  1. Bom pessoal consegui configurar, configurei um Link dedicado de 4MB + 1 Adsl de 4MB em Bridge, porém o que acontece é que o consumo do Dedicado tá em torno de 90% e o ADSL tá consumindo muito pouquinhu ( faixa de 20K à 200K ), vou postar as regras pra vcs analisarem e posivelmente dizer o que tem errado !
    /ip firewall mangle
    add action=mark-connection chain=input comment="Pacotes via Interface" connection-state=new disabled=no in-interface=Link \
    new-connection-mark=wan1_conn passthrough=yes
    add action=mark-connection chain=input comment="" connection-state=new disabled=no in-interface=pppoe-out1 \
    new-connection-mark=wan2_conn passthrough=yes
    add action=mark-routing chain=output comment="" connection-mark=wan1_conn connection-state=new disabled=no \
    new-routing-mark=to_wan1 passthrough=no
    add action=mark-routing chain=output comment="" connection-mark=wan2_conn connection-state=new disabled=no \
    new-routing-mark=to_wan2 passthrough=no
    add action=accept chain=prerouting comment=Bancos disabled=no dst-address-list=loopback in-interface=Clientes
    add action=mark-connection chain=prerouting comment="" disabled=no dst-address-type=!local in-interface=Clientes \
    new-connection-mark=wan1_conn passthrough=yes per-connection-classifier=both-addresses:2/0
    new-connection-mark=wan2_conn passthrough=yes per-connection-classifier=both-addresses:2/1
    add action=mark-routing chain=prerouting comment="" connection-mark=wan1_conn disabled=no in-interface=Clientes \
    add action=mark-routing chain=prerouting comment="" connection-mark=wan2_conn disabled=no in-interface=Clientes \
    NAT
    /ip firewall nat
    add action=masquerade chain=srcnat comment="" disabled=no out-interface=Link
    add action=masquerade chain=srcnat comment="" disabled=no out-interface=pppoe-out1
    Rotas
    [quote]
    /ip route
    add check-gateway=ping comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=189.45.13.182 routing-mark=to_wan1 \
    scope=255 target-scope=10
    add check-gateway=ping comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out1 routing-mark=to_wan2 \
    add check-gateway=ping comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=189.45.13.182 scope=255 \
    target-scope=10
    add check-gateway=ping comment="" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=pppoe-out1 scope=255 target-scope=\
    [quote]
    Onde Link é o IP Dedicado e o pppoe-out é o ADSL.
    Desde já agradeco a ajuda !
  2. Citação Postado originalmente por tiagomatias Ver Post
    Só para ficar mais claro as regras q ira repetir de acordo com o manual do m4d3 são:
    add action=mark-connection chain=prerouting comment="" disabled=no dst-address-type=!local in-interface=EthClientes new-connection-mark=conn_ma0 passthrough=yes per-connection-classifier=both-addresses:2/0
    add action=mark-connection chain=prerouting comment="" disabled=no dst-address-type=!local in-interface=EthClientes new-connection-mark=conn_ma0 passthrough=yes per-connection-classifier=both-addresses:2/1
    basta repetir elas como por exemplo acima repeti a regra jogando duas vezes para um link, como viu acoma basta vc fazer os calculos necessarios e fazer de acordo com sua necessidade
    No meu caso, tenho um link dedicado de 1mb e 1 link adsl de 1 mb.
    Como fazer?
  3. [quote=admskill;455449]Bom pessoal consegui configurar, configurei um Link dedicado de 4MB + 1 Adsl de 4MB em Bridge, porém o que acontece é que o consumo do Dedicado tá em torno de 90% e o ADSL tá consumindo muito pouquinhu ( faixa de 20K à 200K ), vou postar as regras pra vcs analisarem e posivelmente dizer o que tem errado !
    NAT
    Rotas
    [quote]
    /ip route
    target-scope=10
    Acho que no nosso caso caso temos que considerar o link dedicado como sendo 8 vezes melhor que o ADSL. Estou certo ou não?
  4. [quote=admskill;455449]Bom pessoal consegui configurar, configurei um Link dedicado de 4MB + 1 Adsl de 4MB em Bridge, porém o que acontece é que o consumo do Dedicado tá em torno de 90% e o ADSL tá consumindo muito pouquinhu ( faixa de 20K à 200K ), vou postar as regras pra vcs analisarem e posivelmente dizer o que tem errado !
