCE" disabled=no dst-address-list=sem_balance in-interface=Ether1-MKT TOWER
    add action=mark-connection chain=input comment="ADSL1_conn" connection-state=new disabled=no in-interface=Ether3-ADSL1(2WIRE-1)-main new-connection-mark=ADSL1_conn passthrough=yes
    add action=mark-connection chain=input comment="ADSL2_conn" connection-state=new disabled=no in-interface= Ether4-ADSL2(2WIRE-2)-second new-connection-mark=ADSL2_conn passthrough=yes
    add action=mark-routing chain=output comment="to_ADSL1" connection-mark= ADSL1_conn disabled=no new-routing-mark=to_ADSL1 passthrough=no
    add action=mark-routing chain=output comment="to_ADSL2" connection-mark= ADSL2_conn disabled=no new-routing-mark=to_ADSL2 passthrough=no
    (Nesta seccion que segue é onde tenho dúvidas ao igual que em ROUTES, agradecere a ajuda para completar as instruções nesta seccion considerando a informacion proporcionada ao princípio)
    Nat:
    add action=masquerade chain=srcnat comment="MASCARAMENTO PCC ADSL1" disabled=no out-interface= Ether3-ADSL1(2WIRE-1)-main
    add action=masquerade chain=srcnat comment=" MASCARAMENTO PCC ADSL2" disabled=no out-interface= Ether4-ADSL2(2WIRE-2)-second
    Rotas:
    add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=100.10.1.254 scope=30 target-scope=10
    add comment="" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=100.10.2.254 scope=30 target-scope=10
    aqui em rotas esta correcto ou falta-me algo?
    agradecere a ajuda
    saludos
  2. /ip firewall mangle
    add action=mark-connection chain=input comment=ether1_conn connection-state=new disabled=no in-interface=ether1 new-connection-mark=ether1_conn passthrough=yes
    add action=mark-connection chain=input comment=ether2_conn connection-state=new disabled=no in-interface=ether2 new-connection-mark=ether2_conn passthrough=yes
    add action=mark-routing chain=output comment=to_ether1 connection-mark=ether1_conn connection-state=new disabled=no new-routing-mark=to_ether1 passthrough=no
    add action=mark-routing chain=output comment=to_ether2 connection-mark=ether2_conn connection-state=new disabled=no new-routing-mark=to_ether2 passthrough=no
    add action=mark-connection chain=prerouting comment=ether1_conn disabled=no dst-address-type=!local in-interface=ether9-Clientes new-connection-mark=ether1_conn passthrough=yes per-connection-classifier=both-addresses:3/0
    add action=mark-connection chain=prerouting comment=ether1_conn disabled=no dst-address-type=!local in-interface=ether9-Clientes new-connection-mark=ether1_conn passthrough=yes per-connection-classifier=both-addresses:3/1
    add action=mark-connection chain=prerouting comment=ether2_conn disabled=no dst-address-type=!local in-interface=ether9-Clientes new-connection-mark=ether2_conn passthrough=yes per-connection-classifier=both-addresses:3/2
    add action=mark-routing chain=prerouting comment=to_ether1 connection-mark=ether1_conn disabled=no in-interface=ether9-Clientes new-routing-mark=to_ether1 passthrough=no
    add action=mark-routing chain=prerouting comment=to_ether2 connection-mark=ether2_conn disabled=no in-interface=ether9-Clientes new-routing-mark=to_ether2 passthrough=no
    /ip firewall nat
    add action=masquerade chain=srcnat comment="" disabled=no out-interface=ether1
    add action=masquerade chain=srcnat comment="" disabled=no out-interface=ether2
    /ip route
    add comment=link1 disabled=no distance=1 dst-address=0.0.0.0/0 gateway=100.10.1.254 scope=30 target-scope=10
    add comment=link2 disabled=no distance=2 dst-address=0.0.0.0/0 gateway=100.10.2.254 scope=30 target-scope=10
    add comment=link1 disabled=no distance=1 dst-address=0.0.0.0/0 gateway=100.10.1.254 routing-mark=to_ether1 scope=30 target-scope=10
    add comment=link2 disabled=no distance=1 dst-address=0.0.0.0/0 gateway=100.10.2.254 routing-mark=to_ether2 scope=30 target-scope=10
    segue as regras so foi mudado pra sua estrutura de dois links um de 4mb e outro de 2mb as regras sao as mesmas postadas aki mesmo pelo tiago matias so adptadas pra sua realidade contando 2 pro link maior e 1 pro link menor...