    NAT
    Rotas
    [quote]
    /ip route
    target-scope=10
    tem que alterar os valor das distance na primeira regra a baixo 2 e a outra 3 testa que deve dar certo.
    add check-gateway=ping comment="" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=189.45.13.182 scope=255 \
    target-scope=10
    add check-gateway=ping comment="" disabled=no distance=3 dst-address=0.0.0.0/0 gateway=pppoe-out1 scope=255 target-scope=\
    [quote]
  5. Citação Postado originalmente por m4d3 Ver Post
    PCC LOADBALANCE - 3 LINKS SIMÉTRICOS (TESTADO DE 2 ATÉ 16 LINKS)
    MKV: 3.x
    MKR: 3.28
    EthLinkA = Interface do primeiro link
    EthLinkB = Interface do segundo link
    EthLinkC = Interface do terceiro link
    EthClientes = Interface dos clientes
    Quando em modo roteado:
    10.1.10.129 = Ip do modem A
    10.1.10.161 = Ip do modem B
    10.1.10.193 = Ip do modem C
    Endereços das interfaces no Mikrotik ROS
    10.1.10.130/27 = Ip da interface EthLinkA
    10.1.10.162/27 = Ip da interface EthLinkB
    10.1.10.194/27 = Ip da interface EthLinkC
    Vamos as regras e explanações sobre o sistema PCC
    Em mangle
    add action=accept chain=prerouting comment="SEM BALANCE" disabled=no dst-address-list=sem_balance in-interface=EthClientes
    esta primera regra aceita as conexões para todos os ips de destino que se encontrarem na lista 'sem_balance' que irão sair pela rota padrão
    add action=mark-connection chain=input comment="" connection-state=new disabled=no in-interface=EthLinkA new-connection-mark=conn_na passthrough=yes
    add action=mark-connection chain=input comment="" connection-state=new disabled=no in-interface=EthLinkB new-connection-mark=conn_nb passthrough=yes
    add action=mark-connection chain=input comment="" connection-state=new disabled=no in-interface=EthLinkC new-connection-mark=conn_nc passthrough=yes
    cria as marcas (conn_na, conn_nb, conn_nc) para novas conexões em cada uma das interfaces (EthLinkA, EthLinkB, EthLinkC)
    add action=mark-routing chain=output comment="" connection-mark=conn_na disabled=no new-routing-mark=to_ra passthrough=no
    add action=mark-routing chain=output comment="" connection-mark=conn_nb disabled=no new-routing-mark=to_rb passthrough=no
    add action=mark-routing chain=output comment="" connection-mark=conn_nc disabled=no new-routing-mark=to_rc passthrough=no
    utiliza as marcações (conn_na, conn_nb, conn_nc) para criar as marcações das respectivas rotas (to_ra, to_rb, to_rc)
    add action=mark-connection chain=prerouting comment="" disabled=no dst-address-type=!local in-interface=EthClientes new-connection-mark=conn_ma0 passthrough=yes per-connection-classifier=both-addresses:3/0
    add action=mark-connection chain=prerouting comment="" disabled=no dst-address-type=!local in-interface=EthClientes new-connection-mark=conn_mb1 passthrough=yes per-connection-classifier=both-addresses:3/1
    add action=mark-connection chain=prerouting comment="" disabled=no dst-address-type=!local in-interface=EthClientes new-connection-mark=conn_mc2 passthrough=yes per-connection-classifier=both-addresses:3/2
    agora utilizando os classificadores (0,1,2 e portanto são 3) na interface de clientes criamos novas marcas de conexão (conn_ma0, conn_mb1, conn_mc2), notem que se tivessemos 4 links seria aquie que fariamos as alterações para (0,1,2,3 e portanto são 4) ficando 4/0, 4/1, 4/2, 4/3 ou ainda se tivessemos links assimétricos onde por exemplo:
    LinkX de 512k
    LinkY de 1024k
    LinkZ de 2048k
    somariamos todos os links e dividiriamos pelo valor do menor link então teriamos 3584k/512k=7 então teriamos 7 marcações de pcc indo de 7/0 até 7/6 das quais devemos direcionar a primeira pro link X, a segunda e terceira pro link Y e as quatro restantes para o link Z fazendo nosso sistema perfeitamente equilibrado, vale resaltar que sistemas do tipo ADSL não garantem a banda e portanto devemos fazer testes em cada um dos links para aferir as velocidades possíveis em cada um, já vi muitos casos onde um link desse tipo de 2Mb era melhor do que o de 4Mb da mesma operadora instalada no mesmo local, também se deve criar as marcações para input e output.
    add action=mark-routing chain=prerouting comment="" connection-mark=conn_ma0 disabled=no in-interface=EthClientes new-routing-mark=to_nra passthrough=no
    add action=mark-routing chain=prerouting comment="" connection-mark=conn_mb1 disabled=no in-interface=EthClientes new-routing-mark=to_nrb passthrough=no
    add action=mark-routing chain=prerouting comment="" connection-mark=conn_mc2 disabled=no in-interface=EthClientes new-routing-mark=to_nrc passthrough=no
    utilizando das novas marcações (conn_ma0, conn_mb1, conn_mc2) criamos uma nova marcação de rota na interface de clientes como (to_nra, to_nrb, to_nrc)
    Em nat
    add action=masquerade chain=srcnat comment="MASCARAMENTO PCC" disabled=no out-interface=EthLinkA
    add action=masquerade chain=srcnat comment="" disabled=no out-interface=EthLinkB
    add action=masquerade chain=srcnat comment="" disabled=no out-interface=EthLinkC
    vale resaltar que o mascaramento pode ser feito de várias formas, indicando por exempo o ip da interface em src-nat, pela range de ips dos clientes e pela interface do link como acima.