  3. hola aprinou, muito obrigado por responder
    segui as regras que me indicaste e se consigo navegar, somente que em IP ROUTE me ficaram umas regras em azul, o que fiz foi criar um bridge com os ether1, ether2 e ether3 ao que chame CLIENTES, e no ether8 e ether9 pus meus ADSL
    /ip firewall mangle
    add action=accept chain=prerouting comment="SIN BALANCE" disabled=no \
    dst-address-list=sem_balance in-interface=CLIENTES
    add action=mark-connection chain=input comment="marca conexion ADSL1_conn" \
    connection-state=new disabled=no in-interface=Ether8-ADSL1 \
    add action=mark-connection chain=input comment="marca conexion ADSL2_conn" \
    connection-state=new disabled=no in-interface=Ether9-ADSL2 \
    add action=mark-routing chain=output comment="pone marca de ruteo to_ADSL1" \
    connection-mark=ADSL1_conn disabled=no new-routing-mark=to_ADSL1 \
    passthrough=no
    add action=mark-routing chain=output comment="pone marca de ruteo to_ADSL2" \
    connection-mark=ADSL2_conn disabled=no new-routing-mark=to_ADSL2 \
    passthrough=no
    add action=mark-connection chain=prerouting comment=ether1_conn disabled=no \
    dst-address-type=!local in-interface=CLIENTES new-connection-mark=\
    ADSL1_conn passthrough=yes per-connection-classifier=both-addresses:3/0
    ADSL1_conn passthrough=yes per-connection-classifier=both-addresses:3/1
    add action=mark-connection chain=prerouting comment=ether2_conn disabled=no \
    ADSL2_conn passthrough=yes per-connection-classifier=both-addresses:3/2
    add action=mark-routing chain=prerouting comment=to_ether1 connection-mark=\
    ADSL1_conn disabled=no in-interface=CLIENTES new-routing-mark=to_ADSL1 \
    passthrough=no
    add action=mark-routing chain=prerouting comment=to_ether2 connection-mark=\
    ADSL2_conn disabled=no in-interface=CLIENTES new-routing-mark=to_ADSL2 \
    passthrough=no
    /ip firewall nat
    add action=masquerade chain=srcnat comment="enmascara PCC ADSL1" disabled=no \
    out-interface=Ether8-ADSL1
    add action=masquerade chain=srcnat comment="enmascara PCC ADSL2" disabled=no \
    out-interface=Ether9-ADSL2
    add action=masquerade chain=srcnat comment="enmascara interface CLIENTES" \
    disabled=no out-interface=CLIENTES
    /ip route
    (estas regras ficam em cor azul)
    add comment=link2 disabled=no distance=2 dst-address=0.0.0.0/0 gateway=\
    add comment=link1 disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
    (estas regras aparecem bem)
    add comment=link2 disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
    100.10.2.254 routing-mark=to_ADSL2 scope=30 target-scope=10
    100.10.1.254 routing-mark=to_ADSL1 scope=30 target-scope=10
    agradecere a ajuda para corrigir este balanço, como te comento no bridge chamado CLIENTES concte um computador e estou a navegar mas essas regras seguem em azul...
    saludos
  4. sim ficao em azul pois elas ficam em standy by pois elas podem ser monitoradas via chek ping ou netwatch verificando a atividade dos links caso um saia fora vai pro outro link por isso tem as distancias neles, caso use modem em modo roteado use o netwatch pra monitorar seus links e rodar regras de desativar etc...esssa regras que postem e apenas um exemplo que vc deve claro adptar pro nos de suas interfaces...
  5. Aprinou, vc comentou que elas ficam em Stanby by para serem monitoradas, isso em modo chek ping é para os modems em router, e para quem ta usando em modo bridge, o MK discando, como seria esse monitoramento em ping, ja que so tem interfaces ativas? no caso os discadores pppoe´s.
  1. PCC Balance de 3 a 16 links - Por: M4D3
    Por m4d3 no fórum Redes
    Respostas: 509
    Último Post: 30-05-2016, 12:59
  2. Ajuda PCC Mikrotik
    Por marsilba no fórum Redes
    Respostas: 5
    Último Post: 19-09-2009, 20:32
  3. Problemas depois de implementar PCC
    Por antonoel no fórum Redes
    Último Post: 14-08-2009, 09:57
  4. Lentidão depois do PCC
    Por Evilazio no fórum Redes
    Respostas: 17
    Último Post: 04-08-2009, 22:56
  5. Respostas: 2
    Último Post: 24-07-2009, 19:11