    Em rotas
    add comment="" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=10.1.10.129 scope=30 target-scope=10
    add comment="" disabled=no distance=3 dst-address=0.0.0.0/0 gateway=10.1.10.161 scope=30 target-scope=10
    add comment="" disabled=no distance=4 dst-address=0.0.0.0/0 gateway=10.1.10.193 scope=30 target-scope=10
    definimos 3 rotas padrão sendo que cada uma tem um custo diferente e portanto a primeira terá a preferencia, caso venha a faltar a segunda assume, em seguida a terceira
    add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.1.10.129 routing-mark=to_nra scope=30 target-scope=10
    add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.1.10.161 routing-mark=to_nrc scope=30 target-scope=10
    add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.1.10.193 routing-mark=to_nrb scope=30 target-scope=10
    em seguida todas as 3 rotas que utilizam marca de rotas (to_nra, to_nrb, to_nrc) dividem a carga que foi previamente marcada pelo mangle
    Ainda é possível fazer com que o próprio Mikrotik ROS disque as conexões do tipo ADSL aumentando a eficiência do sistema (MODENS EM BRIDGE), sendo que neste caso é recomendado fazer o mascaramento por range de ips e não por interface e a indicação dos gateways por interface e não por ip, no caso de links dedicados é recomendável fazer a indicação do ip do gateway e não da interface.
    Em nat
    add action=masquerade chain=srcnat src-address=10.0.0.0/24 comment="MASCARAMENTO PCC" disabled=no
    Em rotas
    add comment="" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=EthLinkA scope=30 target-scope=10
    add comment="" disabled=no distance=3 dst-address=0.0.0.0/0 gateway=EthLinkB scope=30 target-scope=10
    add comment="" disabled=no distance=4 dst-address=0.0.0.0/0 gateway=EthLinkC scope=30 target-scope=10
    add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=EthLinkA routing-mark=to_nra
    add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=EthLinkB routing-mark=to_nrb
    add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=EthLinkC routing-mark=to_nrc
    Com relação ao usar o check ping, devemos tomar um certo cuidado pois links de diferentes tipos tendem a ter diferentes tempos de resposta ao ping e quando este método é utilizado pode ocorrer desigualdade entre os consumos dos links apesar de as marcações estarem corretas, isso porque o sistema leva em consideração o tempo de resposta de cada gateway.
    Dica:
    /system ntp client
    set enabled=yes mode=unicast primary-ntp=a.ntp.br
    set enabled=yes mode=unicast secondary-ntp=b.ntp.br
    importante manter o relógio do seu sistema em sincronia com UTC para automação de tarefas e registro de logs.
    Complemento:
    utilize sofware Mikrotik ROS original, quando você utiliza um sofware Mikrotik ROS original, esta contribuindo para o desenvolvimento de novas e importantes ferramentas como é o caso do PCC e tantas outras melhorias incorporadas.
    Licença Mikrotik Level 4 - Até 200 usuários simultâneos ~ R$ 110,00
    Licença Mikrotik Level 5 - Até 500 usuários simultâneos ~ R$ 210,00
    Licença Mikrotik Level 6 - Ilimitados usuários simultâneos ~ R$ 510,00
    valores em reais em 29/08/2009 - onde encontrar:> MD Brasil - Inicial
    Fonte:
    https://under-linux.org/f128610-pcc
    PCC - MikroTik Wiki
    http://forum.mikrotik.com/viewtopic....31415&start=50
    Agradecimentos:
    normis, NetworkPro, Chupaka, omega-00, tiagom, andre
    Compilado por:
    Quero te agradecer, pois deu certo aqui em casa onde estou fazendo um laboratorio com o pcc.
    Tenho 2 modens da virtua que é conexao direta no caso do mk tive que colocar dhcp cliente, porem nao conseguia fazer funcionar o pcc, ai coloquei 2 routers so para ter um ip fixo e colocar exatamente seu post para funcionar, foi o mk deu a luz!!!!!
    Sera que o modem da virtua so desta forma que funciona? (com router antes do mk?)
    Vou agora baixar o megaupload onde tenho uma conta de 6 meses e tentar fazer qualquer down para testar a prformance de dois links de 12Mb.
    Obrigadao pela ajuda, seu post foi 10000000000....
    Aproveito para desejar a todos um otimo 2010 com muitas realizacoes e PAZ.
  1. Respostas: 12
    Último Post: 15-05-2015, 17:14
  2. Respostas: 6
    Último Post: 08-03-2015, 02:04
  3. Respostas: 2
    Último Post: 18-06-2014, 16:27
  4. Respostas: 273
    Último Post: 20-09-2012, 10:39
  5. duvida sobre link dedicado por balance de operadora
    Por boneco no fórum Servidores de Rede
    Respostas: 13
    Último Post: 05-05-2011, 18:07
